Spring Replacement How-to?
Discussion in '1st Gen. Tacomas (1995-2004)' started by jeepdude, May 7, 2012.
  1. May 7, 2012 at 12:34 PM
    jeepdude
    jeepdude [OP] Regular Member
    Jesse
    Connecticut
    2004 ext cab 4x4 TRD, bone stock for now
    Has anyone done a rear leaf spring swap themselves? I see this procedure sometime in my future, and couldn't find anything completely relevant when searching
  2. May 7, 2012 at 12:36 PM
    zbaldo
    zbaldo Well-Known Member
    Ozzy
    Torrance, Ca
    99 4Runner SR5 4X4
    Stock as Stock can be with duratracs and a roof rack
    Which springs are you referring?
  3. May 7, 2012 at 12:38 PM
    zbaldo
    Ozzy
    Torrance, Ca
    99 4Runner SR5 4X4
  4. May 7, 2012 at 12:42 PM
    jeepdude
    Jesse
    Connecticut
    duh, sorry...rear leaves
  5. May 7, 2012 at 12:48 PM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    ...too much shit to list.
    Jack up the truck and place jackstands under frame.
    Lower jack so axle is at full droop.
    Place smaller jackstands under axle and do the following side at a time:
    Unbolt lower shock bolt
    Remove ubolts
    Unbolt rear shackle bolt
    Unbolt front hanger bolt
    Install new spring in reverse order.
    **Use new ubolts
  6. May 7, 2012 at 12:56 PM
    Robertgeejr1
    Robertgeejr1 Well-Known Member
    Robert
    Aorora, Ill, yeah!
    1996 Toyota Tacoma SR5 4x4
    I have done all the hi-pro mods for a life time, since I got this truck at a great price, I will be happy with showroom new.
    and treat all the bolts with power blaster or some kind of bolt lub, over and over before you do this it will make it somewhat easier. I have worked on old tag-a-long trailers and air guns would not make the old bolts move, and to save time we would have to take a touch to them.
  7. May 7, 2012 at 1:06 PM
    jeepdude
    Jesse
    Connecticut
    Geeze guys, sounds like an afternoon job, no reason to put it off, I guess!
  8. May 7, 2012 at 1:08 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    ????????????????????????:notsure:
  9. May 7, 2012 at 1:56 PM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    :confused: wut?
  10. May 8, 2012 at 8:05 AM
    jeepdude
    Jesse
    Connecticut
    -meaning it seems very straightforward...wasn't sure about getting the alignment correct, but that's something I'll have a shop do when I'm done
  11. May 8, 2012 at 8:38 AM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    There's real "aligning" a rear solid axle. The centering pin of the leaf pack goes into the hole on the spring perch....and then it's centered.
  12. May 8, 2012 at 8:47 AM
    Jdaniel1274
    Jdaniel1274 Well-Known Member
    Daniel
    Orange County, Ca
    01 DC TRD 4X4
    PIAA lights, OMD leaf spring mod, magna flow muffler, oil filter relocation kit
    You make it sound very easy!
  13. May 8, 2012 at 9:02 AM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    As long as you're not dealing with stubborn bolts, it is easy. I did two spring pack replacements back to back this past Saturday in about an hour.
