Sport or OR for towing
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Ocean82, Mar 5, 2016.
  1. Mar 5, 2016 at 6:43 AM
    Ocean82
    Ocean82 [OP] Member
    I've lurked this forum long enough to realize that I'll get flak for just about anything posted so.....
    Blah, blah, get a full size, blah blah get a diesel.
    Now that that's out of the way....
    I understand the OR has a larger rear differential and a softer suspension than the Sport. All other things being equal, this would make it seem the OR is better for towing. I don't mean that the OR would pull harder or anything but that the larger diff would handle the abuse better and the softer suspension handles the trailer sway better.
    Thoughts?
  2. Mar 5, 2016 at 6:47 AM
    DustStorm4x4
    DustStorm4x4 BBC 2020
    U S A
    04 Jeep LJ
    Get the OffRoad. Not cause it'll handle towing any better than the sport, but just because it comes with a bunch of extra goodies.
  3. Mar 5, 2016 at 6:48 AM
    oldtoyotaguy
    oldtoyotaguy Well-Known Member
    Peter
    Ontario, Canada
    2018 4 Runner ORP
    Stock but with a Warn 10s winch Used to be a lightly modded Tacoma
    I tow with a sport, and it works great.
  4. Mar 5, 2016 at 6:52 AM
    MarX
    MarX Hotdogs, spam and skittles.
    Mark
    NE Kansas
    2013 DCLB Tacoma TRD sorta Sport 4X4, 2009 Tundra SR5 workhorse
    RETRAX bed cover, Tailgate lock, TRD exhaust. 887's, LR UCA'S, Bilstein 5100's and Deavers AAL.
    Yep bought my sport specifically for towing and for the long bed. You'll be fine with either.
    Tbell18 likes this.
  5. Mar 5, 2016 at 6:52 AM
    Ocean82
    Ocean82 [OP] Member
    I have no doubts the Sport would fair just as well day to day as the OR. I'm just speaking long term wear and tear. It would seem a larger diff would lend itself better to the extra load.
  6. Mar 5, 2016 at 7:13 AM
    Lawfarin
    Lawfarin Who me?
    Beetle Juice
    NY
    2024 GMC Sierra
    I don't know but their has been contradicting reports of the larger gear in the diff. Some say it's actually not larger but they are measuring a plate or something, and others are claiming it's slightly larger. What exactly are you towing?
  7. Mar 5, 2016 at 7:20 AM
    Ocean82
    Ocean82 [OP] Member
    17ft center console
  8. Mar 5, 2016 at 7:23 AM
    colinb17
    colinb17 If at first you don't succeed, don't try skydiving
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    Build thread in sig... 4-link long travel
    you are backwards. the sport has the stronger differential. there is an internal truss in the sport diff that the offroad does not have space for due to the locker. this truss prevents the ring and pinion from un-meshing under heavier loads, slowing wear, and reducing chances of shearing teeth off of the ring gear.
    edit: the above info is true for 2nd gens. didn't see this was 3rd gens. could very well be identical axles between the two generations, but I couldn't verify that.
  9. Mar 5, 2016 at 7:27 AM
    3dBdown
    3dBdown Well-Known Member
    2016 DCLB BBP 4x4 Sport
    I don't think there would be any substantial difference except ride quality. Durability should be the same. I can see arguments both for and against a softer/stiffer suspension. I would lean toward stiffer being better.
  10. Mar 5, 2016 at 7:29 AM
    Tmill
    Tmill Well-Known Member
    Tyler
    Florida Panhandle
    07 Sport Black DCLB
    A longer truck will handle the sway better. The sport has a 6' bed option that I don't believe the OR has.
  11. Mar 5, 2016 at 7:31 AM
    rawdog
    rawdog Well-Known Member
    Kelowna B.C.
    2016 TRD Sport Upgrade PKG DCSB
    Both come with a 6 foot bed option but the sport will come on the longer frame (in canada) the longer the truck, the better for towing
  12. Mar 5, 2016 at 7:33 AM
    Ocean82
    Ocean82 [OP] Member
    I have no interest in the long bed. Right now, I'm towing the boat in my 2006 Xterra. You want to talk about short wheelbase......
  13. Mar 5, 2016 at 7:34 AM
    rawdog
    Kelowna B.C.
    Then I think they would both be good options.. a stiffer ride is better for towing, but realistically, if you wanted that you could just throw some new coils in there and an AAL, that way you get the locker and stuff too
  14. Mar 5, 2016 at 7:36 AM
    jwctaco
    jwctaco Retired, going slow in the fast lane
    Jim
    SW Michigan
    23’ T4R
    Welcome to TW, I hope you got the info you needed.
  15. Mar 5, 2016 at 7:48 AM
    daddy_o
    daddy_o Well-Known Member
    Bossier City, La
    2018 TRD Sport, Inferno, w/tech package
    Factory Blackout package, Soft roll up bed cover, Cheap seat covers, Front and rear dash cam, AVS in channel vent visors
    They have towing capacities that have been tested. Stay within those ranges and the sport will do just fine. It really comes down to what features/looks you want.
  16. Mar 5, 2016 at 9:04 AM
    02Duck
    02Duck manuals make it better
    2018 4WD TRD Off Road 6MT
    TRD Exhaust, Mobtown bolt on sliders and aluminum tailgate reinforcement, Reverse lights changed to yellow turn signals, LED pods added for reverse, ADD W1 oil catch can, Total Chaos bed reinforcement, rear diff breather to taillight mod, 12" combo led bars behind lower grill wired to high beams, Toyota led bed light kit, 400 watt anytime mod, SSO slimeline front bumper.
    Look at the manual transmission. It has lower gears and for obvious reasons won't "hunt" when pulling a load. Both are better for towing. Also with a manual you have a lot less to worry about with overheating issues.
    RedBeard1 likes this.
  17. Mar 5, 2016 at 10:06 AM
    MarX
    Mark
    NE Kansas
    Personally I would go for a 2nd gen for the time being until the kinks are worked out in the 3rd gens.
  18. Mar 5, 2016 at 10:18 AM
    Sbpark
    Sbpark Well-Known Member
    2017 Subaru Outback 2.5i Limited
    Deciding between the TRD OR and TRD Sport as far as which will tow better is pretty much splitting hairs. I mean really, what the heck are you going to be towing, and will it really make THAT much of a difference?! Really??!!
    I think people just get too caught up in looking at specs and start losing their sense of practicality and reality nowadays.
    You'd probably be better off asking which color truck tows better!
  19. Mar 5, 2016 at 10:20 AM
    Ocean82
    Ocean82 [OP] Member
    I'm not buying until the 2017 models are out.
    Thanks for the info. I'm leaning towards DCSB Sport 4x4 manual. Sport looks better, iMO with painted fenders and rear bumper. I think crawl control is gimmicky and the locker is uneccesary for me. Plus if I ever wanted one it's an easy add.
    daddy_o likes this.
  20. Mar 5, 2016 at 10:24 AM
    Sbpark
    Bite your tongue! All the OR owners are going to feel inadequate and will feel the need to shame you for wanting an Sport and justify why they went with the OR! Trust me, as a Sport owner, anytime you mention owning a Sport the OR owners just cannot resist coming out of the woodwork to trash your choice, even though 99% of them will probably never take their OR on anything more than a graded dirt road!
    (I personally love my '16 Sport!)
    James_Bond, SpaceTaco and Herniator like this.
