Spring rate for 2012+ T/X Baja & TRD Pro?
Discussion in 'Suspension' started by locster, Nov 4, 2014.
  1. Nov 4, 2014 at 1:34 PM
    locster
    locster [OP] Well-Known Member
    Luke
    Orange County, CA
    2014 DCSB 4x4
    Anyone knows the spring rates for those Eibach springs in the front?
  2. Nov 4, 2014 at 8:56 PM
    RKCRUZA
    RKCRUZA Well-Known Member
    Bob
    Placerville, Ca
    2015 TRD Pro in the Garage!
    The Pros do have a softer front spring rate than the Baja's....not sure as to the actual struts themselves (supposedly different valving)...posted up to see if folks with Baja's and pros could post the strut number to see if they are different, but didn't get a response....
  3. Nov 7, 2014 at 10:53 AM
    Wild Crow
    Wild Crow Well-Known Member
    James
    Anywhere is home
    2014 Baja
    I'm sure you are looking for actual production numbers and not part numbers from Toyota.
    On the spring, all I can find is the part number right now. I may have to dig around a bit to find a stamping on the spring.
    On the strut I can see the part number
    and a stamped number
  4. Nov 8, 2014 at 12:59 PM
    RKCRUZA
    Bob
    Placerville, Ca
    Is this a Pro or a Baja? Trying to find the card I wrote down the Pro # on and it is hiding! Looks about like the #'s I took off the Pro on Wed. If it is a Pro it would be interesting to see if the Pro and Baja rears are the same part number. I know that the Pro has softer front springs than the Baja, but no one seems to know if the valving for the strut and rears is different on the Baja...if both have the same rear part number that would answer at least part of the questions going around.
  5. Nov 8, 2014 at 2:35 PM
    Wild Crow
    James
    Anywhere is home
    2014 Baja
    Sorry. It's a 2014 Baja. I'll take a picture off the rear numbers when I get a chance.
    I was wondering if the earlier Baja's were different and they changed parts as they were developing the Pro?
