Sprint Booster
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Jlemaster4, May 24, 2017.
  1. May 25, 2017 at 12:52 PM
    gpb
    gpb Well-Known Member
    Atlanta
    2017 White DCSB TRDOR 4x4
    Thanks for the video.
    Hopefully such a device will help those who are unhappy with their trucks throttle response.
  2. May 25, 2017 at 12:54 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
  3. May 25, 2017 at 12:54 PM
    hastingsrussell
    hastingsrussell Well-Known Member
    Russell
    Allen, TX.
    2016 Tacoma TRD Sport
    Pretty stock for now
    I know I am, that's why I am keeping my eye on this thread and the Shift Sense Pro thread.
  4. May 25, 2017 at 12:56 PM
    JayRolla
    JayRolla Well-Known Member
    Colorado Springs
    Wife's 2012 DCSB Tacoma Sr5
    Trd stickers for 10whp 32s on MK6 17s
    Im really thinking of getting this for the wifes 2nd gen. Motor off the start feels like it has a dead spot and I need to give a good 30% throttle to get it to move the same compared to my old 4runner that needs about 5% throttle.
  5. May 25, 2017 at 1:01 PM
    9TRDTCO
    9TRDTCO Well-Known Member
  6. May 25, 2017 at 1:02 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Exactly why I posted this in here. While it may work for some, there is no way in hell I'd risk a couple thousand dollar bill just for slightly improved throttle response.
  7. May 25, 2017 at 1:33 PM
    JayRolla
    Colorado Springs
    If you are not able to install an electrical component without shorting and killing your ECU you should not be installing it.
  8. May 25, 2017 at 1:35 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    That's not what was discussed. The member in that thread ran a pedal commander for awhile, and then it all of a sudden shorted out his ECU. Nothing to do with the installation. See Below.
  9. May 25, 2017 at 1:43 PM
    JayRolla
    Colorado Springs
    That sucks. Wonder how many times this has happened. Electronic failures are not uncommon. If I was scared to install parts because one person had a failure I would not have had installed anything. Everything I have installed on my truck or cars has probably failed on someone. Sucks when this happens. But thats life and Im not scared to install a different product because one person posted a failure.
  10. May 25, 2017 at 1:45 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    There are numerous reasons why I would never install one of these, but I digress. If someone wants to, that's their money, their truck, and their decision.
    JayRolla[QUOTED] and 9TRDTCO like this.
  11. May 25, 2017 at 1:57 PM
    smitty99
    smitty99 I also bought a 4Runner
    Scottsdale
    16 TRDORDCSB 4x4 A/T (loaded w/ JBL)
    6112s/5160s & 3-leaf AAL;ubolt flip kit;Superbumps
    Is this better than shiftsense
  12. May 25, 2017 at 5:30 PM
    SamuelJ
    SamuelJ Darkhorse
    Samuel
    33.9269893 -118.0185768
    2012 DCLB 4x4 Trd Sport
    Shortened flowmaster exhaust with a turn down pipe, under cowl intake, throttle body spacer, train horn, underhood led lights, hood struts, dual 27f yellow tops. Led ditch lights, led front roof light bar, led fogs and headlights, behind grill mounted piaa dual color driving lights. Aux fuse and relay panel. Pro comp skid plate, bilstein 5100 leveling shocks on a 2in. lift, b110 rear 5100, add a leaf, front superbumps, light racing jounce rear bumpstops, sway bar relocation, brake line bracket extension, driveline carrier bearing drop, front diff drop, on board air compressor, 10 gal pump driven fresh water tank, cb radio, pioneer 4200 hu, infinity reference component front and component rear speakers powered by rockford fosgate 4 channel, jl audio 10TW3-D4 sub powered by kx800.1 amplifier. Big three upgrade, capacitor. Full cab sound deadening and thermal insulation. Led interior including added footwell, courtesy, cupholder, center console, and glovebox lighting, rock lights, bed lights, ring gear armor, under bed ammo can storage, pistol safe, body armor sliders, roof rack, hilift, 285/70 17 nitto rodge grapplers on american racing teflon atx, tailgate strut, and tailgate lock, retrofit projector headlights(home built), rgb halos inside turbine shrouds, black out surround, black chrome reflector and shroud, white halo outside shroud, white led drl, rgb behind grill on rf control. Mods followed from a TW thread: Anytime fogs Anytime rear view camera Anytime 400w inverter Alternating blinker/running lights 110v center console outlet ABS kill switch Engine kill switch (magnetic) 12volt bed socket Rear diff breather relocation Led bed lights Cargo net anchors Grid it center console top Grid it sun visor Locking center console Instrument cluster led swap Map lights on with dome Cigarette lighter add (shifter position) Dtrl kill switch Hilux lighted 4wd selector switch. Vios hvac knobs Hood scoop led bar
    Thank you, apparently someone should read the post throughly before making comments. Btw, I have been wiring stereos, amps, lights, ect. since highschool so I know I am competent. Sounds like if you dont know that it is a simple plug and play install then maybe you should read up on a product before you shoot off your mouth. Ok sorry, I wont throw anymore stones. If I could do it again I would have gone sprint booster instead.
