Sport wheel lug nuts
Discussion in '2nd Gen. Tacomas (2005-2015)' started by p411mtaco, Apr 13, 2019.
  1. Apr 13, 2019 at 1:20 PM
    p411mtaco
    p411mtaco [OP] Member
    Just swapped out my 16” steel wheels and tires on my 2015 Tacoma for a set of 17” Sport wheels from a 2017 Tacoma. Getting an alignment and tire shop says steel wheel lugs are not the correct lug nuts for the sport wheels. Any ideas on where to get the correct lug nuts as well as torque specs?
  2. Apr 13, 2019 at 1:23 PM
    maxtherat
    maxtherat Well-Known Member
    Inland Northwest
    2001 Dodge Ram 2500, 1993 Jeep Wrangler
    All the usual diesel truck mods- fuel system upgrade, programmer, CAI, intake manifold, 60MM stealth turbo
    Yes that’s correct and absolutely not correct nuts for that wheel. eBay and Amazon all day long along with local parts stores.
    whatstcp likes this.
  3. Apr 13, 2019 at 1:25 PM
    p411mtaco
    Thank you. Do you know the size for the correct lug nuts?
  4. Apr 13, 2019 at 1:56 PM
    Muddinfun
    Muddinfun Well-Known Member
    You're lucky the wheels didn't fall off.
  5. Apr 13, 2019 at 2:06 PM
    p411mtaco
    I am just swapping wheels now. Same amount of thread coverage. Said ok to drive til I swap lugs tomorrow
  6. Apr 13, 2019 at 2:14 PM
    Taco505
    Taco505 Well-Known Member
    Alex
    New Mexico
    2011 4cyl 4x4 5 speed
    OME 884's/90021, MD Dakar/Nitrocharger.
    I also switched out my steelies for some 3rd gen trd rims and you’re correct you need different lugs.
    These are the kind you need.
    24 Pc Toyota Tacoma Tundra Fj Cruiser Oem Mag Seat Lug Nuts 12x1.5 Chrome 1.45" Tall https://www.amazon.com/dp/B01I5SDIAC/ref=cm_sw_r_cp_api_i_odLSCbRQK6VTC
    Edit: I just realized that link on Amazon says they aren’t available anymore. Anyway here is a link to the part on the Toyota parts website.
    https://parts.toyota.com/p/Toyota__/NUT---HUB-FOR-AXLE/62981552/9008494002.html
  7. Apr 13, 2019 at 2:26 PM
    Muddinfun
    :eek: The tire shop told you it was OK to run tapered seat lug nuts on a mag lug nut style wheel? You better find out who their liability insurance company is.
  8. Apr 13, 2019 at 3:40 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    @Muddinfun 's right.
    You can use shank style (square with a washer) nuts on a steel rim, but you cannot safely use tapered nuts on a alloy rim.
    The tapered edge will fuck up the aluminum and mush it around.
    Put the different wheels side by side, look at the surface where the lug-nut seats, look closely at both types of lug-nuts and you'll see..
    Tigerian, Bebop and Muddinfun like this.
  9. Apr 13, 2019 at 5:43 PM
    Bebop
    Bebop Old fashion cowboy
    Nick
    Castle rock Colorado
    2012 Toyota Tacoma baja
    6inch lift sitting on bilstein coilovers. Lexus is300 studs in front to keep stock wheels, general grabber red letters, nfab front bumper.
    Steel wheels are tapered where the lug nuts go to get a snug fit, aluminum Toyota wheels have a wide hole for a shanked lug nut. Do not use the wrong lug nuts with these wheels, impossible to torque down correctly. The lugs will chew through the aluminum when trying to torque even to the 76-89 foot pounds it calls for.
    b_r_o[QUOTED] likes this.
  10. Apr 14, 2019 at 3:25 AM
    muddog321
    muddog321 Well-Known Member
    FL
    09 Tacoma DCSB 4wd TRD Off-Road w/e-locker Pyrite Mica
    TW 1-piece driveshaft with 1310 u-joints All Pro and Budbuilt skid plates OME Dakar rear springs 3" with 5100 5100 front set at 1.75" (3rd groove up) with stock springs Falken Wildpeak A/T3W 265/70R16 2018 TRD Offroad wheels 16x7J with +25mm offset Powerstop rotors with Z36 pads and rebuilt with OEM caliper kit Complete rebuilt rear brakes drums, shoes, springs, wheel cylinders Rebuilt rear diff with Yukon 3.73 ring/pinion Denso 130A rebuilt alternator AGM 24F Battery New OEM idlers and tensioner assembly New AC compressor New PS hose and flushed Walker SS Quiet Flow muffler Denso Iridium long life plugs #3421 (SK20HR11) OEM coolant, cap, and thermostat NAPA CV axles and new seals ECGS bushing Rhino front guard Shortened mud flaps Alziria Black Tail Lights Nilight Headlights X-Bull Traction Boards Maaco full single stage paint job 2023 Nat CV to Knuckle seals 710573 New SKF wheel bearings/hubs BR930978 New Moog stabilizer links K80946 & 948 New MOOG K80819 Suspension Stabilizer Bar Bushing 28mm New Dorman rear wheel bearings using complete axles 926-139 & 140 New Radiator support bushings Dorman 924-267 (front body mounts)
    Just put these on my stock TRD 16" alloys. Stock lugs were all messed up as they were steel with chrome caps. New are black and look great even with the silver alloys at $23.99 next day. All the auto stores sell them at slightly higher prices - if 4x4 remember to get 24 set not a 20 set. Most list as 13/16" but in reality are 21mm so stock size tools work. I use a deep 21mm socket 6 sided.
    https://www.amazon.com/gp/product/B079PNRKK1/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&psc=1
    SCITOO 24PCS Black Lug Nuts for 13/16" Drive Close End, 1.45" Tall, 12x1.5 Thread, Fits for Toyota 4Runner/ Avalon/Avanza/Camry/Celica/Corolla/FJ Cruiser/Highlander/Land Cruiser/Matrix 1997-2016
  11. Apr 14, 2019 at 3:52 AM
    Armkb
    Armkb Well-Known Member
    Hudson Valley, New York
    09 TRD Sport DCLB
    Bilstein 5100, OME 885X, LR UCA, ARB/EL095R, ES LCA Rack & Sway Bar Bushings, Yellow Wire Mod, ABS Switch, TPMS Mod, Scanguage, Toyota Bed Mat, WeatherTech Floor Liners, Extang Trifecta Cover, Fumoto Drain Valve
    Are these from Amazon anodized or painted lug nuts?
  12. Apr 14, 2019 at 2:38 PM
    p411mtaco
    Thanks guys. All set. No damage and got correct lug nuts
  13. Apr 15, 2019 at 6:44 AM
    p411mtaco
    Having a hell of a time with keeping the TPMS light off now
  14. Apr 15, 2019 at 7:47 AM
    Muddinfun
    Where did the TPMS sensors come from and who programmed your truck to recognize them?
  15. Apr 15, 2019 at 7:48 AM
    p411mtaco
    Came off a 17. Did the relearn steps. Came back on today
  16. Apr 15, 2019 at 7:53 AM
    Muddinfun
    3rd gen sensors won't work with a 2nd gen truck. Also, even when you get new to you sensors, somebody has to program your truck by plugging into the OBD2 connector.
  17. Apr 15, 2019 at 7:54 AM
    p411mtaco
    Ugggghhh
