Spraying frame with oil
Discussion in '1st Gen. Tacomas (1995-2004)' started by Yfz 450, Nov 23, 2014.
  1. Nov 23, 2014 at 9:40 AM
    Yfz 450
    Yfz 450 [OP] Well-Known Member
    Rockland ny
    tacoma 4x4
    This weekend I am planning to finish the last stage of my winter prep for my truck. I am planning on picking up one of those pump up garden sprayers to spray in to the frame. What would be a good oil product thin enough to spray through something like that. It would def. have to be a super low viscosity or even mixed with somethig to make it thinner. What are you guys using?
  2. Nov 23, 2014 at 9:50 AM
    Moco
    Moco Well-Known Member
    Eric
    NoVA
    96 Regular Cab 4x4 5spd
    I just use used motor oil from my oil changes.
  3. Nov 23, 2014 at 9:55 AM
    kirkofwimbo
    kirkofwimbo Well-Known Member
    Clayton
    Wimberley, TX
    ‘21 Tundra SR 4x4
    FluidFilm
  4. Nov 23, 2014 at 9:59 AM
    TacoGlenn
    TacoGlenn Nobody Makes a Monkey Outta Me!
    PNW
    '13 MGMAC 2.7L SR5
    Hellwig 1251's, Leer 122, Kahtec smart stop delay flashing 3rd brake light, de-chromed, de-badged, WeatherTech mats, WeatherTech side window deflectors,
    This topic has been discussed extensively by TW members: many swear by Fluid Film, also Amsoil MPH.
    http://www.tacomaworld.com/forum/technical-chat/229505-application-fluid-film.html
    http://www.tacomaworld.com/forum/2nd-gen-tacomas/310580-tacoma-rust-prevention-experiment.html
    also type in "rust prevention" in search function and you'll see many more.
    cheers
  5. Nov 23, 2014 at 10:20 AM
    Yfz 450
    Rockland ny
    tacoma 4x4
    Ok I was reading about fluid film I just didn't know about the viscosity of it. I can simply put used motor oil on a rag and wipe most of the outside of the frame but I just wanted to get an idea of what was thin enough to run through one of those sprayers and do a good job coating the inside of the frame without clogging the tip of the sprayer. I didn't want to buy something to open it to oinly find out it is to thick to be sprayed. Will motor oils or fluid film spray nicely?
  6. Nov 24, 2014 at 7:40 AM
    Yfz 450
    Rockland ny
    tacoma 4x4
    Has anyone used diesel of inside the frame that seems like it would spray well?
  7. Nov 24, 2014 at 11:46 AM
    bry838
    bry838 Well-Known Member
    oregon
    '00 tacoma 2.7 4x4 reg cab 5speed x's 2. '01 T4R 3.4 5 speed
    You can buy fluid film in an rattle can can or in bulk form to use a spay gun for application...so yes fluid film will spray nicely.
  8. Nov 24, 2014 at 11:50 AM
    phs2dent
    phs2dent Member
    '04 Tacoma 4x4
    You can mix diesel (or paint thinner?) with used motor oil or gear oil to spray on your frame. Otherwise fluid film has a pretty good reputation and should come ready to spray.
  9. Nov 24, 2014 at 4:20 PM
    2004TacomaSR5
    2004TacomaSR5 Nemesis Prime
    Jon
    Montana
    2004 Tacoma DCSB & 1980 Toyota Pickup 4WD
    Tacoma is stock and staying that way, Pickup is TBA as of now.
    I've never even heard of this, but wouldn't spraying motor oil on your frame just attract more dirt? Haven't seen or heard about fluid film so I have no idea what that's all about.
  10. Nov 24, 2014 at 4:26 PM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    You change your engine oil for a reason if you'er going to pollute at least buy new oil it won't be full of water gasoline and corrosives.
  11. Nov 24, 2014 at 4:31 PM
    maineah
    Tim
    Maine
    4X4 SR5 V6 6spd
    FF is non toxic and legal (motor oil etc. is not) it will not spray with a bug sprayer any high pressure system will spray it like a Wagner electric paint sprayer.
