Sprinkler system bleaching fence, how can I fix it?
Discussion in 'Off-Topic Discussion' started by TexasTacoma37, Jun 5, 2012.
  1. Jun 5, 2012 at 7:55 PM
    #81
    TexasTacoma37
    TexasTacoma37 [OP] Well-Known Member
    So the cleaner takes the old stain off, so it will match the worn part?
    And yes I adjusted the heads as soon as I moved in.
    Ah okay, but you can't tell whereit was stained/worn before?
  2. Jun 5, 2012 at 8:00 PM
    #82
    kirkofwimbo
    kirkofwimbo Well-Known Member
    Clayton
    Wimberley, TX
    ‘21 Tundra SR 4x4
    Your probably right. My experience comes more with cabinetry and trim:). I still think this is your best option Keith
  3. Jun 5, 2012 at 8:02 PM
    #83
    TexasTacoma37
    I'm going to try a small portion with just a color-matched stain as a few have suggested. Then, when that looks horrible, which it almost assuredly will, I will try the sanding. I appreciate all of your suggestions and feedback.
  4. Jun 5, 2012 at 8:06 PM
    #84
    ISUGrad05
    ISUGrad05 Public Servant Enemy #1
    Wichita, KS
    2012 4x4 5.7 Tundra DoubleCab
    http://www.pro.olympic.com/olympicpro/products/exterior-stains/cleaners/premium-deck-cleaner.aspx Its been several years ago since I used it... So I guess apply full strength, non diluted and just rinse off with water. It says it is non acidic and the water is used to neutralize it, so you'll still want to use gloves and goggles. Sorry for the miss information. Honestly I dont know if it will remove the stain or not but it states it penetrates and deep cleans the wood. So if the stain is just on the surface it may very well remove it. I don't know I used it on non stained cedar, and then stained it.
    And despite the fact that the instructions say no scrubbing needed, I had to scrub the fence.
  5. Jun 5, 2012 at 8:18 PM
    #85
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Not sure , you'll have to test it across a board that is both bleached and not bleached
  6. Jun 5, 2012 at 8:39 PM
    #86
    Madjik_Man
    Colorado Front Range
    I've pressured washed my 25 year old fence that was untreated from the get go.
    It is cedar and had that insanely weathered gray color. After merely pressure washing it, it was brought back to fresh/brand new.
    That's all you have to do if it's a cedar fence.
  7. Jun 6, 2012 at 12:37 AM
    #87
    Amo-cat3
    Amo-cat3 Wizard Sleeve Master
    Maui, Hawaii
    07 TRD Blown dubcab
    TRD Supercharged 4.0 w/ 2.5" Quick change Pulley, UCON EMS, URD 7th injector, AFE Stage II intake, DT Longtubes, MBRP 2.5" dual exhaust w/ Vibrant Ultra resonator, URD Y-pipe w/ vibrant v-bands (Cat free), Walboro 255 fuel pump, SS Oil catch can, Aeroforce gauges, Icon CDC 2.5 coilover set at 3", 1.5" Wleelers Progressive aal, Light racing uca, 17x8.5 Fuel Anza 4.5" backspace/-6 mm offset, Kelly Safari a/t 265/70/17, scanguage 2, AMP electric steps, bed extender, Low-pro tonneau cover, 20% tinted windows/headlights/taillights, tacoma seat covers, Image dynamic sound system w/ Pinoneer avh3200 head, assrtd stickers................
    Since you can't pressure wash you need to give it a good scrub. You can try sanding but i guarantee after you sand two planks in the sun and realize that your orbital pad sander is not as fast as you thought (i have a lot of experience). You cant use a belt sander as it will be extremely awkward. You can use a drywall sander with a big sanding pad, but again after half hour of sanding with that stick yeah right. If you do sand don't go any finer than 100 as you don't want to clog up the wood pores.
    Looks like cedar:
    Get a super stiff deck brush on a pole and fill 5 gallon bucket with bleach brite solution. Get to scrubbing say 8 foot section at a time then give quick rinse.
    Use a natural transparent wood stain -darker the better to blend in with the darker weathered portions. You'd be surprised with how bright old weathered wood will get.
    As for your neighbors side is it bleached from the sprinklers to? If there's is still solid stained i don't think you need to worry about bleaching their end. Just don't soak the bleach for a long time.
  8. Jun 6, 2012 at 1:09 AM
    #88
    OZ-T
    Peter North
    British Columbia
    8" grinder with a concrete grinding flap wheel works wonders on rough sawn wood too
    Fast
    Scary
    Works
    No lie
  9. Jun 6, 2012 at 2:37 PM
    #89
    FFTacoma
    FFTacoma Well-Known Member
    Been buliding & repairing fences for 12 years. +1 on using the deck brightener. Start out by wetting the fence down w/ a hose. Get a cheap pump up lawn sprayer. Spray the deck brightener on a few sections at a time. The crud on the fence surfaces will bubble up like you applied oven cleaner. Pressure wash the residue at a low-pressure fanned out pattern. When everything is thoroughly dry apply a sealer stain. Fences really look good with cedar tint sealer. I would apply 2 coats since you have a sprinkler system. I would then reapply at least every 3 years to keep it looking good, and to fight the effects of the sprinkler system. Hope this helps. By the way, as you can tell, this is very labor intensive. Hang in there and just keep working at it.
  10. Jun 6, 2012 at 3:42 PM
    #90
    wildjerseyfirefighter
    wildjerseyfirefighter I sell fishing and fishing accessories
    Joe
    NJ
    05 Tacoma TRD Sport
    stock, for now
    But he can't powerwash. :rolleyes:
  11. Jun 6, 2012 at 4:05 PM
    #91
    TexasTacoma37
    Thank you. Maybe in a couple of years I can do it that way once the restrictions are lifted.
  12. Jun 6, 2012 at 6:39 PM
    #92
    Polymerhead
    Polymerhead Well-Known Member
    Missouri
    '18 TRD Limited Inferno...Tundra!
    Man, just got done staining 200 linear feet of 4-foot shadowbox fence. Took 5 gallons. That means it's gonna cost about $260 for the entire project. That's a set of bilsteins! :p
  13. Jun 6, 2012 at 6:40 PM
    #93
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
  14. Jun 6, 2012 at 6:43 PM
    #94
    ImpulseRed008
    Susan
    SC
    08 PreRunner SR5 V6 w/tow pkg
    there's no water to save his house if it catches on fire...
  15. Jun 6, 2012 at 6:46 PM
    #95
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Well....that will teach them how effective those stupid water restrictions are.
  16. Jun 6, 2012 at 6:48 PM
    #96
    ImpulseRed008
    Susan
    SC
    :rofl:
  17. Jun 6, 2012 at 6:50 PM
    #97
    Joe
    NJ
    05 Tacoma TRD Sport
    stock, for now
    I'm going to pencil you in for the presidential canidate.. When don't you make sense..:cool:
  18. Jun 6, 2012 at 7:07 PM
    #98
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Indeed. :cool:
  19. Jun 6, 2012 at 7:09 PM
    #99
    Joe
    NJ
    05 Tacoma TRD Sport
    stock, for now
    Do they allow numbers on the ballot? How do you spell 4x4?:confused:
  20. Jun 6, 2012 at 7:11 PM
    #100
    ImpulseRed008
    Susan
    SC
    16
