sPOD Radio Interference
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Taco@NC, Dec 7, 2016.
  1. Dec 7, 2016 at 12:11 PM
    Taco@NC
    Taco@NC [OP] Well-Known Member
    Mark
    Marion, NC
    2015 Blue Ribbon Tacoma Offroad 4x4
    Camper Shell, Door stil protectors, Color Matched Grille, Rugged Ridge floor liners, Redline hood struts, Anti-Dark hood light, and sPOD Universal 6 modular with an Iggy corp switch panel
    Alright I got a problem! I installed my sPOD in my 2015 Tacoma! After installation my radiostations I listen to, only a few of them are coming in! I grounded the negative of the sPOD to the fender of the truck(where the ground coming off the battery to the fender)! So after I noticed the interference, I moved the ground from the sPOD to the battery terminal! Still getting interference but not as bad! Is there anything I can do to to reduce the interference more?
  2. Dec 7, 2016 at 12:11 PM
    T4RFTMFW
    T4RFTMFW Well-Known Member
  3. Dec 7, 2016 at 12:18 PM
    ChadsPride
    Sponsored by TacomaWorld.com
    :goingcrazy::goingcrazy::goingcrazy::goingcrazy::goingcrazy:
    I THOUGHT SOMEBODY WAS IN DANGER
  4. Dec 7, 2016 at 12:24 PM
    Chase8059
    Chase8059 Kinda Well-Known
    Chase
    ESVA
    2015 DCSB TRD Sport | Super White : 2008 Lexus IS 350
    OME 887, JBA UCAs, 1.5 AAL, Fox 2.0 RR w CD adj., SCS SR8s Gunmetal, Falken AT3/W 265/70r17
    I could already hear sirens, glad the OP is OK....
    Maybe change the title so people know what your problem is?
    ChadsPride[QUOTED] likes this.
  5. Dec 7, 2016 at 12:28 PM
    Taco@NC
    Mark
    Marion, NC
    Done!! Is that better??
    Chase8059[QUOTED] and ChadsPride like this.
  6. Dec 7, 2016 at 12:53 PM
    Chase8059
    Chase
    ESVA
    Nicely done. So I don't have an sPOD, so I will offer some generic electrical advice until someone else chimes in. Did you have to disconnect anything radio related for the install? Could you have potentially loosened the radio or antennae ground?
  7. Dec 7, 2016 at 1:57 PM
    Taco@NC
    Mark
    Marion, NC
    Nope just mounted the sPOD on top of the fuse box and ran the wires to the switches in the cab. Hooked up the positive and negative to the battery. But at first I had the ground going to the fender ground! Now I hooked it to the battery!
