Spring info.....
Discussion in 'Technical Chat' started by chris4x4, Feb 3, 2011.
  1. Feb 3, 2011 at 6:21 AM
    chris4x4
    chris4x4 [OP] With sufficient thrust, pigs fly just fine. Moderator
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    I have been getting alot of PM's lately regarding people who contact you guys looking for springs/shocks, and wanting info or wanting to purchase OME springs, to be used with the Bilstien 5100 shocks. Im am hearing that you guys are telling folks that the OME springs will not work with the Bilstien 5100 shocks, and pushing them to buy the Eibach springs. Why? The OME springs work just fine on the 5100 shocks, and not only are many on here running that combo, but I have persoanlly installed, and driven trucks with the OME springs and 5100 shocks. Where are you getting your info?
  2. Feb 3, 2011 at 7:49 AM
    SoTexTacoma
    SoTexTacoma a_causemonaut
    TX Limbo
    '14 TRDOffroad
    '08 fj wheels Cooper 265/75/16
    Been wondering the same thing myself...
    BUMP!
  3. Feb 3, 2011 at 8:08 AM
    ToyTec Lifts
    ToyTec Lifts Toyota Suspension specialist Vendor
    Rocky Mountains
    Toyota's are awesome
    Neither manufacturer recommends it. They will physically work and i have not heard of many problems (other than someone setting the C clip too high). We just cannot really go outside of the manufacturers recommendation. I have no idea if either of the companies would honor their warranty either.
    Thanks
    -Dylan
  4. Feb 3, 2011 at 8:18 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Being as the OME springs are of a lower spring rate than the Eibachs, Warranty shouldnt be an issue for the bilstiens. As the OEM spring, when preloaded to 2.5" lift, is a higher spring rate than the OME spring, that shouldnt be a cause for concern either.
  5. Feb 3, 2011 at 8:33 AM
    ToyTec Lifts
    Rocky Mountains
    The heavier OME coils like the 886 would void the warranty on the 5100s. Bilstein does state these shocks are designed to be used with stock coils, Eibach designed the Toytec/Eibach front coils for stock shocks and the height adjustable 5100, neither Bilstein or Toytec has installed or tested any of the OME front coils on 5100 shocks, so it is hard for us to recommend the two be used together although we do know they will fit, I apologize if anyone was told they will not work together.
    If the 886 OME coil was installed on a 5100 and the shock blew apart Bilstein would not warranty it.
    Caution should be taken with mixing and matching shocks and coils, you can overextend the front 5100s from using too long of a coil that would give too much lift.
  6. Feb 3, 2011 at 9:00 AM
    mach1man001
    mach1man001 eh whatever
    Rob
    Blackstone, MA
    '09 Sport DCLB Met Grey
    Toyota bed mat (1st mod), Toyota all season floor mats, Rear spring TSB, Map light mod, Fog light mod, Putco yellow fog bulbs, Weather Tech window vents, Extra d-rings, Mounted mag light, TRD CAI with AFE pro dry filter, '05 front mud flaps (winter only), 2 set's of wheels/tires, 285/75/16 Hankook MT's, Black Painted 1st Gen TRD wheels (wheeling set) Black powder coated FJ Cruiser with 265/70/17 BFGoodrich KO2's (everyday), painted center of grill & bumper black, Devil horns, OME with 885's + spacers front, OME shocks w/OMD designed rear springs, Front diff drop, Rear trailer plug relocate, ATO IFS skid, Relentless Trans & Transfer skids, BAMF bolt on rock sliders, Relentless tailgate reinforcement, Uniden 75 CB radio, BAMF antenna bracket, TRD exhaust, high lift jack w/ATO mounts. And of course ProEFX Towing Mirrors!
    Chris, which specific OME's are you talking about as there are so many models?
  7. Feb 3, 2011 at 9:01 AM
    08pretaco
    08pretaco Almost there
    Oliver
    az
    2014 Tundra 4x4 CM 5.7L SR5
    AFE pro dry s, Husky X-act Contour
    885, 886 I assume?
  8. Feb 3, 2011 at 9:07 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    884's and the 885's. I dont see the 886's being an issue either, as they are a 650# rate, which is only 30#'s more than the Eibach 620# springs.
  9. Feb 3, 2011 at 9:12 AM
    jhodge83
    jhodge83 They all float down here... Moderator
    SC
    17 XLT Sport
    3rd gen forum caused me to get a Ford
    if bilstein says they are only warrantied for stock shocks, wouldnt the same thing you say about the OME coils voiding the warranty be true about the Eibach?
