SPR TCO - Gilmorec61's Supercharged 2013 DCSB Build/Adventure Thread!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by HappyGilmore, Jan 9, 2019.
  1. Mar 1, 2021 at 8:26 AM
    #101
    uurx
    uurx Well-Known Member
    long island, new york
    '12 t|x pro
    have you ever changed your rad support bushings?
    Is your drivers side fender flare still rubbing on the bumper? if so, check those bushings,
    https://www.tacomaworld.com/threads/polyurethane-radiator-support-mounts-cab-also.361346/
    i had the same issue with the aluminum all pro bumper on my 2012, swapping those bushings gained me just enough space to stop the contact between bumper and flare
  2. Mar 1, 2021 at 8:29 AM
    #102
    HappyGilmore
    HappyGilmore [OP] LambTek Innovations
    Huntsville, AL
    2013 SC’d DCSB TRD OR 4x4 | 2012 Lexus IS-F
    Yes
    I have not but I probably need to. Fenders are probably coming off soon anyways to clear the tires.... thanks for the link, ill check em out!
    uurx[QUOTED] likes this.
  3. Mar 1, 2021 at 8:35 AM
    #103
    uurx
    '12 t|x pro
    i got my bumper used as well, but i know at that time all-pro was shipping these out with a thick plate that was to be used/sandwiched in the drivers side rad support to gain clearance on that side, the rubbing on the drivers side flare was an issue for a lot of people, I believe it was mostly blamed on the taco lean
  4. Mar 1, 2021 at 8:57 AM
    #104
    HappyGilmore
    Huntsville, AL
    Yes
    Interesting stuff, had not a clue about that.... Cool to know, thanks for the info!
