Spring Clamp Warranty Risk
Discussion in 'Suspension' started by Jammy, Jul 12, 2022.
  1. Jul 21, 2022 at 1:58 PM
    Jammy
    Jammy [OP] Active Member
  2. Jul 21, 2022 at 2:03 PM
    Jammy
    Yes, I heard the digits got switched, but if it used to be 52, 73 doesn't make any more sense than 37. Also, you would think Toyota would be correcting the factory output asap.
  3. Jul 21, 2022 at 2:07 PM
    saint277
    saint277 Vigilo Confido
    Toyota uses newton meters not foot pounds thats my guess as to why it hasn't been corrected. 52 is not the right spec for a third gens stock springs, what ever after market or spec for a previous gen truck does not apply. torque them to 73 if they are not already.
  4. Jul 21, 2022 at 2:13 PM
    AllTacosFloat
    AllTacosFloat If yours sank you’re entitled to compensation
    Boston ish
    Has lockers and a skewp
    Like others have said, 73ftlbs. 37 was a typo.
  5. Jul 21, 2022 at 2:21 PM
    Jammy
    52 foot pounds is about equal to 70.5 newton meters. 37 ft/lbs is about 50 nm. 73 ft/lbs is about is about 99 nm. Where does the 73 ft/lbs recommendation originate?
  6. Jul 21, 2022 at 2:22 PM
    Jammy
    So the factory is building product according to a typo?
  7. Jul 21, 2022 at 2:25 PM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    TBQH, when I installed my Dakars I might been following the torque specs in the OME instructions. The kit came with new u-bolts.
  8. Jul 21, 2022 at 2:27 PM
    saint277
    The factory doesn't use foot pounds, they use the newton meter spec. I don't have access to the service manual at the moment but when I did my springs I converted the newton meters to foot pounds and got 73ish.
  9. Jul 21, 2022 at 2:31 PM
    AllTacosFloat
    Boston ish
    No clue but for the size of the bolt if its grade 5 it should be about 65 and grade 8 is like 90. Mine are larger so they get one more ugga dugga.
  10. Jul 21, 2022 at 2:32 PM
    OffroadToy
    OffroadToy old, forgetful, and decomposing
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    Just checked my Chilton 05-09 repair manual... it says 37 Ft lbs/50Nm. Another misprint? :confused:
    Maybe the oem bolts are 7/16 grade 5?
  11. Jul 21, 2022 at 2:49 PM
    Jammy
    So it just gets weirder. 05-09 is older than the 52 ft/lbs spec. from the posted early 3rd gen giant manual/pages :tumbleweed:
  12. Jul 21, 2022 at 2:53 PM
    saint277
    the early second gens came with a thinner 3 leaf pack that was TSB out. That could be an accurate figure for those early packs.
  13. Jul 21, 2022 at 3:18 PM
    Jammy
    OK, my mind is officially blown:boom:
  14. Jul 21, 2022 at 3:24 PM
    OffroadToy
  15. Jul 21, 2022 at 3:34 PM
    #35
    Shortman5
    Shortman5 Well-Known Member
    Supercharged TRD
    TRD S/C, ADS coilovers.
    Get some thick grease that won’t thin out under heat and grease your slip joint. That’s the only thing that actually cured the “axel wrap” I was feeling.
  16. Jul 21, 2022 at 8:22 PM
    #36
    Jammy
    Spring, Summer, Fall, Winter, Spring, Summer all provide the same vibration, and I think the 3rd gen 2WD trucks have no grease fittings.
  17. Jul 28, 2022 at 1:29 PM
    #37
    Jammy
    Turns out the techinfo site gives 52 ft/lbs, but you will get different numbers from different dealerships. Good luck if you're trying to find the u-bolt strength, diameter, and pitch. Oddly, the torque spec in the T-SB-0124-20 bulletin says 44 ft/lbs. In any case, the vibration remains, but oddly seems to be reduced by letting go of the steering wheel.
