Spongy Brake Pedal
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Punkie'sTaco, Dec 22, 2020.
  1. Dec 22, 2020 at 5:23 PM
    Punkie'sTaco
    Punkie'sTaco [OP] Member
    Eddie
    2013 Blue Tacoma TSS
    Ok so i replaced front and rear brakes last night. But now I my brakes pedal goes to the floor. I never lost any fluid and my reservoir is full. It looks good and clear. I did pump the pedal before i started it.
    Was there some kind of trick I should have done before starting it up? Or do I need to bleed them?
  2. Dec 22, 2020 at 5:27 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Do you have a vacuum booster or the hydraulic one?
  3. Dec 22, 2020 at 5:33 PM
    Punkie'sTaco
    Eddie
    I really don't know. It's a 2013 4.0l
    Truly this is the first time doing anything with this truck. It's been such a great truck that I haven't had to touch it.
  4. Dec 22, 2020 at 5:45 PM
    Hunter gatherer
    Hunter gatherer Well-Known Member
    Andy
    Lillooet B.C.
    13DC4X4BaseModel
    Your rear brakes are more than likely out of adjustment. With you back tires off the ground there should be a slight resistance when you spin them backwards.
  5. Dec 22, 2020 at 5:51 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Vacuum boosted looks like this.
    Hydraulic boosted looks like this.
    verynearlypure likes this.
  6. Dec 22, 2020 at 5:53 PM
    Punkie'sTaco
    Eddie
    I have tried to back up a few times to see if they would set. It had got dark and cold on me so i had given up at that point. lol. I will pull the wheels back off and try to readjust them.
  7. Dec 22, 2020 at 5:55 PM
    Punkie'sTaco
    Eddie
    OK Dm93 they are vacuum.
  8. Dec 22, 2020 at 5:57 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    That is a possibility, you want them just dragging on the drum slightly. A good test to check them is to set your parking brake and see how far it travels, if it goes all the way down they are probably too loose.
    Punkie'sTaco[OP] likes this.
  9. Dec 22, 2020 at 5:59 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Ok then I'm betting rear brakes aren't adjusted up correctly.
  10. Dec 22, 2020 at 6:05 PM
    Punkie'sTaco
    Eddie
    Ok thanks. I will try it out tomorrow.
  11. Dec 23, 2020 at 3:32 AM
    Raylo
    Raylo Well-Known Member
    MD, USA
    2023 Tundra SR5 OffRoad; (2009 Tacoma - sold)
    All stock, except for audio and convenience add-ons
    Tacoma drums don't self adjust backing up. They adjust with parking brake use. But if they are really far out you need to do it manually first.
  12. Dec 23, 2020 at 9:46 AM
    LilTexan22
    LilTexan22 Well-Known Member
    2017 Tacoma
    Maybe you just need to bleed the brakes properly. Just youtube it
  13. Dec 23, 2020 at 10:00 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Do this to properly adjust the rear brakes:
    Adjustment Hole:
    deanosaurus likes this.
  14. Dec 23, 2020 at 10:02 AM
    Jimmyh
    SC
    2012 Prerunner SR5
    Hopefully you didn't pop out a wheel cylinder piston from the excessive movement.
    I find it odd replacing the rear brakes on a 2013 so soon. How many miles?
  15. Dec 23, 2020 at 10:06 AM
    Raylo
    MD, USA
    What is a "rear drum gasket"??
    Edit: Ok I found this by a poster who was equally puzzled by this as I am. I have never seen this before... even though I have had my drums off to inspect them.
    factory oem drums have a gasket? | Tacoma World
  16. Dec 23, 2020 at 10:14 AM
    Jimmyh
    SC
    2012 Prerunner SR5
    It is just a piece of paper that goes between the drum and the axle. I've never installed one.... It keeps the axle from rusting onto the drum.
  17. Dec 23, 2020 at 10:18 AM
    Raylo
    MD, USA
    I usually just put a schmear of anti-seize there. Maybe next time I'll replace the gaskets.
  18. Dec 23, 2020 at 10:28 AM
    Lester Lugnut
    Lester Lugnut Well-Known Member
    N of Mex-S of Canada-E of LA-W of NC
    '15 Tacoma PreRunner V6 SR5 Auto
  19. Dec 23, 2020 at 10:42 AM
    tak1313
    tak1313 Well-Known Member
    2013 Base 2WD
    Assuming the brakes weren't "opened" (some people crack the bleeders to make squeezing the caliper pistons back easier), I would think it's as others have said - the rears aren't properly adjusted.
    As Raylo stated, the drums adjust by use of the parking brake. If the shoes are adjusted too loose, it takes a LOT of parking brake activations to adequately move the shoes. I read somewhere that it took a guy about 50 activations before the shoes moved enough because the guy was too lazy to just take the drums off and adjust them properly.
  20. Dec 23, 2020 at 11:17 AM
    Punkie'sTaco
    Eddie
    Thanks everyone for the help. Problem has been solved! The self adjusters needed to go out more. She stops like a brand new truck.
    And to answer your question Jimmyh, It has 140k miles on it. I only changed them because i could here them. I have done some heavy pulling with it the last 2 years.
    Raylo and Jimmyh like this.
