Spring Fluid Film meet 4/29 - CT, MA, NY, NH
Discussion in 'Detailing' started by surfandturf, Mar 2, 2018.
  1. Apr 10, 2018 at 1:06 PM
    #201
    yellow_bandit
    yellow_bandit Well-Known Member
    MA
    2013 TRD Sport DCSB
    HS 2" Lift Kit
    I figured. I just didn't want to go through the pain of sanding down to bare metal and removing the finish from the area around it to put a coat of spray paint on it. My thinking is, the rust is not bad at all and FF stops rust. As long as I get it FF regularly then no problems should arise with rust. I should have done FF as soon as I got back from FL but it slipped my mind. Plus this $40 deal was not known by me so definitely going to try to make it down the 29th.
  2. Apr 10, 2018 at 1:24 PM
    #202
    Hunter.415
    Hunter.415 Well-Known Member
    Pete
    Western mass
    2012 Tacoma short bed 4x4
    Cooper t/a 3
    Leave it for now, spray with ff. It's not as bad as other frames getting done. If it's big flakes might want to brush it. Not an expert but I think you will be ok after getting it spayed.
    yellow_bandit[QUOTED] likes this.
  3. Apr 11, 2018 at 7:44 AM
    #203
    devnull
    devnull Well-Known Member
    western MA
    2018 Cavalry Blue TRD Pro
    Heck...my truck isn't even 5mo old and I've got some spots starting. Not bad, but annoying.
  4. Apr 16, 2018 at 6:36 AM
    #204
    Cativelense
    Cativelense Well-Known Member
    Nuno
    CT
    2014 DCSB Black 4x4 TRD Sport
    -TRD oil cap -TRD radiator cap -TRD shift knob -2015 Entune system with Nav, -OEM roof rack -Front windows tinted to match back (20%) -BPK Skid Plate -Non clock hazard switch assembly -WeatherTech floor mats -AFE Stage II Pro Dry Intake -AVS Vent Shades -AMP Research bed extender -Horn relocation mod -Bob's Mirror -Redline hood struts -UltraGauge MX 1.3 -Debadged -Reverse LEDs & shifter bezel LED -Black steering wheel controls, black shifter bezel, black AC vent panel -Black gauge cluster rings + black tweeter rings -Morimoto XB LED fog lights -Anzo tail lights -Hilux 4x4 lighted switch -Bed mat -Hondo Garage radio knobs -OKLED 20" light bar mounted on BAMF behind the grill mount -CH4X4 LED light bar switch w/add-a-fuse -nd4spdbh fog light anytime mod (HUGE thanks to @tgriff) -Debadged bed -Secondary air pump filter -Retros (Morimoto Mini H1's and Morimoto Panamera shrouds with dual intensity LED DRL's & 5000k bulbs) -Tailgate Anti-Theft Device by @scleaf -OEM TRD Sport 17" wheels painted black w/Bridgestone Blizzak DM-V1 tires (Winter wheels) -Pro Comp Extreme 17" wheels w/Firestone Destination LE2 tires (Spring/Summer/Fall wheels) -Anzo blacked out third break light -HomerTaco Tacoma Ghost Raptor Insert -Rear diff breather mod (HUGE thanks to @jc11taco89) -Fumoto Valve -LEER 100R -Salex center console and glove box organizers -Power Pop N Lock -Mobtown Tailgate Skin -TRD Pro suspension with HS Progressive AAL (overload leaf in) -ECGS replacement bearing -Dust caps on rear drums to match front -Me-So Customs "The Gasshole" -ACEkraut license plate bracket -mesojdm's 2nd Gen Ultimate LED Dome and Map lights -Seat spacers from olecoot -Bullaculla Trailer Harness Relocation Bracket
    Sadly I am going to be out for the 29th.
    Sister was in town visiting this weekend, and found out that she is having my niece's birthday party that weekend up where she lives (Rochester NY). So we're making the trip for the party.
    Sorry Matt.
  5. Apr 16, 2018 at 6:37 AM
    #205
    yellow_bandit
    MA
    2013 TRD Sport DCSB
    HS 2" Lift Kit
    I was planning on going but work just came up so I'm out. I'll try doing it myself .
  6. Apr 16, 2018 at 8:07 AM
    #206
    surfandturf
    surfandturf [OP] Well-Known Member
    CT
    2014 TRD DCLB
    For anyone that can't make the 29th I could probably pull off a few trucks this sat am. Pm me
    yellow_bandit likes this.
  7. Apr 16, 2018 at 3:42 PM
    #207
    TOMB
    TOMB Well-Known Member
    Tom
    Newington Ct. 06111
    2013 Access cab Sport -super white
    Changed all drain plugs to Dimple Magnetic plugs UNI filter on air pump
    Matt.
    I'm still in
    TOMB
    surfandturf[OP] likes this.
