Squadrons make a big buzz sound
Discussion in 'Baja Designs' started by orbot, Sep 7, 2021.
  1. Sep 7, 2021 at 11:13 AM
    orbot
    orbot [OP] Well-Known Member
    Cant be right.
  2. Sep 7, 2021 at 4:16 PM
    Rome604
    Rome604 I am the Captain now
    Dave
    Alexandria, VA
    2023 TRD Pro Sequoia
    I’d take the wires and directly touch them to your positive and negative terminals of your battery so you can bypass any switches or relays. If they still buzz then contact @Baja Designs and they’ll get it straightened out.
  3. Sep 7, 2021 at 7:18 PM
    orbot
    Think the wiring might cause it? Btw one of the sets came with a shitty wiring kit
  4. Sep 8, 2021 at 6:48 AM
    Rome604
    Dave
    Alexandria, VA
    I know that faulty relays and switches can buzz. They are also the easiest and cheapest thing to fix out of the lot. If you narrow it down to just the light then you’ll need help from BD.
  5. Sep 22, 2021 at 2:26 PM
    Baja Designs
    Baja Designs The Scientist of Lighting Vendor
    San Marcos, CA
    This, but also make sure the vehicle is running. The only time our lights will typically buzz is if they are not getting adequate power.
    If you find they are still buzzing when connected to a verified power source, then please PM me and I will get you taken care of 100%. I am heading out to Overland Expo in a few hours, so I might be even slower than usual to respond. You can always hit this page and go through the listed process if I take to long to connect you myself.
    https://www.bajadesigns.com/help/warranty-policy.asp
  6. Sep 22, 2021 at 3:40 PM
    orbot
    Will check that, thanks
