Spring found under passenger seat
Discussion in 'Technical Chat' started by JT1521, Apr 19, 2010.
  1. Apr 19, 2010 at 3:50 PM
    JT1521
    JT1521 [OP] Well-Known Member
    I was recently vaccuming my truck and found this spring underneath the passenger seat. I am not sure exactly where this spring is supposed to go. there is some foam inside the spring which would lead me to believe it goes up under the seat. I examined underneath by runner my fingers along the sides. There is a bunch of springs however the one I found appears bigger than those. I compared the driver seat and the passenger seat with no avail. Any help would be appreciated. Thanks. Here is a picture of the spring. It measures roughly 4" from hook to hook and 1" width.
  2. Apr 19, 2010 at 3:57 PM
    timbo805
    timbo805 Well-Known Member
    SanDiego
    09 tacoma trd sport pre-runner
    dont know but maibe you could check where a piece of foam has ben riped out
  3. Apr 19, 2010 at 3:59 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Welcome to TW! Looks like a spring from under the seat. The foam in it could be a vibration damener. Remove the seat, and see if one is missing.
  4. Apr 19, 2010 at 3:59 PM
    colinb17
    colinb17 If at first you don't succeed, don't try skydiving
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    Build thread in sig... 4-link long travel
    if you go to the dealership, someone in the parts department should be able to pull up an exploded view of your seat. might be able to figure it out that way
  5. Apr 19, 2010 at 4:18 PM
    JT1521
    Ok and how do I remove the seat? LOL
  6. Apr 19, 2010 at 5:17 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    One bolt on each rail. 2 up front, 2 in the rear of the seat. Remove them, and lean the seat back. Disconnect the wireing harness/s and remove the seat.
