Springs
Discussion in 'Suspension' started by kilgoja, Jan 19, 2010.
  1. Jan 19, 2010 at 11:54 AM
    kilgoja
    kilgoja [OP] Well-Known Member
    Alabama
    2009 regular cab 4x4 2.7L (silver)
    :mudding:
    i thought it would be a good idea to leave the spring rates for the different springs in a thread...if you know them then please add to the list
    stock is around 400lbs
    toytec coilover 600lbs
    (optional spring 500lbs) for reg cab
    icon coilovers 650lbs
    eibach 1.6" springs 620lbs
    OME 884 and 885 590lbs
  2. Jan 19, 2010 at 1:17 PM
    mixaro
    mixaro Well-Known Member
    maine
    02 tacoma ext cab, 2011 trail edition 4 runner, 2013 tx baja dcsb
    02 ext cab cat-back exhaust, k&n replacement filter, 5100 billy's, hellcreek 1.5" rear spring packs, 882 OME coils, Toytec 2" AAl, stainless brake lines, Light Racing UCA, 1" diff drop, BPV bracket, 4" deck plate mod, 886 fog light backup light mod, tom woods one piece drive shaft, spider trax 1.25 spacer.
    OME 882 530lbs
  3. Jan 19, 2010 at 1:22 PM
    afd23a
    afd23a Well-Known Member
    The Dynamo of Dixie
    05 Access Cab 5 Lugger
    Factory Fog Lights, Removed Secondary Air Filter, Metra Ipod Adapter, Int Wiper Stalk, Wet Okole's, URD Short Shifter, Scanguage II w/Blendmount, Fat Bob's 2.75" spacer lift, ARE topper, SP Performance Pads & Slotted Rotors, 4.10 gears
    SAW coilovers (2" and 2.5") 650lbs
