Spring compressor
Discussion in 'Suspension' started by Tsenekos, Sep 11, 2009.
  1. Sep 11, 2009 at 5:35 PM
    Tsenekos
    Tsenekos [OP] Well-Known Member
    Greg
    Edmonton, CANADA
    2005 DC 4WD trd offroad
    Toytec 3" lift w coils,1.5 AAL,5100's all around,diff drop kit, axel shims,N-Fab nerf bars,bestop supertop,fog mod, weathertech mats
    So my toytec lift arrived yesterday just have 2 ?'s before I attemp it:confused:
    1) I ordered my kit with the 885's will one of those spring compressors they rent work ok for those its a manual one you crank it with a ratchet???
    2) I want the full 3" lift out of this but could I set my 5100's at the first setting and ditch the top plate spacer good or bad idea???
  2. Sep 11, 2009 at 5:42 PM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    Yes those compressors will work...Just be careful.
    It's not recommended to preload the 885 springs OR use the 5100s above stock setting with lift springs.
  3. Sep 11, 2009 at 5:44 PM
    Tsenekos
    Greg
    Edmonton, CANADA
    Thank you. So i should just use the top plate spacer and forget about my brain fart idea:D
  4. Sep 12, 2009 at 3:26 PM
    Tsenekos
    Greg
    Edmonton, CANADA
    I called the parts place for the rental spring compressor and he asked me "for struts or coils?" I didnt know the answer so I feel like a re tard what should my answer have been guys???
  5. Sep 12, 2009 at 3:28 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Interesting, as the shock/spring assembly on the Tacoma is a Coil Over Strut.
  6. Sep 12, 2009 at 3:31 PM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    I'm not sure what the difference is either to be honest...You want a coil compressor tho...Need to crush down the springs to fit them over the shocks. and Chris is right.
  7. Sep 12, 2009 at 3:47 PM
    SC4333
    SC4333 Well-Known Member
    Grant
    FL
    SOLD - 2016 TRD Off-Road 4x4 DCSB
    You need a spring compressor for a strut. If you tell the guys you need a compressor that will work on a MacPherson strut, you will get the correct compressor.
    Just use your head when using the compressor as it will be under tremendous load when the springs are compressed. Crank on each side a little at a time and you will be alright.
  8. Sep 12, 2009 at 9:16 PM
    Tsenekos
    Greg
    Edmonton, CANADA
    thanks for the help guys I will go for it monday I hope I let you know how it goes
