Springs on Bilstein 5100s
Discussion in '3rd Gen. Tacomas (2016-2023)' started by wilki168, Nov 18, 2024.
  1. Nov 18, 2024 at 6:03 PM
    wilki168
    wilki168 [OP] Well-Known Member
    I’ve got 5100s all the way around and a 1.5” AAL in the rear. I’m looking to run new springs on the front instead of riding on the 4th clip. 4th clip runs 1.55” lift. Debating on a 1.5” spring vs 2.0” spring. I like how it looks now but worried if I get the 1.5” and it sags eventually, it will look all off. 2/1.5” set up sounds just about right.
    Dobinsons 302 says 1.6” and I’d probably run either Dob or OME 2” spring.
    Any thoughts?
  2. Nov 18, 2024 at 10:48 PM
    StreetSr5
    StreetSr5 Well-Known Member
    My truck rides buttery smooth on the 5th clip driver side and 4th clip passenger side stock coils. Have you tried the stock coils at a higher setting yet? 5100s are so interesting as there’s so much conflicting advice regarding the coils and ride quality. My vote is try the stock coils out first and see how you like it!
    Burns likes this.
  3. Nov 20, 2024 at 3:08 AM
    VaToy
    VaToy Life Long Member
    Parts Unknown
    2018 TRD DCLB Sport 4x4 Silver Sky
    Bilsteins 5100s on the top setting, 4runner Gray TRD Pro Sema wheels, 285/70/17 Toyo AT3s, Sumo Bump stops, TRD exhaust, ECGS Clamshell bushing, 1/4 shim for the lean and one inch rear block, OEM Pro grill and garnish OEM TRD Skid plate, TRD CAI, Demon Brackets, Rigid Industries Pro fog lights, OEM Trail Rails sidebars, Diode Dynamics LED SL1 high and low beam lights, OEM Roof racks, Clazzio leather heated seats, Remote Start, TRD Pro shift knob, tinted windows, Rockford Fosgate 4 channel amp for the headunit and sub and amp combo, OEM Puddle lights, OEM tailgate lock, OEM bed mat, LED interior lights, OEM blackout kit for letters, JLT catch can, upgraded 27F toyota True Start battery, Vleds led tail light kit with Pro tail lights, OEM Rave4 side mirrors with convex spotters,just to name a few mods.
    Stock coils. I have been on the 4th setting and the 5th setting and it rides the same. Been 6 years and no issues!
    Burns likes this.
