Splicing rigids in factory fogs
Discussion in 'Lighting' started by commonsense87, Apr 27, 2015.
  1. Apr 27, 2015 at 8:52 PM
    commonsense87
    commonsense87 [OP] Well-Known Member
    Noah
    Edwards, CO
    2013 DCLB w/ Flatbed
    35’s and a flatbed ‍♂️
    I'm having trouble splicing my rigids into my factory fogs. Should be straight forward as I've been reading but won't work for some reason. Any help would be great!!
  2. Apr 28, 2015 at 8:42 AM
    RacecarGuy
    RacecarGuy Well-Known Member
    Houston, Texas
    '12 DCSB OR
    Pelfreybilt front and rear HC bumper w/swingout, BAMF LCA Skids, BAMF Diff skid, Pelfreybilt IFS and Trans skid, RCI gas tank skid, Bronze SCS F-5's, Icon RR's ext travel, Dakar leafs, Archive Garage shackle flip
    What kind of trouble? It should be two wires, if its not correct, flip the two. I made some harness with an set of connectors from Ebay, but I think TAP sells harnesses for direct plug in now, pretty cheap. Have you tried leaving one of the stock foglight plugged in, while plugging one Rigid in, to see if any will turn on? That could indicate if a fuse is blown if nothing will turn on.
  3. Apr 28, 2015 at 8:48 AM
    llibrm
    llibrm OH NOOOOOO!
    Bill
    Winthrop, WA &Convection Oven, AZ
    06 DCSB, 06 LC120 (sold)
    Pelfreybilt Aluminum Bumper, KING 2.5 on all four corners, 4x4 illuminated switch, Cobra 75 w/ 3' Firestick, 2M/ 70cm Radio w/ Diamond NR770HB, Pelfreybilt bed bar, Lightforce Stiker 170s, BD 20" OnX6, BD S2 ditch lites on SDHQ mounts, BD SAE Fogs
    Make sure your battery is charged. My battery was down to around 10v when I installed mine. I thought something was severely wrong. Turned out it was having the radio on was enough to drain my aging battery. Charged it up and soldered on the factory plugs, after checking for polarity, and BAM! everything worked. It wasn't the anytime fog mod or the switch or anything else that I checked before realizing it was the battery.
    Good Luck
  4. Apr 28, 2015 at 10:53 AM
    commonsense87
    Noah
    Edwards, CO
    Tried both ways on connecting, before soldering I wanted to make sure that it would work. I'll look into the TAP harness now, but am going to try to recharge the battery to see if its thats. I'll let ya guys know. Thanks!!!
