"spray in" bed liner?
Discussion in 'Detailing' started by Tacodriver, Oct 11, 2013.
  1. Oct 11, 2013 at 5:40 PM
    Tacodriver
    Tacodriver [OP] Active Member
    AZ
    2011 prerunner
    deflapped debadged snow filter delete bed rail delete K&N drop in
    Has anyone removed the plastic bed liner and had the spray in installed? Im thinking about doing it myself.
  2. Oct 11, 2013 at 5:44 PM
    XXXX
    XXXX Well-Known Member
    sKiP
    05 Prius
    If you have a 05+ Tacoma its w composite bed. If you have a older truck, then yes people use bedliner to line beds :)
  3. Oct 11, 2013 at 5:49 PM
    ST3VE
    ST3VE IG: @fishsohard
    MD --> SC
    Tint, car seat, baby wipes
    TicoTrd in the Maryland thread bought a 2nd gen with a lined bed. I seen it the other day in person. Honestly it doesn't look too bad.
  4. Oct 11, 2013 at 7:34 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    You can have the composite bed sprayed, but you can not remove it.
  5. Oct 11, 2013 at 7:41 PM
    User Name01
    User Name01 Little boy from FairyTale Land
    Bolbi Stroganovsky
    Wherever the next wind project is
    TRD Sport Barcelona Red Metallic Dbl Cab 4x4
    I tried to get mine lined but was told by line-x and rhino lining that they could not warranty the job because of the composite bed............ I did it on my own
  6. Oct 12, 2013 at 7:55 PM
    Tacodriver
    AZ
    2011 prerunner
    So.... I noticed the bed is plastic haha. I just don't like all the scratches the plastic gets over time and how some freight slides around. I guess I will just have to get the rubber mat for the bed.
  7. Oct 20, 2013 at 11:36 AM
    Dingo556
    Dingo556 Dingo556
    Erik
    Aynor South Carolina
    WAR WAGON
    K&N Cold air intake, Custom AllPro bedliner with bodycoating, code lights and siren, toolbox with bedrails,
    I worked as a spray in bedliner installer for 2 years. I will tell you now that the Herculiner do-it-yourself roll on stuff is pure crap. Even the stuff we used (all-pro linings) is great stuff but not the best. what everyone knows as "rhino lining" is a rubber/glue composite material and may dry rot after 10-15 years. It takes 15 minutes to set, 1 week before putting any light/softer materials into the bed and a full 30 days before dropping any heavy sharp loads into it (pallets, engines etc) I would recommend going with LINE-X. Its a plastic material that is cured that day and can immediately begin to take abuse. I Sprayed my bed and most of the outside of my truck because I worked there and only had to pay our cost for the materials. It adds a negligible amount of weight( 1 case=6 tubes= 10lbs.) DO NOT have it done by anyone other than a reputable shop. If it isnt prepped right then it will peel, tear and be an endless problem trying to fix it. Spend the extra $, have it done right.
    Itll add value and durability to the truck. [​IMG]
