Spring Shop Rear Leaf Springs?
Discussion in 'Suspension' started by wolftree, Dec 5, 2011.
  1. Dec 22, 2011 at 7:09 AM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    yup, airbags are a good option
  2. Dec 22, 2011 at 8:29 AM
    wolftree
    wolftree [OP] Well-Known Member
    Rick
    Ohio
    2011 Tacoma 4x4 Regular cab automatic trans,
    Rear Leaf TSB, Bilstein 5100s, extra leaf added
    captclueless,
    Certainly the airbags are a good choice for you. If you choose to go with having custom springs, I would suggest as 4WD did, using Ford springs and building your own or going to a local spring shop and having them built to your needs and wants. A spring shop can build anything you want within reason. They know springs.
    I am like you, my concern is lifting heavy things into the truck bed from the ground up, not lifting the bed itself.
  3. Dec 22, 2011 at 9:12 AM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, Tundra brake swap, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera
    Aren't Ford leaves a bit wider than than the Toyotas?
    Toyota leaves are 2 3/8" wide, and most other 4x4's are 2.5" .
    Not much wider, but noticeable when re-assembling the packs.
    This may require new u-bolts, since the stock u-bolts may not
    accommodate the new, wider leaves. I had trouble with this
    years ago when I added Jeep Wagoneer leaves to the stock
    leaf packs of my Toyota pickup.
  4. Dec 22, 2011 at 11:00 AM
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    Funny you mention that, I did run into that on mine (1st gen) the difference in width was very slight (maybe an 1/8" overall)
    by the time I took my angle grinder & basically cleaned up the edges ever so slightly, they fell right into place on the mount/clamp/shock perch
    I've done 3- 2nd gens so far & havent had the issue with them
    For the record I've no problem shaving a spring down slightly if U bolts make contact . Whats more important is making sure they (bolts) sit close to flush against spring (no bowing ) for alignment purposes & no "false torqueing"..
  5. Dec 22, 2011 at 4:19 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    Ok seems like a good place to start, just got back from... ya know what, I'll start a thread with build steps, thanks to the OP for starting this one gives me another chance to show the non-believers that you dont have to be a master mechanic or to empty your wallets on "name brand" springs, dont get me wrong... Deaver, Alcan,AllPro, etc; are excellent springs , I just couldn't justify the price they get for springs for doing something that we did back when there were no offroad specialty shops or products....;)
  6. Dec 22, 2011 at 4:54 PM
    wolftree
    Rick
    Ohio
    Thanks 4WD for your information. I created my own "Add-A-Leaf" years ago on a 57 Ford Fairlane using Mercury springs. I did not need traction bars after adding them.
  7. Dec 22, 2011 at 5:58 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    No worries bro' , good on you for thinking outside the box with the Ford/Merc springs....:thumbsup::thumbsup:
