Split Rear Differential
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TGCRVT, Nov 1, 2016.
  1. Nov 1, 2016 at 2:46 AM
    TGCRVT
    TGCRVT [OP] Member
    2007 Tacoma 4.0l Manual
    I need to change the fluid in the differentials but the owners manual indicates different fluid for a split rear differential. No wanting to sound like a noob but what is a "split rear differential" and how do I know if I have one?
  2. Nov 1, 2016 at 11:17 AM
    eon_blue
    Azusa, CA
    Are you sure it didn't say "limited slip" differential? Never heard of a "split" differential...
    And yes, a limited slip differential requires fluid with the limited slip (or LSD) additive. You can find it at any auto parts store. I use this stuff in mine, keep in mind though I have a '04 Tacoma so the gear oil weight your truck requires might be different, I'm not sure. Be sure to use what your manual states.
  3. Nov 1, 2016 at 11:19 AM
    ChiefManyWrenches
    ChiefManyWrenches Well-Known Member
    Florida
    '11 Silver DCSB TRD Off Road 4WD
    Look at your pumpkin in the back, if it needs the additive it should say on there unless it came off. I think it is only the TRD Sport in that year that will potentially need it.
  4. Nov 1, 2016 at 11:56 AM
    DGXR
    DGXR Well-Known Member
    Friend
    Sacramento, CA
    2006 2.7L SR5 2-wheel drive
    If the limited slip differential uses clutches to produce the limited slip effect, then yes the additive is required. Some of the Tacoma models do not use clutches for the LSD. Rather, the limited slip system uses an *open* differential and if a wheel spins, the computer activates the brake on the slipping wheel only. This will transfer more power to the wheel that is not spinning.
    For these brake-activated LSD systems, the open differential does not require the LSD additive... it won't hurt to use the additive, I'm just saying it is not required in all of the Toyota LSD differential systems. Only the ones with clutches need the additive.
  5. Nov 1, 2016 at 11:58 AM
    ChiefManyWrenches
    Florida
    I believe the only ones that need the additive are TRD Sport models from 05-08 or 09.
  6. Nov 1, 2016 at 12:02 PM
    Kerrigan911
    Kerrigan911 Well-Known Member
    Dan
    05 TRD OR, AC, 4x4, V6
    TRD Offroad has the E-locker so LSD additive is not required. I like the Mobil 1 LS (use coupon online from advanceauto for best price)
  7. Nov 2, 2016 at 1:19 AM
    TGCRVT
    TGCRVT [OP] Member
    eon: Yes, my bad it does say limited slip differential. What I need to know is how do I tell if my truck does have one?
  8. Nov 2, 2016 at 2:03 AM
    Matic
    Matic The "OFG" Baby!!!
    Tricky Dick
    Easley, SC
    1 owner 2002 TRD, SR5, DC, 2.7. Full OME suspension, STT pro's.
    OME 881 coils with OME nitrochargers shocks up front. TC UCA's OME Dakars with extra leaf in the rear. Warn 8000 winch with 80ft custom braided synth line. Custom 60ft synth extension. All pro tube bumper, Hi-lift jack, Safari Snorkel, Wilco tiregate. 2019 Jeep JLUR.
    You just answered your own question.
    If there is a tag on the rear diff that says "LSD fluid only". then you need lsd fluid which contains an additive.
    If the tag is gone and you have a button on your dash that says "LSD" or shows a car with some squigly lines....then you probably have an lsd rear end.
    I wouldnt trust the manual as far as telling you it has lsd, because its probably covering a couple different models...and only "suggesting" that if you have lsd....to use lsd fluid.