  10. Feb 3, 2011 at 9:50 AM
    ToyTec Lifts
    Rocky Mountains
    We have not had a problem getting warranty credit on the 5100's unless they are broken, that would be a sign of misuse or abuse.
  11. Feb 3, 2011 at 9:53 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Well....The OME springs wouldnt do any more damage, or add any more stress as opposed to the Eibach springs. IN many cases, they would yeild less tension over the Adjustable 5100's using the 620# Eibach springs.
  12. Feb 3, 2011 at 10:45 AM
    ToyTec Lifts
    Rocky Mountains
    They will physically fit together. However, we had Eibach design the springs for the 5100's and OME did not. As you have seen, OME springs do work on the 5100's but we can not recommend them, because we can not be held liable for someone breaking the shock or spring when neither manufacturer recommended them together.
    Also, spring rate is not everything. The 886's are longer AND a higher spring rate. That means they will be preloaded more and the spring rate will be higher.
  13. Feb 3, 2011 at 10:48 AM
    Khaos
    Khaos Big Member
    Bryant
    Jacksonville, Florida
    2005 Prerunner TRD Off Road
    265/75/16 BFG A/T, 18" Magnaflow, K&N Intake Filter, Ultra-Gauge, Kobalt Toolbox, Metal Tail Light Guards, Cobra 19 and 4ft fiberglass antenna, Plasti dipped Badges/lower valance/rear bumper/grill/bullbar/ac controls, black DIN kit, JVC KD-X40, Wet Suit Seat Covers
    I've always thought it was ok to combine the two, as long as your not trying to gain more than .85 of lift from the 5100s.
  14. Feb 3, 2011 at 11:03 AM
    brutalguyracing
    brutalguyracing BIG DADDY
    F.U> GUYZ
    broken mods
  15. Feb 3, 2011 at 12:11 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    You can use the OME springs on the 5100's. Some folks have set the 5100's at the .85" setting, but its not a good idea.
  16. Feb 3, 2011 at 12:12 PM
    Pugga
    Massachusetts
    '13 Ford F-150 SCREW
    F-150 Mod
    Sounds like they work well enough together but since there's no testing to prove it, both manufacturers are covering their ass (and would probably rather sell you their product).
  17. Feb 5, 2011 at 9:24 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Correct. The OME and EIbach springs are designed essentially the same. Same wire diameter. Ends are the same too. The only difference is the various spring rates, and lengths. In fact, Toytec sells the OME 884 springs for use with stock shocks. They do recomend different shocks for use with the 885's and 886's, but the only difference between the 884's and 885's is 10mm in length. The 886's are made with thicker wire and a higher spring rate. Personally, You shouldnt use any aftermarket spring with the OEM shocks. They arent designed to dampen the higher spring rates. As far as which shock to use, The OME and 5100's are valved the same 255/140, both are speed sensative, but one (OME) is a low pressure twin tube shock, while the 5100's are a high pressure, mono tube shock.
  18. Feb 8, 2011 at 9:12 PM
    judd94
    judd94 Well-Known Member
    Ponchatoula, LA
    17 4Runner TRD Off Road Premium
    Mods in Progress
    this thread couldn't have come at a better time. i'm debating the eibachs or the 883s. they are only 0.1" height difference but i wonder how much different the ride is with both. anybody here have personal experience with both and know which they think is better or if you can really tell diff?
  19. Feb 9, 2011 at 6:42 AM
    Cheeto6182
    Cheeto6182 Cheeto
    Sean G
    Denver, Colorado
    05 Tacoma TRD Offroad DoubleCab
    JBA Headers, Custom Snorkel/Ram-Air Intake, Spal Electric Fan Conversion, TBS lol, Borla Exhaust, ToyTec Coilovers, Old Man Emu Rear Leafs, Bilstein 5100's, Alpine system (type R's), 4.56 Gearing, 285/75/R16, Bead Lock Rims, Bed Carpeting, SoftTopper, Ram Air intake Mod, URD MAF, Dash Dyno, One Piece Drive-Shaft Conversion, Bed Cubby Led Lights, 12,500 Lbs winch, Expediation bed racking system, Hella Lights, Custom front winch bumper
  20. Feb 9, 2011 at 6:47 AM
    malander
    malander Well-Known Member
    max
    01 limited trd 4x4
    deck plate mod,jba cat back,bilstein 5100's,ome 883 springs, Allpro expos, allpro U-bolt flip kit, 10" Bilstien 5150 shocks, custom lower shock mounts
    My 5100s with 883s work perfectly