  13. May 25, 2017 at 5:39 PM
    Halena Molokai
    Halena Molokai Well-Known Member
    Black 2016 TRD DCSB OR 4x4 MT6
    BFG KO2 265/70/17 Moto Metal 17x 9 -12mm ToyTec Boss 2.0 lift Kit Wet Okole, Ceramic tint 35% Bakflip F1 Flowmaster Exhaust Single in /Dual out with 3"stainless tips DashMat Covercraft Custom windshield shade Tilt Alarm Weatherbeater Mats Diode Dynamic LED upgrade to interior OEM Bed Mat OEM 5" Chrome Side Steps
    The thing that bothers me more than anything about the pedal response is when you go to rev the engine in neutral it takes forever to come back to idle. Will this resolve that issue. Tks
  14. May 25, 2017 at 5:59 PM
    SamuelJ
    SamuelJ Darkhorse
    Samuel
    Maybe I should clarify that I don't have any intension of screwing around with my pedal or related components after what happened. In fact I wouldn't have even posted about it if the company had taken the time to respond to my messages. I didn't think they would do anything to help. Figured they would say they cant be held liable for any damages incurred from using their product. Or perhaps offer to reimburse me the money spent in return for it to get shipped back to them for testing to find possible causes which led to it shorting out the ecu. But I wasn't holding my breath. What really bothered me was they didn't even respond. What the hell kind of customer service is that? So I considered my options and plan on telling everyone about it. I also have both the old ecu and pedal commander unit so perhaps small claims court. Doubt it will do any good but if I try maybe they will get the point. URD on the other hand I have heard nothing but positive things about.
    doublethebass likes this.
  15. May 25, 2017 at 6:17 PM
    #35
    FrankJake
    FrankJake Well-Known Member
    Southern California
    2017 Tacoma TRD OR SB Magnetic Grey Metalic JBL Stock (so far)
    Shift Sense Pro, HomeLink Mirror, Screen Protector, Tinted Windows, Now onto the expensive stuff
    But this isn't the Throttle Commander. Maybe very similar but a different company all together. Not that I'm going to buy one. I'd assume with many after market products there's a chance of something going wrong.
  16. May 25, 2017 at 6:30 PM
    #36
    FrankJake
    Southern California
    This could be you with the Shift Sense AND Sprint Booster!
    Jeremy4x4, Judicar and SamuelJ like this.
  17. May 25, 2017 at 6:45 PM
    #37
    gainman
    gainman Semper Fi
    SW Florida
    2012 TRD Sport Supercharged Manual
    Stuff
    There is no difference at all. It basically shortens the pedal travel, gets you to 100% throttle faster. It feels more responsive but there is no actual difference.
    It simply amplifies the throttle position signal.
    I admit though, it makes the truck feel great. I had it on both my last second gens. Just don't think it adds power or reduces throttle delay because it does none of that.
    If you have the money to spare, they do feel nice.
    Jeremy4x4 likes this.
  18. May 25, 2017 at 7:19 PM
    #38
    Joe23
    Joe23 Canuckistikian
    The Great White North
    2017 TRD Off-road DCSB
    I have one on my Jetta. If I can find another one for the taco for the same price I'll buy it again.
    Theyre worth it and it is a noticable improvement on the shitty fly by wire throttle
  19. May 25, 2017 at 10:51 PM
    #39
    SamuelJ
    SamuelJ Darkhorse
    Samuel
    Ya it doesn't actually give you more power but it did make it feel that way. Wish I had saved all that money and gone supercharger but lesson learned. My wife asked about her 4runner at first but now she saw what happened and agrees with the "you want more hop? Mash it" theory. IMO save your money, get a real upgrade, I shouldve.
  20. May 26, 2017 at 7:08 AM
    #40
    Mountain Minstrel
    Mountain Minstrel Well-Known Member
    Prather, CA
    '17 DCSB MT INFERNO
    Why in the world would you feel the need to do that?
    TheCookieMonster likes this.
