Springs for 5100s
Discussion in 'Suspension' started by ToucanV13, Oct 1, 2010.
  1. Oct 1, 2010 at 6:18 AM
    ToucanV13
    ToucanV13 [OP] You think I was rollin out here naked?
    San Diego and Colorado
    Infideled out TRD Sport 4X4
    285/70 Hankook AT-M, Window vents, TRD CAI, TRD Cat-back exhaust with WickedFlow can, AFE Throttle Body Spacer, Billy 5100 @ 2.5 and 1" block rear, RBP nerf bars, Halo HIDs, 20% tint up front
    I know the Eibach springs are preferred/run the most but can you run any other spring? Say springs off some 2.5 C/Os? I found springs on Race Dezert but they're not Eibach and I'm curious if I can run them. Also in the Read Before Lifting, it said it's not recommended to run aftermarket springs. Is that due to UCAs?
  2. Oct 1, 2010 at 9:19 AM
    ToucanV13
    Bump for East Coast lunch crowd!
  3. Oct 1, 2010 at 9:26 AM
    spark4
    spark4 Well-Known Member
    So Cal
    2018 Tacoma TRD OR 4x4 Cement
    Bilstein 6100/5160, Ray 10's, 5.29, KDMax Tuned
  4. Oct 1, 2010 at 9:31 AM
    ToucanV13
    Appreciate it but I'm also wondering about other springs like some King springs either from 2.0 or 2.5. Can't swing the OMEs just yet; actually prob a while :eek:, would rather get UCAs but if I can use these springs since they're substantially cheaper...
  5. Oct 1, 2010 at 7:57 PM
    TexasTacoma37
    TexasTacoma37 Well-Known Member
    I think it's not recommended to run them with aftermarket springs because they don't want people setting the billy's to a preload setting and ALSO using lift springs.
    The billy's have the same spring perch as any other shock, so running any lift springs with the billy's set to zero should be fine.
