Spring 3RZ Rebuild
Discussion in '1st Gen. Tacomas (1995-2004)' started by LdogH, Feb 21, 2024.
  1. Feb 21, 2024 at 7:56 AM
    LdogH
    LdogH [OP] Flirting with Death since 04’
    Landen
    Show Low, Az
    1999 Tacoma PreRunner, 2.7 4-Banger
    Shock Towers, Camburg long travel kit,
    Hello everybody, this spring/summer I will be doing a rebuild on my 3RZ (2.7L) I was curious if anybody has any tips or would like me to post an in depth process on how I did mine, I’m planning on building for it around 5-10Psi of boost. I will also be keeping track of cost and time. I don’t think the full rebuild is going to be much more than $3000 but I could be entirely wrong. I won’t be adding the boost yet, not sure whether I want to go turbo or supercharger. Any tips or pointer will be appreciated. Thanks!
    Clamber247 and Speedytech7 like this.
  2. Feb 21, 2024 at 8:04 AM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Not much you have to do in terms of building a 3RZ to handle 10psi... they will do that out of the box just fine with decent tuning. I've had two 3RZ trucks and one had the supercharger... speaking from experience here, skip it, go turbo. The SC is expensive for what it offers and underwhelming. It also has no provision for an intercooler of any kind so it makes less power as it gets hotter and is more prone to detonation. KO Racing sells a decent turbo kit, from there you can pick your own intercooler, piping, and tuning solution. If you're for sure going to build the engine, cheap and effective mods are the updated Toyota MLS head gasket, ARP head studs, and ARP rod bolts.
    LdogH[OP] likes this.
  3. Feb 21, 2024 at 8:33 AM
    LdogH
    Landen
    Show Low, Az
    Hell yeah thank you, only reason I said I want to build it for boost is because once I get the power I might want to add on to it but I heavily appreciate that thanks!
  4. Feb 21, 2024 at 1:57 PM
    Clamber247
    Clamber247 2004 Tacoma
    Boise, ID
    I'd be interested in a pretty detailed doc of the process. Been thinking of doing the same to my 04.
    billybop90 and grizzlypath like this.
  5. Feb 21, 2024 at 5:54 PM
    billybop90
    billybop90 Well-Known Member
    Bill
    Black Hills SD
    1996 Taco, 2.7, 4WD, 5 spd
    Pics!! Lots of Pics!! Like to see the progression and final product. Great project.
