spring compression
Discussion in '2nd Gen. Tacomas (2005-2015)' started by outlawtacoma, Nov 21, 2009.
  1. Nov 21, 2009 at 9:55 AM
    outlawtacoma
    outlawtacoma [OP] Well-Known Member
    W. TN
    2018 T4R MGM TRDOR Premium Daddy Wagon
    Do I need to compress my springs when I install my 5100's? Or can I do it without the compressor with the same results?
  2. Nov 21, 2009 at 10:01 AM
    JDMcQ
    JDMcQ Well-Known Member
    The Mushroom Capital of the World
    2006 Toyota 4Runner SR5 V8
    You will need to compress the springs to remove and install them on the struts.
  3. Nov 21, 2009 at 10:03 AM
    outlawtacoma
    W. TN
    when I installed my leveling kit, I was able to get them off and on, without compressing them. I was just curious to know if compressing them would make it easier.
  4. Nov 21, 2009 at 10:05 AM
    Brunes
    Brunes abides.
    Rotorhead
    Did the leveling kit go on top of the top plate or in the springs??
    Cause I have a hard time believing you'll get the spring properly seated and tightened down without a compressor....
  5. Nov 21, 2009 at 10:06 AM
    outlawtacoma
    W. TN
    on top. I will try the compressor. is it a pita?
  6. Nov 21, 2009 at 10:09 AM
    Brunes
    Brunes abides.
    Rotorhead
    On top of the plate means you didn't change the springs at all. In order for you to take the springs off the current shocks and then install them on the 5100s-You will have to compress them, take the top plate off, move the springs to the new shocks, put the top plate on the new shocks, and then release the springs from the compressor.
    Depends on what kind of compressor...I used a wall mounted one and it took about 20 mins for both sides....then I dropped the struts again to add a bushing and that took about 20 mins start to finish both sides...
  7. Nov 21, 2009 at 10:11 AM
    outlawtacoma
    W. TN
    ok, I gotcha now. Is it a pain in the ass and can it be done without an impact wrench
  8. Nov 21, 2009 at 10:14 AM
    Brunes
    Brunes abides.
    Rotorhead
    A wall mounted spring compressor doesn't need an impact wrench...Non mounted ones are only supposed to be used with hand tools. I used all hand tools for the removal and install (cept the impact for the tires)...I had a frame lift too...
  9. Nov 21, 2009 at 10:15 AM
    outlawtacoma
    W. TN
    alright, I will be going by autozone to get their loaner compressor and tie rod separator this afternoon.
  10. Nov 21, 2009 at 10:17 AM
    Brunes
    Brunes abides.
    Rotorhead
    Just be careful with that loaner compressor...They can be a bit questionable if you aren't careful.
    Take your time and you'll be fine.
  11. Nov 21, 2009 at 10:18 AM
    outlawtacoma
    W. TN
    thanks brunes you are tons of help man. I will take my time. I have never used one before. I hope I dont kill myself, I hear they can be quite dangerous
  12. Nov 21, 2009 at 10:20 AM
    rustyshakelford
    rustyshakelford Well-Known Member
    Brett
    Magnolia, TX
    i used the one from autozone the other night when i broke mine. i had to use two c-clamps to get it sucked down enough to do the install. i was doing 5100s with new eibach coils tho. definately dont recommend doing it that way
    brett
  13. Nov 21, 2009 at 10:21 AM
    Brunes
    Brunes abides.
    Rotorhead
    They can be....Go slow you'll be fine dood.
    You are more than welcome- PM or post up if you have any questions while you are working!!
  14. Nov 21, 2009 at 10:24 AM
    outlawtacoma
    W. TN
    well damn, wth I want these installed but it is starting to sound like I need to take em to get it done by someone who knows what to do. I am a cheap ass, and like to do it myself if I can.
  15. Nov 21, 2009 at 10:28 AM
    kjf216
    kjf216 Fitz
    Kyle
    Ridley Park, PA
    2016 Jeep Wrangler Sahara
    Head unit, speakers, LEDs
    i know this is a stupid question but i rented a spring compressors a few days ago and could not figure out how to make it work since we have such small coils on our truck. can anyone explain the trick to this things.
  16. Nov 21, 2009 at 12:57 PM
    yosh2000
    yosh2000 Well-Known Member
    Denver, CO
    '17 Tundra CM 5.7
    dont be scared...i've used the autozone ones over a handful of times and have never had a problem with them. just make sure everything is tightened down and secured properly, go slow and even and you'll be fine.
  17. Nov 21, 2009 at 1:06 PM
    Brunes
    Brunes abides.
    Rotorhead
    It may not fit. There is no trick. They either fit and will compress the springs or they won't and you are risking injury by trying.
    If you can't get the ends properly hooked thru the spring...Try a different compressor or get them done somewhere.
  18. Nov 21, 2009 at 1:34 PM
    ramjm_2000
    ramjm_2000 Well-Known Member
    NoVa (Alexandria VA)
    08 PreRunner SR5 DoubleCab BSP
    5100's Rear TSB Dominator slider/step bars Eclipse AVN 2210 Nav/XM Leather Upgrade TRD Skid Century Royal Sheel Armor Tech Custom Rear Bumper
    If you have a harbor frieght close by they have a pretty cool compressor for $35 bucks.
  19. Nov 21, 2009 at 2:00 PM
    rustyshakelford
    Brett
    Magnolia, TX
    i bought one of those and it is currently sitting in the back of my truck with a spring in it compressed. the bolt bowed and i cannot get it out. i will no longer recommend these to anyone.
    if anyone is interested in one, ill make you a heck of a deal and ill even throw in a stock spring too! :D
    brett
