Spluttering V6
Discussion in 'Technical Chat' started by Raider, Jul 21, 2009.
  1. Jul 21, 2009 at 1:08 AM
    Raider
    Raider [OP] Active Member
    Durban, South Africa
    2005 2.7 Double Cab Hilux
    31 BFG AT's, S/Steel rollbar/side steps/bullbar, Powerflo exhaust (side exit)
    My wife got a new 2009 Fortuner(SUV using the Hilux chassis and same motors)
    and the V6 jerks and splutters(almost like a misfire or fuel starvation) when cold and is even slightly noticable when hot, it has been back twice and they seem clueless but say they need it for longer to check out properly. Any ideas???
  2. Jul 21, 2009 at 4:09 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Take it back to the dealer.... You should still be under warrantee!!
    (unless they do things differently there in Africa)
    Seriously - if you start messing with it to try and fix it yourself, the dealer could use that againest you. Atleast, that's what they try to do here in USA.
  3. Jul 21, 2009 at 4:45 AM
    Raider
    Yeah we are doing just that but out of interest I thought somebody might have had the same problem here on TW, they also can't seem to find the problem??
  4. Jul 28, 2009 at 12:01 AM
    Raider
    They finally found the fault after another 3 hrs on ramp - fault with wiring loom???
    Temp fix for now and new one ordered - V6 is hummin now!!!
