Sport vs Off road OEM shocks
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Bradg93, Nov 25, 2019.
  1. Nov 25, 2019 at 6:24 PM
    Bradg93
    Bradg93 [OP] Well-Known Member
    Port Hope, Ontario, Canada
    2020 TRD Sport DCLB Cement Grey
    What is the difference in ride quality between the TRD sport and Off road shocks?
    Unfortunately in Canada we aren’t able to get an Off Road in DCLB, so I went with the sport. You can feel literally every (even small) bump in the road. I assume the OR shocks are better although I have heard there is a sacrifice in handling.
    Anyone have experience with this? Would switching shocks to OR shocks provide a more comfortable ride. Or is it just the nature of leaf springs? It’s not that bad but I wouldn’t mind the ride being smoother.
    TeecoTaco likes this.
  2. Nov 25, 2019 at 6:27 PM
    calebc
    calebc Well-Known Member
    Sports are a more plush ride. It's a truck though so plush is relative.
    Bradg93[OP] likes this.
  3. Nov 25, 2019 at 6:30 PM
    Doggman
    Doggman Well-Known Member
    Alabama
    2017 TRD OR MT
    Ftfy
    TnTuna, Boghog1, Cudgel and 5 others like this.
  4. Nov 25, 2019 at 6:31 PM
    calebc
    Maybe something has changed with the 3rd gens but on all my other Tacomas, my sports have always been more plush than my offroads.
  5. Nov 25, 2019 at 6:35 PM
    TeecoTaco
    TeecoTaco Liberty Biberty
    SW Ontario
    16 Taco DCSB TRD Sport 6MT
    Modified the level of gas in the tank
    So, here's my deal...found the sport OEM stiff in rear unless I had a couple hundy pounds in the box then was nicer. Swapped out the Hitachi factory rears with 5100s and put on OR rims (sport 17, OR 16) for a lil more sidewall. Left front stock...it mellowed out the rear as if I had a couple hundy pounds in the box, but didn't. Still have the front handling characteristics which I like and taming the rear. Works real well for me.
    4100 OR stock rears would be a waste of time I think...just go up a bit to 5100 rear only. Cheap and easy swap in the driveway.
  6. Nov 25, 2019 at 6:35 PM
    Doggman
    Alabama
    2017 TRD OR MT
    What do you mean by plush? Soft, right? OR is and has always been much softer than sport.
    Neither is more plush than the other when using it's actual definition: "richly luxurious and expensive" lol
    MoneyMan55 and shakerhood like this.
  7. Nov 25, 2019 at 6:48 PM
    St0rm-Tr00per
    St0rm-Tr00per Well-Known Member
    SoCal
    2018 TRD OR 4X4 DCLB - Super White
    “Semi-Pro”/“PrOff-Road”
    When I was looking to purchase my Tacoma I was sure I wanted the sport until I test drove the OR and sport back to back ... I ended up with the OR! The OR is a noticeably softer ride.
    The OR also has 16” wheels with 1” more Sidewall than the 17’s on the sport.
    I now have the pro’s Fox shocks on my OR and they pretty noticeably better than the stock shocks.
    shakerhood likes this.
  8. Nov 25, 2019 at 6:52 PM
    Bradg93
    Already bought 16” rims for winter tires so I could have more sidewall, not as much of an improvement as I had hoped.
    I know it’s a truck so it’s not going to be “plush” but I have heard OR’s are softer. Wish I could have gotten it in DCLB.
    My best bet is to switch shocks I assume.
  9. Nov 25, 2019 at 6:57 PM
    St0rm-Tr00per
    SoCal
    The OR also has a 28mm swaybar vs the Sport’s 30mm. It’s a shame That you can’t get the OR in a DCLB in Canada ... what is Toyota thinking?
  10. Nov 25, 2019 at 7:44 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    Sport has stiffer springs, shocks, and lower profile tires so the ride is firm.
  11. Jan 11, 2020 at 4:52 PM
    TeecoTaco
    SW Ontario
    It did tame the rear end ride. The 16 OR wheels and tires (little more sidewall) also did a smidgen. But ya, the 5100 rear only on the sport, I cannot recommend enough. Bang for the buck it's a winner...put 300 lbs of stuff in your sport hitachi's and go for a ride, that will give you an idea of the difference it will be with the 5100s
    GreyBaldTaco and shakerhood like this.
  12. Jan 11, 2020 at 5:16 PM
    Hoff
    Hoff Well-Known Member
    I’m carrying a bit of weight now like maybe 150 lbs and it feels like I need more.
  13. Jan 11, 2020 at 5:19 PM
    ChrisK7UND
    ChrisK7UND Well-Known Member
    Colorado
    2017 Tacoma TRD Sport Double-Cab
    LED Interior Bulbs, Hondo Garage Phone Mount, Tacoma Bed Mat
    I swapped my complete Sport suspension with Off Road suspension. It is WAY softer now and I love it. The TRD Sport is “Sport Tuned” which means the handling and cornering is more responsive. However the ride is harsher. Just leaving the driveway is noticeably softer with the off road shocks/springs.
    Hoff likes this.
  14. Jan 11, 2020 at 5:21 PM
    CrippledHo
    CrippledHo I'm calling about your car's extended warranty
    Eric
    Biggest Little Dumpster
    2016 DCSB Diet Coke
    Dents and a rattle can
    could add a shell. I keep mine on most of the year unless I'm moving larger things. Definitely helped the ride, but I didn't find it too stiff to begin with. Permanent solution would be shocks/springs
  15. Jan 11, 2020 at 5:26 PM
    Hoff
    I don’t hate the way my sport rides After all it’s a truck.
    CrippledHo likes this.
  16. Jan 11, 2020 at 5:27 PM
    TeecoTaco
    SW Ontario
    5100s...it's a cheap transition.
  17. Jan 11, 2020 at 5:29 PM
    HawkShot99
    HawkShot99 Well-Known Member
    Kingston, NY
    13' Silver DCLB TRD Sport - Sold
    What was your previous ride for comparison?
  18. Jan 11, 2020 at 5:29 PM
    JWestie
    JWestie Well-Known Member
    2019 Tacoma DCLB-OR Mag gray
    The OR is softer with the sacrifice of poorer cornering and increased brake dive. I compared to the SR5 which has similar suspension as Sport.
  19. Jan 11, 2020 at 5:32 PM
    Hercanstein
    Hercanstein Well-Known Member
    Bryan
    State of Jefferson
    1999 2.7 SR5 4x4 5MT XC, 2020 3.5 TRD Sport 4x4 6MT AC
    ('99) Offset Aluminium Wheels, 31" BFG All-Terrains, Bushwacker Fender Flares, Window and Hood Wind Deflectors ('20) Stock
    Just got back from a trip up to Roseburg on I-5 in our sport and I LOVE the way she handles on the highway. Hardly any roll and very smooth and responsive. I will probably want a softer ride when off roading, but this ride is the wife's daily driver so will spend a lot of it's time on the road. It definitely is WAY stiffer than my '99 SR5, but that ride does need new shocks. Rides like a friggin' boat right now. : )B
    BSFord and CrippledHo like this.
  20. Jan 11, 2020 at 5:36 PM
    I just had bilstein 5100 installed, front at 4th clip. Rear with a 1inch block. The front rides the same as stock in my opinion, but the rear is softer with the 5100
