square tubing rock sliders
Discussion in '1st Gen. Tacomas (1995-2004)' started by Totland design, Oct 11, 2012.
  1. Oct 11, 2012 at 7:09 AM
    Totland design
    Totland design [OP] Member
    Kevin
    Salt Lake City, utah
    Here is a set of square tube rock sliders that i made for my buddy mike(trowbocop). We decided on square tubes to get a more bulky look.
    And here is a few pics of the build.
    Let me know what you guys think.
  2. Oct 11, 2012 at 7:34 AM
    tc98tacoma
    tc98tacoma Well-Known Member
    Nik
    San Antonio, Texas
    98tacoma4x4
    3inch toytec coils 5100's, aal(soon to be replaced), 33/12.5 km2s, + a money hole...
    Those look nice..have a little angle to them rather than looking like a rectangle and plain
  3. Oct 11, 2012 at 9:08 AM
    Tenax
    Tenax Well-Known Member
    Terry
    Alberta
    03 prerunner trd
    17 inch wheels
    i like em. i would round the corner where it is sharp at the angle on either end. safer..and would look more custom i think. then i'd buy a set from you!
  4. Oct 11, 2012 at 10:50 AM
    DitchDoc
    DitchDoc Well-Known Member
    Logan
    Western North Carolina
    03 V6 QC TRD Limited 4x4
    2003 DC 4x4 TRD Cap K&N FIPK
    I am looking at building something similar. Question for ya, what are you cutting your square tubing with. I'm looking for a nice cut but don't have the moola to buy something like a plasma cutter. TIA
  5. Oct 11, 2012 at 11:01 AM
    BAMFTACO
    BAMFTACO Another day another beer
    Juan
    Woodlandland hills , CA
    2007 Tacoma AC Prerunner
    Kings bruh
    Nice and I like square tubing. What's the thickness of the tubing and diameter
    unstpible likes this.
  6. Oct 11, 2012 at 11:06 AM
    TacoDell
    TacoDell Truck ~n~ Tow
    SoCal
    '00 Tacoma SR5 4X
    Donahoe CO's, Deaver leaf paks, Lockright Locker, All Pro body armor ( sliders, front and rear bumpers ), All Pro under belly skids, Warn M8K w/Masterpull synthetic line, Dual Optima battery system, 4 ea LightForce Striker 170 offroad lights, 8 ea wired rock lights, and plenty more I'm sure
    kool...
    but how much of a gap is left at the bottom of the door
    and slider surface... when that's opened ?
    the pictures make it look kinda close, but I can't tell from the pics.
  7. Oct 11, 2012 at 3:34 PM
    Totland design
    Kevin
    The tubing is 1.5" x 1.5" with 0.120 thickness. The angle is not as sharp as it looks on the pic so there is plenty clearance between the bottom of the door and the slider.
  8. Oct 11, 2012 at 3:37 PM
    Totland design
    Kevin
    For these I actually used my trusty angle grinder. You just gotta make sure you cut it straight!
  9. Oct 11, 2012 at 8:29 PM
    TacoDell
    SoCal
    '00 Tacoma SR5 4X
    maybe you could give me some real numbers and not a politician's answer.
    I've looked at the pics numerous times...
    and maybe those don't show well...
    but the sliders position looks like the door(s) would narrowly miss.
    And tho' your sliders probably would deflect less then others might...
    I'd suspect they still would.
    I've guided trucks thru boulders that wedged both sliders up.
    like a teeter-toter if you will...
    The operator couldn't get his doors open...
    and I had to harass 'im a bit for that...
    before helping of course :D
  10. Oct 11, 2012 at 9:14 PM
    DitchDoc
    Logan
    That's what I was considering doing. Thx
  11. Oct 12, 2012 at 8:11 AM
    Trowbocop
    Trowbocop Adventurer
    Nashville, TN
    03 Tacoma SR5 4x4
    Wanted to let you know, I already had these attached to my frame, and Kevin finished them off for me. He did a way better job than what had been previously been done.
    Here are the before pics:
    Tacodell- I'll open the door and take some pics and measurements today, and let you know.
  12. Oct 14, 2012 at 12:21 AM
    DitchDoc
    Logan
    How far past the rocker should your sliders be?
  13. Oct 14, 2012 at 1:32 PM
    TacoDell
    SoCal
    '00 Tacoma SR5 4X
    1/2" will be fine...
    'bout where mine sit as well.
    My buddy is too fat to crawl out of a window...
    so he just sat on 'is ass, in the seat, looking confused at me. Lol
    thanks... no real reason for me to care...
    I'm just annoyingly curious.
