Spod switch panel
Discussion in 'Lighting' started by 50stateoverlander, Mar 12, 2019.
  1. Apr 19, 2019 at 10:54 AM
    Roofy
    Roofy Well-Known Member
    Virginia
    '14 Sport 4x4 DCLB
    Bilstein 5100’s, Vision Wheels, slotted StopTech rotors, TRD pads, SPOD, Decked Drawers, N'Fab Steps, Leer Cap, KC Highlites 40” & Cyclones underbody and under the hood, Rigid Scenes mounted to Prinsu Rack, anytime LED Fogs, TacomaBeast headlights, RAGO bed stiffeners, USB-C rocker in cab & 2xUSB in bed w/anytime on option, Alpine Head Unit, Front Camera.
    Saw a YouTube on this.
    @Alesimo has a stick. Maybe he can chime in
  2. Apr 19, 2019 at 11:05 AM
    velogeek
    velogeek Well-Known Member
    Andrew
    Gilbert, AZ
    2024 4Runner
    This is a good portion of why I ended up with a SwitchPros instead. The unit is freaking tiny by comparison because it's solid-state and SDHQ makes a bracket that offsets the unit toward the rear of the truck so you don't have to move your reservoir.
    Lunchmeat79[QUOTED] likes this.
  3. Apr 19, 2019 at 12:01 PM
    Lunchmeat79
    Lunchmeat79 Well-Known Member
    Kansas
    '18 Off Road
    I like the smaller size of the switch pro but I like the built in bus bars and wearherproof enclosure on the spod. Is one more reliable than the other in the long run?
  4. Apr 19, 2019 at 12:41 PM
    velogeek
    Andrew
    Gilbert, AZ
    2024 4Runner
    In theory the SP9100 would last longer given it's solid state (no exposure to elements, no moving parts, regulated voltages, etc.) but it also means that if something fails, you're SOL as it's one sealed unit. It's a trade-off one way or the other. Worst case scenario, I carry a small spool of 10ga wire in my kit and could rig anything I needed to (aside from maybe my compressor) in the event mine fails.
    The SP9100 is a standard Molex connector so you can re-pin and replace circuits as needed. I have mine done with custom gauges and lengths for all the loads so I'm not running 10ga wire for a 3A lamp circuit... it saves a few pounds and thinner wire is easier to run and tuck away.
  5. Apr 19, 2019 at 12:49 PM
    Lunchmeat79
    Kansas
    '18 Off Road
    @velogeek do you have pics of your setup or a build thread? I'm looking at the sdhq setup now but their pics are lacking.
  6. Apr 19, 2019 at 2:48 PM
    Alesimo
    Alesimo Jeeper
    Alec
    Houston, Texas
    2020 Jeep Wrangler JLUD
    I just screwed it into the fuse box. No problem with mounting anything
  7. Apr 22, 2019 at 6:48 AM
    velogeek
    Andrew
    Gilbert, AZ
    2024 4Runner
    Unfortunately, no. I can probably snap a few later if you wanted any pics in particular but I'm not sure I can add much to what's out there at the moment.
    I actually want to re-run some of the cables to the interior because I need a couple more than planned so when I do that, I'll likely tear it all down and do a how-to. It's actually really easy, just tedious as all hell since you have to yank so many dash panels.
  8. Apr 22, 2019 at 9:58 AM
    Lunchmeat79
    Kansas
    '18 Off Road
    @velogeek No worries. I'm just curious where you mount the bus bars on the sdhq plate or if they go elsewhere. It looks like powertrays has a good option also.
  9. Apr 22, 2019 at 10:04 AM
    velogeek
    Andrew
    Gilbert, AZ
    2024 4Runner
    There's probably enough room to run one on an auto but it's not going to be an ideal setup and it will likely interfere with the clutch reservoir on the MT - it's clearly intended you just splice your loads straight into the leads and since the voltage regulation is handled solid state (e.g. no fuses required) it's simpler to do that IMO.
  10. Apr 22, 2019 at 10:08 AM
    Lunchmeat79
    Kansas
    '18 Off Road
    @velogeek Gotcha! I think the power trays is the setup for me, I don't trust my splicing abilitites all that much. Thanks for all the info!
