Sputtering during acceleration, need help
Discussion in '1st Gen. Tacomas (1995-2004)' started by low boy, Jan 2, 2014.
  1. Jan 2, 2014 at 10:18 AM
    low boy
    low boy [OP] 4wd Toyota Enthusiast
    Maryland
    2001 Tacoma TRD Xtra-cab
    lift, tires, wheels, some interior stuff
    So here's my issue. last week I took my 2001 SR5-TRD to the wash-rack to degrease the engine bay. I used greased lightning then hit it with the power-washer, everything but the battery and fuse box. I drove it home and it started sputtering during acceleration, and stops sputtering once I reached my cruising speed. the next day I replaced my K&N with an OEM air filter since my initial thought was water got in the air box. the K&N filter was wet, but beyond the air filter was dry. I still have the same issue and it sucks. does anyone here know what's up or has ever had this happen, please help my truck out.
    I've searched threads on this and haven't got the answer yet.
  2. Jan 2, 2014 at 10:23 AM
    flatblack
    flatblack Well-Known Member
    CDA
    95.5 Tacoma 3.4 Manual
    Check out your MAF, is my first thought; especially if your air filter got wet
    Those wire-sensors are pretty sensitive
    And a faulty MAF will cause problems like your describing
    Spark plugs would be my next guess, with high-pressure water getting sprayed in there; even though they're pretty well sealed
  3. Jan 2, 2014 at 10:24 AM
    low boy
    Maryland
    will do thanks
  4. Jan 3, 2014 at 7:17 PM
    Greensystemsgo
    Greensystemsgo 1 owner with clean car fox.
    Dirty Nickers
    Peoria, AZ
    18 year old black taco...
    Bone Stock.
    beyond maf was dry because engine sucked it in. go down the line. check stuff. maf. iac. coils. plugs. wires. really you shouldnt powerwash. this will also mess up alt, power steering pump, ac compressor, push in through seals on block, overall you could have a really bad time. on the plus side, doing this work, the engines clean!
  5. Jan 7, 2014 at 11:23 AM
    low boy
    Maryland
    UPDATE: cleaned the MAF, checked the TPS, and installed a new upstream o2 sensor. runs much better but still not 100%... I noticed my check engine light flashing 3 times and know that usually means I'm in trouble of melting my CAT, so I popped the hood and found an exhaust leak passenger side after the headers and before the "down pipe" with my upstream o2 sensor, it looks like it's attached with 3 studs. does anyone know what this pipe is called and how to fix this leak? I haven't had the chance to take it to get the code read yet, but would appreciate some insight if you have any to give.
  6. Jan 7, 2014 at 11:42 AM
    se7enine
    se7enine MCMLXXIX
    Reno, NV
  7. Jan 7, 2014 at 11:44 AM
    sirsaechao
    sirsaechao Well-Known Member
    Tim
    CA
    2002 Toyota Tacoma SR5 TRD 3.4L 4X4 V6
    A lift, some wheels, some tires, some performance, some cosmetic and then audio.
    Water in the spark plugs. I had the same situation and had to switch my plugs out and dry it up.
  8. Jan 7, 2014 at 12:34 PM
    low boy
    Maryland
  9. Jan 7, 2014 at 12:36 PM
    Jetlander
    Jetlander Just trying to measure up...
    Jonathan (aka MOAB)
    Depends on the day.
    2010 Tacoma DCSB 4x4 SR5
    TKO Wheel w/ 35" BFG KM2, Volant CAI, Safari Snorkel, 3" lift, All-Pro Full Skid Underarmor, Chopped/Re-Routed FlowMaster Exhaust, CBI Moab 2.0 Front Bumper, DerpWerx High Clearance Rear Bumper, Rear Tire Swing Out, BAMF Sliders w/Kickouts, King Resi w/700# Coilovers on front, Total Chaos UCA's, King Long Travel with Resi's, Shock Hoops and King 2.5 Bump Stops, OME Dakar Leaf Springs mounted on All-Pro Shackle Flip w/ U-Bolt Flip, extended SS Brake Lines, DerpWerx Bedrack, 10# C02 Tank, Black Badges, Dual Optima Red Top's, Blue Sea 12 Fuse Block on custom Block mount, SuperWinch 9.5iSR Talon w/synthetic line, Prolink Thimble, 20" Rigid Dual Row LED Light Bar, Rigid Dually Floods, OTRATTW Switches, Cab Mount Chop, Cobra CB w/ 4' Firestik, Center Counsel Glock 23 mount (with plenty o' ammo!), Weathertechs, and plenty more mods to come!