  14. Nov 19, 2015 at 10:09 PM
    Cadmus
    Cadmus Un-Known Member
    Fort Collins CO USA
    '04 4door 4x4 TDRoffroad
    BUMP!!!! @Totland design
    Nice sliders Totland. Very nice. I was planning on making some like this as a winter project. I have a bandsaw so square is easier for me to work with compared to notching/fitting pipe with a holesaw.
    Can you post more photos?
    Especially of the marriage to the frame. Looks good. I like the look of square. 'not sure what causes more windage but i like the ease of cutting and joining and also square tube as a greater moment of inertia of plane area compared to round tube of similar weight to length.
    Have you used a hi-lift on them? any denting or deformation? That was one of my concerns.
    Is there anything you would have done different?
    Well done
  15. Nov 20, 2015 at 7:48 AM
    Trowbocop
    Nashville, TN
    03 Tacoma SR5 4x4
    Hey, not on here often, will try to follow through with photos soon! I've used hi lift on them a few times, worked great- never dented or bent or anything. Never had any issues clearing the door- never even crossed my mind. Used them a few times on the under side, sliding- but nothing pivoting on the outside. Still kicking ass. I wouldn't change anything on them, they're tucked in tight to the body and don't get in the way otherwise. I'm 5'7" and just hop in, I don't really need to climb in using them, but could if needed.
  16. Nov 20, 2015 at 7:49 AM
    SlipperyTaco
    SlipperyTaco Slippery when Wet
    Chandler, AZ
    04 Tacoma 4x4 & 2014 4Runner Trail Premium
    FOX 2.5 C/O, CAMBURG UCA, FOX 2.0 REAR, SMP CUSTOM FRONT BUMPER, BAMF LCA SKIDS, SCS RAY 10 MATTE GREY WHEELS, 305/70/16 BFG KO2, ALL PRO STANDARD LEAF PACK, ALL PRO SLIDERS, U-BOLT FLIP KIT, MARLIN CRAWLER REAR BUMPER, TIMBREN REAR BUMPSTOPS, WHEELERS SS BRAKE LINE F/R, D-BADGED, GIBSON CAT BACK, K&N CAI, LINE-X , GREY WIRE MOD, APOLLO 3.0 SHROUDS, D2S XB 5500K HID BULBS, LED HALOS, LED DEMON EYES, TRS LED BULBS, BHLM, IGGY PODS, CALI RAISED PODS, 30" CALI RAISED 4D LIGHT BAR, BESTOP SUPERTOP, TRASHAROO , WET OKOLE SEAT COVERS. 4 RUNNER- 2014 TRAIL PREMIUM W/KDSS KINGS FRONT AND REAR DIRT KING BALL JOINT UCA METAL TECH LONG TRAVEL SPRINGS METAL TECH UPPER/LOWER LINKS SONORAN STEEL KDSS TRACK BAR URD EXHAUST URD Y PIPE URD MAF CALIBRATOR PEDAL COMMANDER PRINSU ROOF RACK RIGID ADAPT LIGHT BAR SCS SR8 17" GUNMETAL 285/70/17 FALKEN WILDPEAKS TRS FOG LIGHTS TRS HID KIT SS OFFROAD SLIMLINE WITH SIDE PROTECTION COASTAL REAR SWINGOUT HEFTY FAB SKIDS
    Looks good me likey
  17. Nov 20, 2015 at 3:29 PM
    Trowbocop
    Nashville, TN
    03 Tacoma SR5 4x4
  18. Nov 20, 2015 at 5:23 PM
    Cadmus
    Fort Collins CO USA
    Thanks. Nice job. I missed the fact that it was not Kevin's truck, (D'oh!) so i sent questions to him requesting photos of how you married them to the frame. Just looked at your build. very nice.
    and it had this in the photos:
    Is that angle iron or did you make an L out of plates? What dimensions?
    Do i see 5 plates on each side?
    Just 6 of those 1/2" beads on each plate? I want to minimize the welding as to minimize the HAZ on my chassis.
    Did you gusset the proximal arms? If so above or below?
    Where on the plate did you put the proximal arms?
    Did you weld 100% of the joints from the proximal arms to the plate? if not how much of each ? Must be hard getting in there.
    Only if you have time. Thanks for posting more photos.
  19. Nov 20, 2015 at 5:28 PM
    MatthewMay1
    MatthewMay1 I'm an amateur professional.
    Matthew
    Lone Star Republic
    Supercharged '01 TRD
    Probably one of the best square tube designs I've seen. Nice work
  20. Nov 20, 2015 at 5:30 PM
    Cadmus
    Fort Collins CO USA
    I never thought i would see "nice cut" and "plasma cutter" in the same sentence.
    ...but perhaps other people have a steady hand relative to mine.
    unstpible and Sceprent like this.