  8. Apr 16, 2018 at 5:31 PM
    #208
    jc11taco89
    jc11taco89 Well-Known Member
    jon
    Naugatuck CT
    2011 Tacoma aclb 4wd
    3 inch toytec 5100 SPC uca's Pelfreybilt front plate bumper with center hoop Pelfreybilt rear plate bumper with swing out B.A.M.F. sliders with kick out Mobtown ifs and trans skid. 33's with rims that are to large.
    I'll be there as well hopefully toting along a dead long beard.
  9. Apr 16, 2018 at 5:44 PM
    #209
    surfandturf
    CT
    2014 TRD DCLB
    I'll put it on the smoker!
  10. Apr 16, 2018 at 6:01 PM
    #210
    surfandturf
    CT
    2014 TRD DCLB
    John and are hitting the woods sat too. Hopefully we see something. Otherwise he'll want me to blast a squirrel
    jc11taco89 and Hunter.415 like this.
  11. Apr 16, 2018 at 9:13 PM
    #211
    jc11taco89
    jon
    Naugatuck CT
    Hahahahaha obviously me and the little guy have more in common than just the name cause I get a little trigger happy myself :thumbsup:
    Hunter.415 likes this.
  12. Apr 17, 2018 at 5:59 AM
    #212
    bucktales
    bucktales *Retired* curmudgeon
    Litchfield County Ct.
    2012 TRD Sport AC / 2014 FJC/ 1972 Rally Nova
    I have 2 weeks of last year's vacation I have to burn up, soooo, 1st 2 weeks of May is Turkey Time for me.:bananadance:
    Hunter.415 and jc11taco89 like this.
  13. Apr 17, 2018 at 6:44 AM
    #213
    Hunter.415
    Pete
    Western mass
    Cooper t/a 3
    I can hunt for the whole month if needed. Not sure if I'm going to go to ct to hunt.
  14. Apr 17, 2018 at 11:57 AM
    #214
    yellow_bandit
    MA
    2013 TRD Sport DCSB
    HS 2" Lift Kit
    I may be able to make it this Saturday. Depends on when I work Saturday. I won't find out until Friday so I'll let you know.
  15. Apr 19, 2018 at 8:16 AM
    #215
    Cid
    Cid ╭∩╮(◣ _ ◢)╭∩╮
    Keith
    Waterbury CT
    2004 Taco 5spd SR5 TRD / 2018 HD FXBB
    ADS Coilover Front, OME Dakars with Nitro's Rear, Relentless Skids, BAMF Sliders, FN Five Star rims, 285/75r16 Falken Wildpeak, Aero Turbine 2525
    We got a guy at work practicing turkey calls for 2 weeks now. SMFH. Hahaha @jc11taco89 getting good
  16. Apr 19, 2018 at 8:56 AM
    #216
    Hunter.415
    Pete
    Western mass
    Cooper t/a 3
    Is he strutting yet, :rofl:
    I broke out the mouth calls a month ago, I use a couple for early for location and break in. will set up a couple more next week. I use 3 and 4 reed calls as my go to calls and will have one or two five reed calls set as well.
    Cid[QUOTED] likes this.
  17. Apr 19, 2018 at 4:25 PM
    #217
    nickonfire700
    nickonfire700 Reg. Cab Nation Member
    Nick
    Rhode Island
    05 Reg Cab SR5 4x4
    Satoshi grill, 3rd Gen TRDOR Bucket Seats, TRD front skid plate, TRD Beadlock Wheels, TRD Exhaust, OEM bed mat, LCE Header, LCE Balance Shaft Delete, ECGS front diff bushing, TRD Sport LSD rear diff, Diode Dynamics SS3 Sport fog lights, Stainless Steel Brake-lines, No A/C with Defrost mod, 2014 OEM Radio, Illuminating 4x4 switch, Various LEDs, UWS Toolbox, Proven Design Products Mudflaps, Bilstein 8112 front Coilovers w/ rear Bilstein 5125's/IronMan lift leaf springs, Archive Garage Hammer Hangers, JBAs HD UCAs, SOS Bolt-On rock sliders, TRD bedside decals, ImMrYo Mirror Bracket, Relocated rear diff breather, 2019 Steering wheel, color matched door handles
    @surfandturf If you don't have to many trucks to do, I would like to get my truck done as well versus just hanging out. Thank you!
  18. Apr 19, 2018 at 4:47 PM
    #218
    surfandturf
    CT
    2014 TRD DCLB
    Plenty of room and time for you...see you then
    nickonfire700[QUOTED] likes this.
  19. Apr 19, 2018 at 7:10 PM
    #219
    nickonfire700
    Nick
    Rhode Island
    05 Reg Cab SR5 4x4
    Perfect, see you guys next Sunday!
  20. Apr 20, 2018 at 10:51 AM
    #220
    yellow_bandit
    MA
    2013 TRD Sport DCSB
    HS 2" Lift Kit
    @surfandturf will you be doing any trucks tomorrow? I won't be able to make it the 29th
