Sqeak when backing up
Discussion in '2nd Gen. Tacomas (2005-2015)' started by centerwall, Jan 19, 2012.
  1. Jan 19, 2012 at 7:02 AM
    centerwall
    centerwall [OP] Active Member
    Bruce
    Elk River, MN
    2014 Black TX Baja
    2" front lift from dealer
    My brakes will squeak sometimes when backing up from sitting a long time. It only started happening when I had my brakes worked on. It is a very loud squeak. This problem was brought up in an older thread in 2011, but not too many responses. :confused:
  2. Jan 19, 2012 at 7:17 AM
    Utard
    Utard Well-Known Member
    Mark
    Nyssa, Oregon
    2012 DC LB 4WD TRD SPORT NAVI
    ------------------------------------------------------------ Stabilus.EZDown.Tailgate http://www.ezdown.com/home.php ----------------------------------------------- Tekonsha.Primus.IQ.Trailer.brake http://www.tekonsha.com/content/default.aspx---------------------------------------------------------------- Leer 180 CC http://www.leer.com/Truck-Caps#------------------------------------------------ Firestone Air Rite Air Bags--------------------------------------Kargomaster Rack
    How long ago where they done? Anyone know if the toyota rear brakes auto adjust in reverse? If they did not adjust properly maybe every time you are backing up they are still trying to adjust?
  3. Jan 19, 2012 at 7:31 AM
    centerwall
    Bruce
    Elk River, MN
    2014 Black TX Baja
    The brakes were worked on about 4 months ago now.
  4. Jan 28, 2012 at 4:54 PM
    Tacozoid
    Tacozoid Well-Known Member
    Terry
    Katy Texas
    White Tacoma Pre-runner
    Billsteins,Texas tint. Blue Dash mod. Console mod. in Blue, Customized grille
    Squeak when backing up? You just ran over your cat![​IMG]
  5. Jan 28, 2012 at 5:04 PM
    undermoneyed
    undermoneyed aka Alley Opp,
    Mark
    B.C., Canada
    Tacoma TRD
    totally stock
    Get your manual out and compare the brake pics in the manual with what's going on with your own brakes. Sounds like the mechanic screwed up. I've done my own brakes a few times and to make sure I don't screw up I take pics before I touch anything.
    If you can't see anything amiss, check yours against a friends right down to the last detail. You can also try comparing left to right. That will work unless he F**k'd both sides.
    HTH
    Mark
  6. Jan 28, 2012 at 5:32 PM
    WV150
    WV150 Well-Known Member
    South Carolina
    Trifecta Tonneau Cover
    Metalic brake shoes and pads?
