Spiral cable replcement then got airbag light
Discussion in '2nd Gen. Tacomas (2005-2015)' started by coopjl, Sep 5, 2018.
  1. Sep 5, 2018 at 6:55 PM
    coopjl
    coopjl [OP] Well-Known Member
    Jeff
    Fairbanks, Alaska
    2014 Double Cab
    ARB Deluxe bull bar ARB Fog lights ARB Driving lights 24" Vision X Light bar ARB Rear locker w/4.56 ARB Front locker w/4.56 ARB Compressor Warn M8000# winch OME HD suspension CBI rock sliders CBI Trail Rider rear bumper with tire carrier and fuel can carrier Lear Topper with wilderness package TRD Matte Black Wheels SlimLine FrontRunner II Roof rack
    Just replaced my spiral cable on my 2014 because my horn wouldn’t work unless the steering wheel was turned. No problem, easy job. However, now my airbag light remains on. Ugh!
    Any suggestions?
  2. Sep 5, 2018 at 6:56 PM
    boogie3478
    boogie3478 Well-Known Member
    14 TRD Off-Road V6
    All the mods
    Maybe disconnect the battery for 15 minutes, reconnect, and check again?
  3. Sep 5, 2018 at 7:23 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Or you have something connected incorrectly or incompletely.
    12TRDTacoma likes this.
  4. Sep 5, 2018 at 7:52 PM
    coopjl
    Jeff
    Fairbanks, Alaska
    2014 Double Cab
    I had disconnected the battery while I did this (about 40 minutes start to finish).
    Took everything apart again to ensure all connections were tight.
  5. Sep 5, 2018 at 8:12 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Where did you get the clockspring?
  6. Sep 5, 2018 at 8:13 PM
    coopjl
    Jeff
    Fairbanks, Alaska
    2014 Double Cab
    Amazon. Really hoping that is not where I went wrong, but we’ll aware it may be just that
  7. Sep 5, 2018 at 8:15 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Possible you have a different code going on in the SRS system?
    This is a stupid question, but gotta be sure, did you plug in the clockspring entirely?
  8. Sep 5, 2018 at 8:15 PM
    jboudreaux1965
    jboudreaux1965 Ragin Cajun Fan
    Joseph
    Hub City
    2023 TRD Sport
    That wasn't under recall?
  9. Sep 5, 2018 at 8:19 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    I think recalls are only good for one and done. I suspect my dealer never replaced mine, because my horn is no longer operable as well. Stupid problem to have on what has otherwise been a good truck.
  10. Sep 5, 2018 at 8:29 PM
    jboudreaux1965
    Joseph
    Hub City
    2023 TRD Sport
    What do you mean one and done? It was replaced before?
  11. Sep 5, 2018 at 8:44 PM
    jboudreaux1965
    Joseph
    Hub City
    2023 TRD Sport
    I mean service records will show if the spiral cable was replaced under warranty, if your in doubt. Anyone here have an active TIS account and can run his VIN? Mine expired couple months ago, when I can renew it ($75 a month) I'll run it for you. Or maybe just ask another dealership to run your VIN?
  12. Sep 6, 2018 at 5:18 AM
    DesertRatliff
    DesertRatliff Well-Known Member
    Mt. Hood, OR
    Mas Tacos Por Favor
    I got a POS Amazon one for the wife's truck. When I did it, the air bag light went on too and wouldn't go off. I took everything apart and noticed I hadn't fully closed one of the yellow air bag connectors because the new clock spring was just a bit off of factory fit and finish. I would go back and check your work before you try to diagnose anything else.
    EDIT: to my knowledge, the air bag system monitoring is in real time. If it all checks out, the light will disappear without the need to re-set/clear the code.
  13. Sep 6, 2018 at 5:23 AM
    poseytaco
    poseytaco Well-Known Member
    Nicholas
    Indiana
    2012 Off-road
    I wouldn’t use any aftermarket clockspring. That is probably your problem. I Had the same problem that you had. Horn wouldn’t sound unless I turned the steering wheel. Replaced the clockspring with oem and have been good for over a year. I’ve heard nothing good about aftermarket clocksprings.
    jboudreaux1965 and REDdawn6 like this.
  14. Sep 6, 2018 at 7:02 AM
    coopjl
    Jeff
    Fairbanks, Alaska
    2014 Double Cab
    Thanks everyone.
    I reinstalled my original cable and the airbag light went out (but the horn still didn’t work).
    Guess I’ll have to get off my wallet.
    REDdawn6 and Muddinfun like this.
