Spring compressor ADS/King/Fox owners
Discussion in 'Suspension' started by Shortman5, Oct 28, 2017.
  1. Oct 30, 2017 at 3:28 PM
    Shortman5
    Shortman5 [OP] Well-Known Member
    Supercharged TRD
    TRD S/C, ADS coilovers.
  2. Nov 1, 2017 at 10:42 AM
    FinnJ
    FinnJ Well-Known Member
    Finland
    2007 FJ Cruiser 6M/T
    TRD SC, UCON, CNG conversion, RC 6" (lifted 4"/3" air suspension) w/FOX 2.5, 315/70R17 Duratracs, RECARO seats, etc.
  3. Nov 1, 2017 at 11:25 AM
    Shortman5
    Supercharged TRD
    Im going to try this Friday, Im going to use two endless ratchet straps and if it does not work I found a small shop with a spring compressor.
  4. Nov 1, 2017 at 9:21 PM
    GREGSBSPTACOMA
    GREGSBSPTACOMA Well-Known Member
    Greg
    Phoenix,AZ
    4runner
    Just did this tonight edit: but I wouldn’t do it again.
  5. Nov 1, 2017 at 9:32 PM
    Shortman5
    Supercharged TRD
    So when you release the tension on the ratchet does it violently decompress?
    RANGER13 likes this.
  6. Nov 1, 2017 at 9:39 PM
    TACOVRD
    TACOVRD I Identify As A Prius
    TW Addict
    AZ/WA
    2019 T4R ORP - Formerly 2013 DCSB OR Spruce Mica
    Workin' on it....
    Sometimes you can find Brannicks on Craigslist for a decent amount if you keep your eyes open. Seems like a good investment for a couple of hundred bucks to have the safety over the widow maker spring compressors.
  7. Nov 1, 2017 at 9:53 PM
    GREGSBSPTACOMA
    Greg
    Phoenix,AZ
    4runner
    I was putting the spring back on as I was done with my rebuild so I was sucking it down just enough to put the clip back in. I don’t recommend doing it honestly had me pretty worried a strap would slip or ratchet mechanism would break.
  8. Nov 3, 2017 at 11:47 AM
    neonlazer
    neonlazer Mechanically Goofy
    Lafayette, LA
    '23 DCSB 4x4 SR5
    splitbolt[QUOTED] likes this.
  9. Nov 3, 2017 at 1:16 PM
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    Aren't the spring clips interchangeable?
  10. Nov 9, 2017 at 6:44 PM
    neonlazer
    Lafayette, LA
    '23 DCSB 4x4 SR5
    The OTC clamshell is welded with a pin that is supposed to keep the spring in the clip.
  11. Nov 13, 2017 at 7:12 AM
    *TRD*
    *TRD* Well-Known Member
    Carson, Ca
    Springs are very dangerous, I wouldn't recommend any of the ratchet strap methods, or even the cheap harbor freight spring compressors.
    The OTC style spring compressor from Harbor Freight isn't strong enough (I tried and bent two).
    I used to pay a local independent wheel and tire shop $10/shock to take springs off, and $10 to put them on. I recommend going there when they aren't busy, take cash, and tip the guy doing the work. Your non-amputated fingers will thank you.
    Biscuits and MCDavis like this.
  12. Nov 13, 2017 at 8:32 AM
    Shortman5
    Supercharged TRD
    Yeah, I’ve decided to just buy a used branick when it pops up. Might be a long time before a deal pops up.
