Spring TSB does not apply to my 2010
Discussion in '2nd Gen. Tacomas (2005-2015)' started by zdog, Aug 15, 2011.
  1. Aug 15, 2011 at 3:17 PM
    zdog
    zdog [OP] Well-Known Member
    Oregon
    2010 5lug Access Cab SR5 2.7/5speed
    Does anyone know why the TSB does not apply to the base 2010 tacoma?
    It has the 48210-04380 springs in it now. The dealer took it apart to do the spring TSB and their 4 leaf springs would not fit.
    After re-reading the TSB, the TSB says only 4x4 and pre runner models are covered?
    Thanks,
    zdog
  2. Aug 15, 2011 at 4:00 PM
    zdog
    Oregon
    I understand about spring over and spring under. The spring under is just as weak as the spring over. Is it true that there is a Toyota Canada part number number that will replace my spring under with a 4 leaf spring under?
    Maybe a 48210-04561
    zdog
  3. Aug 15, 2011 at 4:10 PM
    OZ-T
    OZ-T You chose ... poorly
    Peter North
    British Columbia
    Pretty sure the Canadian 5 lug trucks are the 3 leaf spring under as well
  4. Aug 15, 2011 at 5:45 PM
    zdog
    Oregon
    I called a Vancouver BC dealer and the parts guy said that were two sets available for the under spring. A 2+1 and a 3+1. I currently have the 2+1.
    I plan on letting Toyota spend their money first. When that runs out I will raid the wife's egg money.
    zdog
  5. Aug 15, 2011 at 6:00 PM
    David K
    David K Well-Known Member
    San Marcos, Alta California
    2010 4WD Off Road DC
    Did your '10 bottom out/ have a 'harsh ride'?
    My '05 did, but my '10 did not... If it doesn't need a TSB then there is no reason to change (if it ain't broke, don't fix it).
    Access Cabs and Double Cabs had the issue but not regular cabs. The 3 leaf springs were not strong enough for the bigger 2nd gen access and double cabs... at least in the beginning.
  6. Aug 15, 2011 at 6:08 PM
    OZ-T
    Peter North
    British Columbia
    Interesting to know , I had thought there was no TSB for the 5 luggers
  7. Aug 15, 2011 at 6:09 PM
    OZ-T
    Peter North
    British Columbia
    Did you read the thread ?
  8. Aug 15, 2011 at 6:47 PM
    David K
    Yes, and no where do I see him say he had a harsh ride or the suspension bottomed out... that is why I asked.
  9. Aug 15, 2011 at 7:02 PM
    zdog
    Oregon
    I have a access cab 5 lug. Yes I have a harsh ride when moving between Arizona and Oregon hauling a 4-5 hundred pound load twice a year.
    For some reason Toyota excluded the 5 lug series. Can anyone think of a good reason why?
    Try reading this post
    http://www.tacomaworld.com/forum/4-cylinder/115345-2wd-spring-tsb-sort.html
    Thanks,
    John Shaw
    Thanks,
    Zdog
  10. Aug 15, 2011 at 9:33 PM
    JKD
    JKD Well-Known Member
    From the '09 dealer brochure, the 5-lug reg. cab is about 200 pounds less than the regular cab pre-runner, and about 400 pounds less than the regular cab 4x4.
    The 5-lug regular cab is about 300 pounds less than the 5 lug access cab. It is about 300-500 pounds less than an access cab prerunner/4x4.
    It is about 700-900 pounds less than the double cab 4x4s.
    My guess is that's a main reason why.
  11. Aug 15, 2011 at 10:16 PM
    zdog
    Oregon
    This is a reasonable reply JKD. This all started when I was looking for a way to upgrade the suspension in my Tacoma after the Last trip to Arizona hauling a 4-500 pound load. I was impressed with how unstable the truck was. Then I discovered the TSB and thought this is my problem, there is a fix and life is good. Then the dealer called today and said the upgrade parts don't fit after they had stripped the old springs out. After this screw up the dealer had the insight to tell me that my truck did not quality for the TSB. If Toyota won't stand behind this truck then I will have to go the AAL or airbag route. We will see how this plays out.
    zdog
  12. Aug 15, 2011 at 10:17 PM
    brian
    brian Another Traitor
    Elizabeth City, NC
    2017 F-250 Powerstroke
    Do you have the yellow sticker?
  13. Aug 15, 2011 at 11:03 PM
    zdog
    Oregon
    OK....I will bite. What is the yellow sticker?
    zdog
  14. Aug 16, 2011 at 12:12 AM
    JKD
    Nothing of consequence, since it has absolutely nothing whatsoever to do with the TSB or rear spring issues.
  15. Aug 16, 2011 at 3:47 PM
    zdog
    Oregon
    JKD,
    I believe there is another reason that the base model is not eligible for the TSB and that is.....The base model has the 2+1 leaf under spring. There is no US upgrade part for that spring. The only upgrade part for the base model is a Canadian Part # which is a 3+1 under spring. The trucks eligible for the TSB all have over springs.
    Have you read this? http://www.tacomaworld.com/forum/4-cylinder/115345-2wd-spring-tsb-sort.html
  16. Aug 16, 2011 at 4:26 PM
    brian
    Elizabeth City, NC
