Spyder Projector 14' Tacoma
Discussion in '2nd Gen. Tacomas (2005-2015)' started by busychild, Mar 9, 2016.
  1. Mar 9, 2016 at 7:01 AM
    busychild
    busychild [OP] Well-Known Member
    Alberta, Canada
    14 DCSB TRD
    TRD Exhaust, TRD Sport Short Shifter, Skid Plate, K&N Intake, Bakflip G2 Cover, Husky Liners, Falken Wildpeak ATW3. Alpine ILX-259, JL Stealthbox w 10TW3, JL XD600, 2x JL 650-x (front and rear doors), Subaru Kicker Tweeters, Motegi Traillite 17x8.5, Westin Side Steps .
  2. Mar 9, 2016 at 7:16 AM
    mrkabc
    mrkabc Mall Crawler with a Locker
    Art
    Corona, CA
    2017 MGM DCSB TRD OR
    Morimoto XB LED Head & Fog Lights, Cali Raised Stealth Light bar, OEM Roof Rack, Homelink Compass Mirror, Power Tailgate Lock, LED bed lights, MESO mirrors, gashole, switch panel & Stage 2 tails, PRO grille. Where's the mall?
    No one here has them yet. I have been asking for weeks. Picking up a set tonight. Will report back.
  3. Mar 9, 2016 at 7:20 AM
    ChadsPride
    Sponsored by TacomaWorld.com
    Report back immediately!!!
  4. Mar 9, 2016 at 7:52 AM
    busychild
    Alberta, Canada
    14 DCSB TRD
    nice! where did you pick them up btw?
  5. Mar 9, 2016 at 7:54 AM
    Aw9d
    Aw9d That one guy
    ALL ebay headlights have shitty light output and are cheaply made. I'd suggest doing a retro, but good luck with those.
  6. Mar 9, 2016 at 9:18 AM
    RAD
    RAD Well-Known Member Vendor
    Rad
    LAX & LOGAN
    Spoken like a True Gentleman. There is no way they'll put quality projector parts into an oem headlight at that price.
    You should purchase or build your own Retrofit.
    Aw9d[QUOTED] likes this.
  7. Mar 9, 2016 at 9:33 AM
    vssman
    vssman Rocket Engineer
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    Guys, I purchased a set of Anzo projector lights for my last truck. They were horrible. The reflector bowl is plastic when it should be metal in order to properly reflect the light where you want it. I eventually replaced them with true hid retrofit kit. Keep in mind that most aftermarket kits have a very sharp cut off. Mine were in a 3/4 ton Dodge 4x4 running 33's and when driving over undulating roads the cut off would come rather close to the front of the truck leaving the rest pitch black. That had to do with the height of the truck and needing to tip them down just a bit to keep from blinding everyone else. The cut off was so pronounced that stop signs would be dark. With the Tacoma being a little lower it may not be as much of an issue.
    Not telling you not to retrofit but want to make sure you realize it's not all sunshine and rainbows.
  8. Mar 9, 2016 at 9:47 AM
    RAD
    Rad
    LAX & LOGAN
    You are absolutely correct about those Anzo/Spyder so called projector lights. However the reflector bowl of a oem and aftermarket light are both made of plastic. Now the OEM Toyota reflector bowl is made of higher quality plastic than the aftermarket. The light output is not going to make a difference from the bowl if you have a projector. The projector is the main source of light you'll be getting and thats where you'll fail with the Aftermarkets.
    You'r best bet to get the Look and the Performance is to build your own Retrofit or get it done by someone.
    My absolute favorite build is a OEM Toyota Headlight with a OEM Nissan Murano Projector retrofitted in. That's a perfect combination imho.
  9. Mar 9, 2016 at 9:53 AM
    vssman
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    Go figure, I did mine more than a few years ago and I could swear they were metal as I actually had to make some special mounts. Maybe I'm mistaken (good chance) or they've changed to plastic. Got them from The Retrofit Source.
  10. Mar 9, 2016 at 10:47 AM
    RAD
    Rad
    LAX & LOGAN
    ^LOL. You're talking about the actual Projector itself. Then yes, its metal 100% all around as well as the reflector shield.
  11. Mar 9, 2016 at 10:51 AM
    ChadsPride
    I want to order a set from yall, any discount if I send my OEM lights after mine are installed?​
  12. Mar 9, 2016 at 11:17 AM
    KaptainH
    KaptainH Well-Known Member
    Kris
    Gainesville, GA
    Black 2013 DCLB Sport
    Is there a writeup for this? That seems pretty inexpensive to do compared to other retrofits I've seen.
  13. Mar 9, 2016 at 3:21 PM
    RAD
    Rad
    LAX & LOGAN
    Don't know if you'd consider that a cheaper retrofit as it can run you some coin to build. There is a lot of work to get those OEM Projectors to fit perfectly after tuning them. The FX-R is a lot easier to do and get it aligned right.
  14. Mar 9, 2016 at 3:22 PM
    RAD
    Rad
    LAX & LOGAN
    You got yourself a PM. We're doing a group buy starting tomorrow
    KaptainH and ChadsPride[QUOTED] like this.
  15. Mar 9, 2016 at 3:23 PM
    Aw9d
    Aw9d That one guy
    Nobody, and I mean nobody, should ever argue about Retro's when it comes to this guy.
  16. Mar 9, 2016 at 3:28 PM
    RAD
    Rad
    LAX & LOGAN
    ^LOL. I mean it comes down to preference as I know people love the Lexus LS Projector but I prefer the Muranos. I am in the process of building my new personal pair with Muranos and a Infiniti Shroud w/Custom paint work. Its going to be sleek for my truck while the lighting will turn heads.
    ChadsPride and TRSJimmy like this.
  17. Mar 9, 2016 at 3:31 PM
    TRSJimmy
    TRSJimmy All I Do Is Nguyen
    Jimmy
    Gainesville, GA
    12' Mall Crawlin Peerunner
    Muranos because sexy slopes lol
  18. Mar 9, 2016 at 3:50 PM
    RAD
    Rad
    LAX & LOGAN
    Sometimes there is always a slippery slope to be had. . . LOL.
    After doing quite a few, we've figured it all out 100%
    It's called a lot of R & D
    TRSJimmy and ChadsPride like this.
  19. Mar 10, 2016 at 4:49 PM
    Danny1956
    Danny1956 Well-Known Member
    Danny
    2015 Toyota Tacoma 4x4
    How much are they in the group buy?
    ChadsPride likes this.
  20. Mar 10, 2016 at 6:20 PM
    Noslow100
    Noslow100 Well-Known Member
    Josh
    VA
    08 SR5 4x4
    Toytec 3 Inch lift kit with Bilstein 5100's, and more
