sport vs off road axles
Discussion in '2nd Gen. Tacomas (2005-2015)' started by wildcats, Jul 16, 2013.
  1. Jul 16, 2013 at 8:15 PM
    wildcats
    wildcats [OP] Well-Known Member
    13 DCSB Sport
    Looking at getting my first Tacoma and was wondering people's opinions on how much stronger the 8.4'' rear end is versus the 8". Have there been any problems with the trd off road axles. It seems that most really built up Tacoma's on this site are either sports or sr5's. Does anyone run 35's on the 8"?
    I'm not sure how much off roading I would be doing but it seems like a sport with arb is a much better setup than the e-locker, but I'm not sure if it's worth the hassle. Any help would be appreciated. Thanks
  2. Jul 16, 2013 at 8:27 PM
    benbacher
    benbacher Purveyor of Fun Vendor
    Anchorage, AK
    '10 Tacoma 4x4 LBDC SR5 TRD Sport
    Too many to list now.
    Sport with Arb is superior to the e-locker yes. That's why I got a sport. :)
  3. Jul 16, 2013 at 9:16 PM
    maxamillion2345
    maxamillion2345 Make Nevada Great Again, build the wall
    Max
    Nevada
    80 series LC
    Tons and 40s
    Do. Bit of searching and youll turn up reading material for days
  4. Jul 16, 2013 at 9:21 PM
    PMK
    PMK Well-Known Member
    Florida
    10 DCLB TRD Sport
    White, debadged, Mudflaps removed, ICON 2.5 in front, 2.0 in rear, all 4 corners have reservoirs, Spidertrax wheel spacers all around, BAMF bolt on sliders, Avid lightbar, oem transmission cooler converted to power steering cooler, aftermarket transmission cooler eliminating all oem transmission cooler stuff, remote mounted spin on transmission fluid filter TrueTrac rear differential, rear diff housing vented and filtered into left side bed box, URD MAF calibrator, Volant intake scoop into oem airbox, second filter removed, airbox internals smoothed, blended and polished throttle body, NST intake manifold spacer, Wet Okolee set covers, WeatherTech Digital Fit mats, inexpensive JVC single DIN, Scangage, AVS Stepshield door sill protectors
    Yes I agree, however are you running oem Toyota ring and pinion? The photos of failures I have seen indicated the oem gear is weak under high loads.
    The bearing support truss on the 8.4 seems to beef up the carrier bearing supports, but still it seems the weak ring gear and fewer bolts is a problem.
    PK
  5. Jul 16, 2013 at 9:37 PM
    BradyT88
    BradyT88 ┌∩┐(◣_◢)┌∩┐
    Somewhere Offroad
    Mostly Stock '05
    8.4 is stronger. A number of people have blown up the factory ring and pinion on the 8". Although it's pretty rare once someone regears so possibly the factory gears are the real weak link.
  6. Jul 16, 2013 at 9:39 PM
    DoorDing
    DoorDing Intentionally obtuse
    Bodie, CA
    2017 RC Off-Road 3.5WD
    yes
    I'll plant the mandatory A-TRAC derp seedling here.
  7. Jul 16, 2013 at 9:47 PM
    BradyT88
    Somewhere Offroad
    Mostly Stock '05
    Because A-trac makes my offroad so much more capable:rolleyes:
  8. Jul 16, 2013 at 10:07 PM
    Raceline08
    Raceline08 Well-Known Member
    Brett
    Santa Rosa, ca
    Silver 08 DBC SB 4x4 TRD Offroad
    front Billies, 885x coils, taco lean spacer, TC UCA'S, Magnaflow 22" OME Dakars, Billy 110 rear's, B.A.M.F CMC, custom made E-locker guard
    ^ ha, funny.