    I had the same symptoms on a vehicle awhile back. Found one of the spark plugs had a broken insulator. I think water hit it and because it was hot, it cracked.
  10. Jan 7, 2014 at 12:41 PM
    low boy
    Maryland
    good call on the plugs guys, i'll definitely get to that soon (was going to anyways) right after I fix this front pipe exhaust leak... hoping I can just tighten up the studs and roll on. thanks for the help
    Dalandser likes this.
  11. Jan 15, 2014 at 10:19 AM
    low boy
    Maryland
    replacing the plugs, wires and ignition coil today... will keep you posted. I really appreciate all the help from you guys.
  12. Dec 29, 2015 at 7:50 PM
    01trdtaco
    01trdtaco Active Member
    Alex
    louisiana
    01 trd, lunar mist ext. cab tacoma
    Flowmaster 40 series 1"leveling kit much more to come
    I know this is digging way back on the forum but what was the end result? I'm having the same problem with mine now. It was high pressure rinsed about 6 months ago but did not start having problems till about a week ago. Mine sputters when I accelerate from around 57-58mph in 4th. Been raining a crap ton here so maybe something got wet?
  13. Dec 29, 2015 at 8:14 PM
    CodeSeven
    CodeSeven LOC: 33.781461, -115.867251
    Serge.
    Coachella Valley
    '00 Taco 3.4 4x4 TRD ( <3), '06 Taco Prerunner 4.0 (totaled)
    3 inch lift. bluetooth stereo. blue transparent skulls shift knobs
    drove through a reallly flooded intersection during heavy rains. i believe the water splashed up and hit my cables, causing them to arc. apparently they arc easily, the other day i was cleaning my throttle body and was putting vacuum tubes back on while the engine was running. my finger got near the wires and I got zapped. make sure the wires aren't laying on grounded metal.
  14. Dec 30, 2015 at 4:04 AM
    low boy
    Maryland
    ignition coil and plugs, after that it was perfect again
    Dalandser, mechanicjon and wilcam47 like this.
  15. Dec 30, 2015 at 4:16 AM
    Stags863
    Stags863 Bye Felica!
    Florida
    2014 DCSB TRD Off Road 4x4
    - Bilstein 5100's set at 1.75 - 265/70/r17 Goodyear Wrangler Authorities - 6000k headlight and fog light bulbs - NiLight off road LED rear lights - Light bar mounted behind front bumper - White LEDs in dome, map, and sun visor - Tint (5% around / 35% front) - Universal 13 inch metal antenna - Beer bottle opener in bed - Organizer storage box in center console and glove compartment - Mounted MagLite to top of center console storage box - MGM grille - MGM rear bumper - CamLocker toolbox - Rubber floor mats - 2 USB and Cig lighter chargers in rear of center console - Headrest mounted iPad holders for rear seats
    Had the same thing happen to me when I owned my dodge. Water got down in the spark plugs. Had to let them dry out and then replace them. Once I did that it fixed the issue. Glad to hear that fixed your problem :thumbsup:
  16. Dec 30, 2015 at 5:40 AM
    01trdtaco
    Alex
    louisiana
    Awesome. I appreciate the response. Glad you found the problem. :thumbsup:
  17. Feb 13, 2017 at 8:52 PM
    LUNCHBOX66
    LUNCHBOX66 Well-Known Member
    Eric
    2012 white tacoma prerunner
    None so far
    I'm having this same problem with my 2012 DCSB. At 30-40 MPH I'm getting the sputtering, we did have some decent rain fall here in Califor5over the past few weeks. I cleaned out the MAS, k&N is cleaned, throttle body is clean, should I check my plugs?
  18. Feb 17, 2017 at 9:57 AM
    Greensystemsgo
    Dirty Nickers
    Peoria, AZ
    Bone Stock.
    Generally sputtering is caused by lack of ignition, so yes, check your plugs. Probably worth changing. Remember to not skimp out and go oem. First gens called for dual prong iridium's and it does make a difference.
    LUNCHBOX66[QUOTED] likes this.
  19. Apr 8, 2017 at 12:36 PM
    Bjm9598
    Bjm9598 Member
    98 Tacoma sr5 4x4
    Halo projectors
    What about e3s wouldn't those get better fire? Asking bc I recently drop a new set in mine. Drove fine. Then couple days ago it started sputtering when u shift to drive. Idles in nutreal and park. Cleaning maf today and gonna torque sparks and check for bad ones.
  20. Apr 8, 2017 at 6:44 PM
    LUNCHBOX66
    Eric
    None so far
    So after everything it needed up being my torque converter. I had an extended warranty. New torque converter and she's running tip top, gas mileage got better too
