Spongy brakes & brake clunking
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Ghost62, Oct 19, 2021.
  1. Oct 19, 2021 at 12:27 PM
    Ghost62
    Ghost62 [OP] New Member
    Patrick
    2006 Toyota tacoma
    3” body lift
    Hello to all !
    I have a 2006 Tacoma, had a spongy peddle and brake clunking - this is what I did to repair both condition’s -
    Replaced front rotors and pads with the better brand, not the cheap off shore “crap” that you can get. I also noticed when I pulled the rubber cups off the rear wheel cylinders, it started dripping brake fluid. So I replaced rear wheel cylinders, rear shoes, and a “NEW” rear Combe kit (new rear spring kit). If you leave the “old” spring kit on new rear shoes, this will cause rear shoes to move “excessively” inside the drum, causing a clunking noise when letting off the brake peddle. You can also make sure that rear emergency brake cables aren’t rusted through the backing plate. This in my case solved both issues !
    HansLanda likes this.
  2. Oct 19, 2021 at 12:39 PM
    tcjacado
    tcjacado Well-Known Member
    Welcome to TW
