Sqeaking when truck starts up
Discussion in '2nd Gen. Tacomas (2005-2015)' started by countryboy22, Jan 5, 2011.
  1. Jan 5, 2011 at 9:36 AM
    countryboy22
    countryboy22 [OP] Well-Known Member
    Arizona Mountains
    05 SR5 4x4
    TRD cold air intake, Bilstein 5100's @ 2.5, Toytec 1.5" aal w/rear bilsteins. MBRP tip, Flowmaster Delta Flow 50 series, Toytec axle shims and carrier bearing drop.
    When I start my truck each morning its squeaks like my belt or one of my pulleys has an issue. It just started randomly I have done anything to the belt or the pulleys. It will only squill for like two minutes then it goes away and each time i start it the rest of the day it doesnt make that noise. Unless it has sat for quite awhile.
  2. Jan 5, 2011 at 9:43 AM
    memario1214
    memario1214 Vivid Illumination Vendor
    Colton
    Gillette, WY
    05 Dub Cab TRD Sport 4x4
    Yeah, I gots boost
    Try and tighten your accessory belt a bit. The one up front. Just use a wrench and turn the belt tensioners a little bit.
  3. Jan 5, 2011 at 9:46 AM
    countryboy22
    Arizona Mountains
    05 SR5 4x4
    ok will do thanks for the input
  4. Jan 5, 2011 at 9:49 AM
    countryboy22
    Arizona Mountains
    05 SR5 4x4
    my truck is an 05 and i havent ever replaced the serp belt do you think that that might have something to do with it? I prob need to change my belt
  5. Jan 5, 2011 at 9:50 AM
    memario1214
    Colton
    Gillette, WY
    Yeah, I gots boost
    Not much though. If it feels too tight then try and loosen it a scosche...
  6. Jan 5, 2011 at 9:59 AM
    rossk35
    rossk35 Do Work Son!
    hawaii
    07 TRD Sport Supercharged
    TRD S/C/TRD Intake/TRD Boost Gauge/DT Headers/OEM TL/ZKW retro/Pioneer DVD w/Ipod/Magnaflow/20% Tint/BHLM/JL 10" sub, JL VR components, JL 450/4 amp/Helwig Sway bar/Viper 791/ 18" limited 4runner rims
    Mine makes noise also, but comes and goes. It might be an idler bearing starting to go bad. Try spray some lube on them and see if that keeps it from returning. Also our trucks have a self tensioner that can't be adjusted
  7. Jan 5, 2011 at 10:37 AM
    memario1214
    Colton
    Gillette, WY
    Yeah, I gots boost
    It could be... I have an 05 as well with close to 100k on it. All of my belts are good. With that AZ heat you may be more prone to cracking though... I can't determine that over the computer ya know? But squeaks starting up are definitely precursor signs.
  8. Jan 5, 2011 at 11:56 AM
    05Moose
    05Moose Middle-Aged Member
    Jim
    In the snow (NorCal)
    '05 4x4 DC LB SR5 #8 (LSD, Tow Pkg)
    '05 4x4 DC LB SR5 (LSD & Tow Pkg), Timbrens, AAL, 5100s (1.75), Owned: 12/3/04 Mods: Fog, Map/Dome Light, Illuminated 4wd Switch, Washable Cabin Air Filter
    My serpentine belt lasted about 3 years (60K miles or so). If you've passed that point, you're probably way overdue for changing it! The first thing a worn belt will do is squeak when you start up the engine. It might also squeak more in wet weather.
    Don't lube it with anything (you might cause your new belt to squeal if you do), and the tension cannot be adjusted. Takes about 15 minutes to swap belts from underneath the truck.
  9. Jan 5, 2011 at 12:38 PM
    dexterdog
    dexterdog My pee parts itch
    Oly WA
    2012 F150
    it could be a precursor to a bigger issue. I would try to isolate which accessory is causing the noise. I would also take the belt off and check all of the pulleys.
    I would change the belt if you have not done so regardless.
  10. Jan 5, 2011 at 12:39 PM
    Krazie Sj
    Krazie Sj Resident Jackass
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Borla Catback Exhaust, Snorkel, 33s on either 16's or 18's, ARB Bumper, All Pro LT w/Walker Evan Shocks front and back, All Pro expedition leaf pack, 10,000lb Superwinch, Intake Manifold Spacer, Bed Rack with ARB RTT, Rotopack and Hi Lift mounted, Husky Liner mats and an air freshener from 1995.
    ^You thinking the oil pump too?
  11. Jan 5, 2011 at 12:42 PM
    AndrewFalk
    AndrewFalk Science!
    The North East
    2010 5 speed 5 lug
    When I initially start my truck and take off in first gear it always makes one quick squeak...and the sound comes from somewhere in the rear of the truck. After that one initial squeak, I never hear the noise again until I start up the truck and drive off the next time.
  12. Jul 27, 2014 at 3:54 PM
    Deserttrooper
    Deserttrooper Member
    Juan
    Las Vegas
    06 Prerunner
    CAI, HID's, interior lighting
    I have the same exact issue on my 2006 sr5 and have been searching through the forums, doubtful I'm dealing with the infamous "toyota tick"... Did you get your issue resolved Andrewfalk?
  13. Jul 27, 2014 at 4:11 PM
    tacoman00
    tacoman00 Your Average Joe
    Hampton Roads, VA
    2006 TRD-Sport Silver Streak Mica
    Bilstein 5100's with AAL in rear, 265/70/R17 BFG KO2 tires on 17x9 Fuel Maverick Machined rims with 4.5BS and -12mm Offset.
    the squeak in the rear could very possibly be U joints or bad carrier bearing...