    Brett
  9. Jul 16, 2013 at 10:09 PM
    MGMTacolover55
    MGMTacolover55 Well-Known Member
    Orygun
    2013 MGM Taco TRD Off Road
    floor Mats
    The axles are fine I mean I have the off road and it does pretty well but its your choice
  10. Jul 16, 2013 at 10:24 PM
    Raceline08
    Brett
    Santa Rosa, ca
    Ya a Taco on Ton's.:D
    Brett
  11. Jul 16, 2013 at 10:26 PM
    BMOC
    BMOC Well-Known Member
    Paden
    Phoenix, AZ
    i got it for the hood scoopz
  12. Jul 16, 2013 at 10:28 PM
    maxamillion2345
    Max
    Nevada
    80 series LC
    Tons and 40s
    I blew up a stock side gear?
    running nitro gears
    Suppose ARB would have fixed that issue though.
  13. Jul 16, 2013 at 10:34 PM
    ForeRunner
    ForeRunner Scotch before noon. Moderator
    Drunken Sailor
    Somewhere between Maine and Florida
    2016 Subaru WRX STI Limited (no wing)
    Extra PSI
    Anything with an ARB is superior to stock. What I've seen and experienced the TRD Offroad is better than the TRD Sport stock, got the money sure drop an air locker in there.
    All in all, I'd pit my 4Runner up against your locked Sport.
  14. Jul 17, 2013 at 12:58 AM
    DoorDing
    Bodie, CA
    yes
    I see it sprouted.
    The OP is still shopping. No need for anyone to go DK over A-TRAC, but it's worth mentioning if wildcats is really going to take the truck offroad and isn't sure they want to go ARB.
  15. Jul 17, 2013 at 3:45 AM
    Dragons Taco
    Dragons Taco Well-Known Member
    Derek
    Cary/Raleigh NC
    06 Black TRD-S 4WD 4D 6SPD and MINE!
    Can ya spell Tonneau
    I like that the factory Sport saves one tire during a burnout. Nice feature.
  16. Jul 17, 2013 at 9:33 AM
    wildcats
    13 DCSB Sport
    Thanks for the replies. This message board has awesome support. I've done plenty of reading, just looking for a direct comparison between the two. A couple of you who have replied have pretty sweat rigs that are off road models so I probably shouldn't worry about it too much.
  17. Jul 17, 2013 at 9:47 AM
    85GT 79FJ40
    85GT 79FJ40 Well-Known Member
    Ken
    New Hampshire
    05 SR5 Double Cab 4X4
    How common is a LSD in a non-sport? I just bought another 05 a few weeks ago and it has a LSD in it and it's an SR5. Didn't know it when I bought it but I was pretty psyched when I was underneath it a few days later and saw the tag. Jacked it up and sure enough it's a limited slip.
    As for durability of an 8" I would assume the 8" TRD Off Road 3rd member is very similar to the original 8" they have used since the late 70's. I know a lot of guys who have swapped in domestic V8's in older trucks and beat the crap out of them. Only one broke a diff and it had aftermarket 5.29 gears in it so it was weaker than stock anyhow.
  18. Jul 17, 2013 at 10:17 AM
    medic2230
    medic2230 Ditch Doctor
    Murph
    Bama! Roll Tide
    2011 Taco 4x4 DCLB
    20% Tint, OME 3"complete lift with Dakar's, Light Racing UCA's, 285/75/16 Nitto Terra Grapplers, 10 HP TW sticker, Ultraguage, B.A.M.F. Rock Sliders, MedicFab Bed Rack, Relentless front bumper
    My 11 SR5 came with LSD also.
  19. Jul 17, 2013 at 3:54 PM
    DoorDing
    Bodie, CA
    yes
    Are you sure? More likely, it came with "Auto LSD" (ABS derived LSDish functionality) on an open differential.
  20. Jul 17, 2013 at 4:00 PM
    BradyT88
    Somewhere Offroad
    Mostly Stock '05
    Good point I let that slip by me... haha All 2009+ Tacoma have Electronic-LSD, it is part of the traction control system. Only the 2005-2008's have a mechanical LSD from the factory. I thought it was only the sports though.
