Spongy Brake Pedal ?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by randyjaco, Jan 15, 2014.
  1. Jan 15, 2014 at 4:57 PM
    randyjaco
    randyjaco [OP] Member
    Randy
    Friendswood, TX
    07 PreRunner
    I replaced the front pads on my 2007 Taco today. I noticed on testing the brakes that they worked fine but they felt spongy. As a comparison I went to the wife's Prius. They were worse. Back in the old days if one pumped the brake pedal and held it (if the brakes were good) the pedal would stop mid travel and hold like a rock. Both my truck and the Prius , if I hold the brake down, eventually the pedal will go to the floor. Is this common for newer vehicles?
    I tried bleeding the brakes and it didn't seem to make a difference. I couldn't find any air in the lines and I don't see any leaks. What's up?
    Randy
  2. Jan 15, 2014 at 5:02 PM
    Styx586
    Styx586 Well-Known Member
    Terrance
    Lake Elsinore, Ca
    2001 TRD Off-road Prerunner V6
    Icons, Konig Countersteers, BFG A/T's
    If your pedal creeps to the floor you could have a bad seal in your master cylinder... But I find it hard to believe that it would happen to both the Prius and taco at the same time. How did u bleed the brakes?
  3. Jan 15, 2014 at 5:14 PM
    ajw1986
    ajw1986 Well-Known Member
    Andrew
    Pitt Meadows, B.C.
    06 Money Pit
    x2
    When i replaced my front brakes and rotors, i removed my calipers to paint them. I had to bleed the shit out of my brakes, i made a topic here and asked if i needed to do the front or backs first, they said the backs then the fronts. With the assistance of my buddy we got it done but it took awhile. My truck did the same thing, it sounds like you need to bleed them better. 3 pumps and hold, repeat till whoever is under there sees a solid stream of fluid coming out
  4. Jan 15, 2014 at 9:42 PM
    Styx586
    Terrance
    Lake Elsinore, Ca
    Yea if you bled your brakes properly you should have a nice firm pedal... If your doing it by yourself you need a vacuum bleeder or pressure bleeder. I think the easiest way is with a friend. Make sure the person holding the pedal doesn't let up until you have fully closed off the bleeder screw. Start at the wheel furthest from the master cylinder and work towards the one closest. I.e. Rear passenger side, rear driver, front passenger, front driver. And like ^^^he said keep going until you see no more air in the line.
  5. Jan 16, 2014 at 6:41 AM
    randyjaco
    Randy
    Friendswood, TX
    07 PreRunner
    I did it the old fashion way, having someone pump the brakes and hold while I let the fluid out from each wheel. I didn't see or hear any air in the line.
    The Prius has never had any brake work done.
    As I said before, I am not seeing any evidence of leakage anywhere on the system. I am also amazed that I would get air in the system by doing a pad change. At that point I had never touched the hydraulic system? The air must have been there from the get go.
    Randy
  6. Jan 16, 2014 at 6:46 AM
    PB65stang
    PB65stang Well-Known Member
    Patrick
    Kansas City
    2006 Infiniti M35x
    People talk about the Tacoma brake pedal being soft quite a bit, do you think it's possible you're just more in tune to what it felt like, since you just did a brake job? My truck requires more effort on the pedal to stop than some of my previous cars, and it's been a common theme for all our Toyotas. Maybe you really don't have a problem at all?
    Just doing a pad change shouldn't require a bleeding of the brakes, you're right.
  7. Jan 16, 2014 at 8:14 AM
    03is300ztk
    03is300ztk Well-Known Member
    Zach
    Somewhere in the hills NC
    07 Tacoma 4X4
    Grillcraft, with front and rear bumper/bed in the works.
    I did the front and rears 2 weeks ago, pad was horribly soft. Bled the brakes doing the circle around method.
    Right Front, Right Rear, Left Rear, Left Front. REPEAT. I was also doing this to get old fluid out.
    Brake fluid absorbs water and degrades over time thats why pedal feels soft even with new pads. Just bleed bleed bleed.
    I did this and my soft pedal went to a good solid firm pedal!!!!!
  8. Jan 16, 2014 at 3:43 PM
    randyjaco
    Randy
    Friendswood, TX
    07 PreRunner
    Thanks for all the responses guys. I will keep bleeding. The air or whatever must be further up the lines.
    Now I am concerned about the Prius :eek:
    Randy
  9. Jan 16, 2014 at 4:04 PM
    DoorDing
    DoorDing Intentionally obtuse
    Bodie, CA
    2017 RC Off-Road 3.5WD
    yes
    VW used to recommend changing brake fluid every two years, and running 500ml through each wheel cylinder in the specified sequence. Instead of making two passes at bleeding, I'd recommend one circuit, with 500ml per cylinder. It's possible that some air is trapped in the ABS pump or some other spot that requires more fluid to fully remove it from the system, and doing less will only move the air around the system instead of removing it.
    Also, is there a specific process in the factory service manual for bleeding the ABS pump? Some vehicles require activating the pump to completely purge old fluid and/or air from the pump. I don't have access to the FSM, but it may be worth checking before another round of bleeding.
