Splicing wires for aftermarket headunit
Discussion in 'Audio & Video' started by dk6487, Feb 11, 2010.
  1. Feb 11, 2010 at 7:14 PM
    dk6487
    dk6487 [OP] NorCal Member
    David
    Novato, CA
    08 Silver 4X4 TRD Sport w/ Tow Pack
    Pioneer Z110BT Nav/DVD H.U., Sub Box by Mr. Marv w/ amp and 10" Sub, Rear-Leaf TSB, L.E.D. Guage Mod, 3" OME Lift Kit w/ 885, Total Chaos UCA's
    What is the best (or perfectly acceptable) way to splice my new Pioneer AVIC-Z110BT wires? Thanks in advance.
  2. Feb 11, 2010 at 7:15 PM
    rmb_crew
    rmb_crew My other ride has 18,400HP!!!!!!
    Jacksonville, FL 30.243103, -81.591007‎
    2010 F150 XLT SuperCrew 4X4
    Access larado tonneau, magnaflow exhaust
    soder... Only way to go.
  3. Feb 11, 2010 at 7:19 PM
    dk6487
    David
    Novato, CA
    I've soldered a little bit before. I feel pretty comfortable with it but I'm not sure what type of solder I should get for this application if I go that route.
  4. Feb 11, 2010 at 7:20 PM
    rmb_crew
    just normal rosen core should be fine. I never really messed around with flux but prerunnerseth has lots of experience soldering.
  5. Feb 11, 2010 at 7:26 PM
    dk6487
    David
    Novato, CA
    Thats what I was thinking. I don't think the normal flux would be good in this project because the wires are small. The rosen core solder should work fine then it sounds like. I didn't want to spend the money before the research was completed. Thanks for your help.
  6. Feb 11, 2010 at 7:29 PM
    rmb_crew
    No Prob. I went to radioshack and picked up a new soldering iron and rosen core like two weeks about and spent $13 if that helps. It is a 40W or 45W iron so it heats up really hot.
  7. Feb 11, 2010 at 7:36 PM
    l_prettyman
    l_prettyman Well-Known Member
    Logan
    Easton Shore Maryland
    06 4x4 SR5
    12% tint, Leer cap, Pioneer Avh3100DVD headunit, Kinetik 2000 battery, Memphis pr1.1000 amp, Pioneer subwoofer(not sure what kind), Back-up Camera, PA/CB system
    40/60 rosin core solder. 40= 40% lead, but i forget what 60 stands for. i do all my wiring with that solder. go to radioshack and tell them you need solder and what your application is, mention 40/60 rosin core and get the thiner stuff. not the "pencil lead size" i believe the size that should work is 8oz.
  8. Feb 11, 2010 at 7:37 PM
    Burgman
    Burgman I KEEEEEL YOU
    Stephen
    Ric VA
    08 PreRunner TRD sport Silver
    K&N intake, Boston Acoustic SL 60 6.5 components up front, Rockford Power T16 6.5 in rear, Pioneer P4100 HU, Soon to be Pioneer Prs 4200f
    use heat shrink too, just to throw that out there
  9. Feb 11, 2010 at 7:55 PM
    dk6487
    David
    Novato, CA
    Does the heat shrink need to be rated for voltage?
  10. Feb 11, 2010 at 7:56 PM
    Burgman
    Stephen
    Ric VA
    not that i know of i believe its just in different sizes for the thickness of the wire
  11. Feb 11, 2010 at 7:57 PM
    dk6487
    David
    Novato, CA
    Cool. Thanks I'll post some pics on saturday when I do the project.
  12. Feb 11, 2010 at 8:00 PM
    l_prettyman
    Logan
    06 4x4 SR5
    heat shrink is just like electrical tape to cover up the bare wire but makes for a more professional look. make sure to put the shrink tube on the wire before you solder :p
  13. Feb 11, 2010 at 8:01 PM
    Burgman
    Stephen
    Ric VA
    heat shrink pre solder is key, especially after u get that perfect solder and have to cut in apart, that and tight places
  14. Feb 12, 2010 at 5:41 AM
    uood8
    uood8 If You Search...You Shall Find.
    Greensboro, NC
    '16 Sr5 4x4 DCSB
    Pretty much stock
    like everyone else said solder is the way. Just make sure you do it all in the house and not in the truck! Its alot easier when everything is laid out on the table.
  15. Feb 12, 2010 at 10:56 AM
    81shark
    81shark Well-Known Member
    2006 Base Access CP1
    i must be the only person that uses wire nuts with a little electrical tape to connect everything.
  16. Feb 12, 2010 at 11:53 AM
    uood8
    Greensboro, NC
    '16 Sr5 4x4 DCSB
    Pretty much stock
    yes
    :) nah just kidding. soldering is just a more reliable solution and once it is soldered the odds of it working it loose are damn near impossible.
  17. Feb 12, 2010 at 1:01 PM
    dk6487
    David
    Novato, CA
    Does anyone know if I'm better off splicing the grounds together (from stereo wiring harness to factory harness) or should I ground straight to the chasis behind the stereo? In past installs I've just connected the black grounds together and called it good.
  18. Feb 12, 2010 at 1:27 PM
    Burgman
    Stephen
    Ric VA
    i just used the factory ground for my pioneer 4100 dvd and have not had any probs
  19. Feb 12, 2010 at 5:29 PM
    uood8
    Greensboro, NC
    '16 Sr5 4x4 DCSB
    Pretty much stock
    I have a dvd headunit and mine is grounded via factory wire.
  20. Feb 12, 2010 at 5:41 PM
    l_prettyman
    Logan
    06 4x4 SR5
    aah pioneer 4100.. good choice, i got the 3100 and it does me right but i wish i had the bigger screen
