Spray paint overspray
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Holland83, Jul 9, 2017.
  1. Jul 9, 2017 at 10:03 PM
    Breakfast Taco
    Breakfast Taco Well-Known Member
    SW CT
    2002 4x4 5spd 2.7L
    GOOP hand cleaner (in the laundry soap aisle).
    Clay bar.
    Both should do the trick. I'll try soap before harsh chemicals every day.
  2. Jul 9, 2017 at 11:41 PM
    James_Bond
    James_Bond Well-Known Member
    Southern California
    '16 TRD Sport DCLB
    All stock
  3. Jul 10, 2017 at 3:50 AM
    kgilly
    kgilly Well-Known Member
    Kurt
    Pennsylvania
    2016 DCSB SR5 4x4
    Bed cover and Mud flaps, OEM Audio, Super Bump stops, Sumo Springs, Bed Stiffeners, Stryker hood shocks
    hand buffing paste, then wax...simple, not sure I would use thinner on a new paint job?, just saying...
  4. Jul 10, 2017 at 5:57 AM
    Hank Heel
    Hank Heel Well-Known Member
    WA
    Acetone
  5. Jul 10, 2017 at 6:00 AM
    LJGIbbs
    LJGIbbs Well-Known Member
    Independence Missouri
    2017 TRD PRO Cement 6MT
    none yet/none planned! It's perfect!
    Any advice you are getting I would advise to research before you try.
    Rowdymoon likes this.
  6. Jul 10, 2017 at 6:56 AM
    rsimi72
    rsimi72 Well-Known Member
    PNW
    2020 Tacoma SR5 Access Cab
    Last time I was at the detailing shop, they were removing spray paint from a car that was vandalized. If you are uncomfortable, you could let the pros handle it. Good luck.
    SeanDub likes this.
  7. Jul 10, 2017 at 7:08 AM
    tguil
    tguil Well-Known Member
    Nebraska
    2018 Double Cab TRD Sport 4X4 AT
    Very good advice. You are not even sure that it is overspray. Why take the chance on messing up a nice truck?
    rsimi72[QUOTED] likes this.
  8. Jul 10, 2017 at 7:14 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    I pulled this from some randome website
  9. Jul 10, 2017 at 7:22 AM
    ian408
    ian408 Well-Known Member
    Ian
    Santa Clara, CA
    09 Tacoma
    How you solve the problem depends a lot on what kind of paint it is and how long it's been there. I'm not a detailer but I've had my car covered in over-spray before. If you can get it off immediately, it will do the least amount of damage. If it sits on the car any length of time, it will penetrate the car's paint and be much harder to get off without needing to be re-sprayed with clear.
    Personally, I'd take it to someone who is familiar with removing over spray.
    SeanDub likes this.
  10. Jul 10, 2017 at 7:44 AM
    rsimi72
    PNW
    I actually had approximately 10-12 paint specks on the passenger side of my truck when it was delivered from the factory. Both white and red specks. (silver truck) My clay bar removed some and I used bug/tar remover cream for the stubborn specks. Even with the cream it took a bit of rubbing. No damage to the clear coat but if I had a large area of overspray to remove, I'd take it to a detail or body shop.
  11. Jul 10, 2017 at 11:46 AM
    Quicksand17
    Quicksand17 Well-Known Member
    Rob
    Belardi
    NONE
    Gas should take it off but u will need to apply a good coat of wax after cuz it takes off the old wax as well.
  12. Jul 10, 2017 at 2:23 PM
    Scotty Dosent Know
    Scotty Dosent Know Well-Known Member
    2017 Tacoma DCSB
    Theres some pretty horrible advise in here LOL
    I would start with a clay bar which will probably remove it. If that does not work I would use a buffer with a medium cut compound
    ABA180 likes this.
  13. Jul 10, 2017 at 2:25 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    o_O And what makes you any more qualified?o_O
  14. Jul 10, 2017 at 2:53 PM
    Scotty Dosent Know
    2017 Tacoma DCSB
    Someone in here recommended Oven Cleaner......Im not using anything on my paint that can cause chemical burns. Using common sense one would think you would start with the least aggressive option first and work your way up. That and I have been detailing cars as a side business since 1996, feel free to do what you like, its not my car.
    RocTaco likes this.
  15. Jul 10, 2017 at 2:59 PM
    #35
    Pirhett
    Pirhett Instagram @pirhett_ship
    Rhett
    San Diego
    2014 TRD Sport 4x4 DCLB MGM
    Stock...
    have the same problem from respraying my sliders and bedracks.
    clay bar and a buffing wheel with compound didnt work.
    So which is best? Thinner doesnt seem smart...
  16. Jul 10, 2017 at 3:23 PM
    #36
    Scotty Dosent Know
    2017 Tacoma DCSB
    For those that go on forums which is probably everyone reading, this autogeekonline.net is an invaluable source for auto detailing. There are probably 100 threads on there about over spray removal from paint.
  17. Jul 10, 2017 at 10:08 PM
    #37
    djmr1972
    djmr1972 Well-Known Member
    N. Central Mass.
    18 Cement TRD Off Road Long Bed
    Visors, Roof rack, decals in and out, bug deflector, tonneau cover, bed extender
    Good for you, the cleaner worked for me as recommended by a detail place to avoid damaging clearcoat. trusted it enough on my 5 month old,$11,000 paint job on the nova so would trust it on my tacoma.
    The question was any suggestions so I gave my 2 cents. dont like it? MOVE ON.
  18. Jul 11, 2017 at 10:39 AM
    #38
    Scotty Dosent Know
    2017 Tacoma DCSB
    You gave your 2 cents I gave mine, take your own advise and get over it.
    :thumbsup:
    http://napavalleyregister.com/news/...cle_98763187-bd31-5fe8-a45f-1ac2b774026f.html
  19. Jul 11, 2017 at 6:34 PM
    #39
    Brian4125
    Brian4125 Active Member
    Brian
    Stuart, Florida
    17' Mgm 4x4 or