  10. Jan 23, 2014 at 6:42 AM
    FishaRnekEd
    FishaRnekEd Well-Known Member
    New Orleans, LA
    none
    Hydraulic fluid is not supposed to compress
    If it is broken down, discolored, absorbed moisture or other contaminants, then it will compress, and not push on the pistons as hard as new fluid would
    higher temperatures will aslo cause the fluid to compress. the back of the bottle of fluid will have a dry boiling point and a humid/contaminated boiling point. not all dot 4's have the same temps
    Just stop and go traffic, or one hard stop from high speed will cause the fluid temperature to spike almost immediately.
  11. Feb 27, 2014 at 8:29 PM
    stumblestacks
    stumblestacks Well-Known Member
    North lake Tahoe
    Beat up 98taco 3.4L limited xtracab TRD
    Finally blew the motor at 230,000, sprung for a Jasper with 100,000/3 year warranty. The birdpig has a new set of wings! OME heavy load lift kit, Dakar leafs w/AAL, frame mounted energy suspension 4.5" bumpstops, 882 coils, nitrocharger sport shocks, trail gear sliders, addicted offroad front bumper, KC 130w daylighters, Warn M8000, 31" BFG KM2's, custom dents and Nevada pinstripes.
    I had the exact same problem for the last six months. Tried everything to no avail. Finally figured it out today (with some help) after it happened getting off the freeway and I almost blew through a busy intersection, it will get worse. For details see my post in "recommendations for mods to tow with a gen 1 taco" hope that answers some questions.
  12. Feb 28, 2014 at 4:19 AM
    moondeath
    moondeath Winter is Coming
    Pa, Carlisle
    2013 TRD Sport DCLB 4x4
    5100 @ 1.75", 1.5" Icon Progressive 3 leaf, Procomp Wheels, Grill Thin Lip (Custom Car Grills Mod), Access Tonneau Cover, Pop & Lock Tailgate Electronic Lock PL8521
    The only way air could get into the brake lines while changing is if you had the reservior open and it was low, then you pumped the brake and it ran out of fluid. Otherwise, there isn't anywhere else for air to get into the hydraulic system.
    The pedal should not go to the floor. Typically, when you push the caliper pistons in to make room for the new pads, the pedal will push further down until the piston meets the new brake pads. Once you've pumped it a few times it should be nice and firm.
  13. Feb 28, 2014 at 4:58 AM
    2013TacoLTD
    2013TacoLTD Well-Known Member
    Dennis
    Mckinney, TX
    13 Tacoma Limited V6 4X2
    Radio On Mod, Complete new stereo with 10" subs, Truxedo bed cover, GT-MAT through doors and rear cab.
    My wife has a 2013 Camry Hybrid and I HATE the brakes. The car uses regenerative braking (Like the Prius) and it just works differently than traditional brakes. I never drove the car in the test drive since it would be my wife's car, but I never would have bought it because of the brakes.
    They are not so much squishy, it just seems to require much more foot effort to stop the car and sometimes it feels like they won't engage (especially when I need them fast).
  14. Feb 28, 2014 at 9:47 AM
    03is300ztk
    Zach
    07 Tacoma 4X4
    He said he bleed the brakes. That process in itself can allow air in.
  15. Feb 28, 2014 at 9:52 AM
    moondeath
    Pa, Carlisle
    He said he tried bleeding them after the fact. My original point however, is changing your brakes will not cause air to get into the line.
  16. Feb 28, 2014 at 10:18 AM
    03is300ztk
    Zach
    07 Tacoma 4X4
    Correct(but you quoted a post about bleeding) but it seems that he has an issue beyond just the pad change so no need to hang up on it. Like was said before could be a seal because it's a slow creep to the floor. It doesn't just bottom out fro first press.
    OP any update?
  17. Mar 1, 2014 at 5:36 AM
    randyjaco
    Randy
    Friendswood, TX
    07 PreRunner
    I haven't done anything else to it. I didn't want to risk screwing up the skid control system. It seems to stop properly and hasn't gotten any worse. It just isn't a rock hard break pedal.
    Randy
  18. Mar 1, 2014 at 5:56 AM
    moondeath
    Pa, Carlisle
    So when the truck is running, while not moving, and you apply steady pressure to the pedal, does it go to the floor or just feel 'squishy'?
  19. Mar 1, 2014 at 6:35 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Are you saying..... your brakes were NOT spongy before you changed the pads?
    Who changed the pads? Did anyone disconnect the brake lines when changing the pads?
    If this truck is NEW to you.... and you're just not used to how the Toyota brakes feel, this could be normal.
    My trucks brakes are 'soft' (I'll call them soft) compared to my Husbands Acura. Every time I drive his MDX and I apply the brakes, I just about send myself thru the windshield. His brakes are 'touchy and every little input is strong almost immediate.
    Having this 'soft' nature - isn't necessarily a bad thing. My husbands rotors were warped after about 3 years. In all the Toyota's I've ever owned (4?), I've never had rotors that warped.
  20. Mar 1, 2014 at 6:41 AM
    03is300ztk
    Zach
    07 Tacoma 4X4
    Wrong. Not all toyotas are soft pedal feeling.
    And please go back through and real all comments before asking pretty much every question that's already been asked.
