Sprintbooster. Any reviews or experience?
Discussion in 'Performance and Tuning' started by thomsom1, Aug 21, 2012.
  1. Aug 21, 2012 at 1:59 PM
    thomsom1
    thomsom1 [OP] Member
    Blackfalds, Alberta
    11 Tacoma TRD
    AFE Stage 2 CAI Wet Filter, AIRAID TBS, Magnaflow 3" Catback Exhaust, Sprintbooster
    Is there anyone out there with a Tacoma that has tried the product Sprintbooster? Get at me!
  2. Aug 21, 2012 at 2:20 PM
    nut
    nut she'll ride
    Patrick
    Arizona
    Totaled
    TRD SKEWP DCSB 4x4 Silver Mica | URD TCAI/MAF CAL | BHLM | GrillCraft | FF Sliders | LED's All Around | 12v Constant On | EGR In Channel | 15% Tint | Trimmed mud flaps | Fog Light Anytime Mod | Debadged | Tailgate Hoseclamp | DTRL Switch | Disabled Lock Beep/Seatbelt Chime | Husky Liners | HID's | BedRug | WO Seat Covers | ABS Kill Switch | Oil Catch Can | Viper 5704 | Custom Carbon Cabin Filter | Backup Camera Anytime | 400W Anytime | In Cab Outlet W/USB | Firestone Ride Rites | Ams Oil All Around | 32" LED In Lower Grill | BlackVue DR500GW-HD |
    I have 3 on my Tacoma. I love them. Best bang for the buck you can get, well aside from NOS (Saving for a NOS kit).
    Not
  3. Aug 21, 2012 at 2:55 PM
    thomsom1
    Blackfalds, Alberta
    11 Tacoma TRD
    You do like them? or you dont...
  4. Aug 21, 2012 at 3:02 PM
    thomsom1
    Blackfalds, Alberta
    11 Tacoma TRD
    A friend of mine installed it on his Hyandai Genesis, and he loved it. All the reviews online are about BMWs but nothing on a Tacoma
  5. Aug 21, 2012 at 4:27 PM
    nut
    nut she'll ride
    Patrick
    Arizona
    Totaled
    seems like a waste of money, whats the point??
  6. Aug 22, 2012 at 8:17 AM
    thomsom1
    Blackfalds, Alberta
    11 Tacoma TRD
    www.sprintbooster.com
    It is a plug and play module that cuts out the delayed throttle response with drive-by-wire technology.
  7. Aug 22, 2012 at 9:36 AM
    Speed Freek
    Speed Freek Tacoma Whisperer!
    Vista, Ca, Lake Havasu, Az.
    98 Tacoma V8 (LS1) swap
    LS1-T56 swap, Z06 ported heads, cam, Titanium valves, Kevlar clutch. Now building a forged stroker (383) and all the ponies! Old setup was rod-knockin on heaven's door...
    No, but a lot of the drive by wire systems that I have driven ( the worst one was a new 6 series BMW) had the worst fking throttle lag on the planet, and it had a split second lag as well when releasing the throttle, almost ended in disaster since when I release the throttle I expect INSTANT release, not OK I will get to that in just a sec!.
    I cant say I have really felt that in a Toyota, but I have felt some bad electric throttles that I absolutely hated. You will understand once you drive one that has bad delay....
  8. Aug 22, 2012 at 9:48 AM
    Speakerboy
    Speakerboy Well-Known Member
    Jim
    Center Valley, PA
    '02 Xtracab 5 lug manual
    It's more than just for a race track. A lot of the German cars have a lot of delay in the drive by wire system - to the
    point where you have to change the way you drive. Its almost dangerous when you make a left across traffic, pulling out, etc. I don't think it's necessary on the Tacoma.
  9. Aug 22, 2012 at 11:46 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    They are basically to give you a linear pedal response, such as a cable driven throttle body, or more than linear response. Gives you the ability to remove the negative bow from actual throttle position compared to commanded throttle position.
    Mine will have a linear response with my next tune, since the ProEFI will be controlling the throttle body. If i didn't have that control, I would do something like the Sprint booster, or the Blitz throttle accelerator as well.
