Spring rate and preload question
Discussion in 'Suspension' started by splitbolt, Apr 17, 2017.
  1. Apr 17, 2017 at 8:25 PM
    splitbolt
    splitbolt [OP] Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    I'm trying to figure out which springs I want with the 6112s for my 3rd gen. Reportedly, the stock coil is 700 lb.
    Do I understand preload correctly?
    During compression;
    -a 600 lb spring with 7/8" of preload has 525 lbs of pre-load; requiring 1,125 lbs of force to compress the spring the first 1", 1,725 lbs for 2", 2,325 for 3"...
    -a 700 lb spring with 0" of preload would require 700 lbs of force to compress the first 1", 1,400 lbs for 2", 2,100 lbs for 3"...
    -a 650 lb spring with 1/8" of preload would require 731.25 lbs of force to compress the first 1", 1,381.25 for 2", 2,031.25 lbs for 3"...
