Squareone Creations - A Product Development Thread
Discussion in 'North East' started by Nimble9, Feb 25, 2019.
  1. Aug 8, 2020 at 1:04 PM
    #301
    Nimble9
    Nimble9 [OP] visit squareonecreations.com Vendor
    Lebanon, PA
    2006 4x4 DCSB
    enough to have fun
  2. Aug 8, 2020 at 1:05 PM
    #302
    Nimble9
    Lebanon, PA
    2006 4x4 DCSB
    enough to have fun
    New Logo!
    super_white likes this.
  3. Aug 10, 2020 at 7:10 PM
    #303
    Nimble9
    Lebanon, PA
    2006 4x4 DCSB
    enough to have fun
    gsubioguy, Cooktop86 and TwistedTLM4 like this.
  4. Aug 18, 2020 at 6:52 AM
    #304
    kerner
    kerner Well-Known Member
    2020 Magnetic Gray TRD Offroad
    I've been looking for a rack solution like this for a 3rd gen DCSB with the Lomax tonneau. Positioned properly you'd have full usability of the cover with just 18" of clearance under the rack. I'm pretty sure there'd be a decent crowd here interested in a rack that goes over that cover. My current plan is building something out of extruded aluminum, but this looks great (and not having to build would be a plus). If you'd be interested I'd be happy to help with it.
    Nimble9[OP] likes this.
  5. Aug 18, 2020 at 11:36 AM
    #305
    Nimble9
    Lebanon, PA
    2006 4x4 DCSB
    enough to have fun
    That'd be something for the future! I certainly could design it. I believe the challenge with that is the rack uprights would have to be vertical to clear the folding action of the tonneau, which is okay but doesn't always look the best IMO.
  6. Aug 18, 2020 at 12:56 PM
    #306
    kerner
    They may not have to be perfectly vertical. The uprights would need to sit at the outside of the bed rail, but the Lomax sits pretty far in when closed. Also if you put the uprights in the right spot, you might be able to clear them due to the swing of the panels. There are spots where 14-16" of clearance would be enough. Certainly would take some playing, but if you go through the Lomax channels there's desire for a rack that works with this cover and nobody seems to have one.
  7. Aug 18, 2020 at 4:25 PM
    #307
    buca
    buca Member
    Peter
    Portland, OR
    2019 Cement Tacoma TRD Sport
    @Nimble9 would the SideRide work with the @Mobtown Offroad full height bed rack? I would like to use something other than the tow hitch rack I have now. The added length and not being able to easily open the tailgate is a problem.
  8. Aug 18, 2020 at 5:37 PM
    #308
    Mobtown Offroad
    Mobtown Offroad Boss
    Joe
    Harrington, DE
    2002 SR5 4Runner
    I don’t think so. I’ll talk to Joel. Would be cool if it did.
    buca[QUOTED] likes this.
  9. Aug 19, 2020 at 6:44 AM
    #309
    Nimble9
    Lebanon, PA
    2006 4x4 DCSB
    enough to have fun
    I'll talk to @Mobtown Offroad and see how compatible it is :)
    let's chat :cheers:
  10. Sep 2, 2020 at 10:17 AM
    #310
    Nimble9
    Lebanon, PA
    2006 4x4 DCSB
    enough to have fun
  11. Oct 19, 2020 at 11:56 AM
    #311
    Overland&UpMoutains
    Overland&UpMoutains Fully Built Overland Rig for Sale
    Parker
    Deleware
    2018 TRD Pro MT Blue
    Armor: Custom Fabricated Front Bumper (Victory 4x4 Blitz w/ full width tubing added after) Victory 4x4 Strike Steel Rock Sliders Coastal Overland Rear Bumper w/ Dual Swing Out Steel and reinforced Hitch Receiver RCI Full Aluminum Skid’s Wheels/Tires/Suspension 34” BFG KO2 (Full size spare on swing out) 17” KMC Impact (black) Fox 2.5” Front Coilovers w/ DSC Adjuster Upgraded Springs: 650 lb Eibach 14" Long 3.0" ID Coil Springs Total Chaos Upper Control Arm Fox 2.5" Remote Reservoir Shock Kit for Rear w/ DSC Adjuster ICON RXT Leaf Spring (Option 3/Heavy Setting) Wheeler Superbump Front + Rear Bumpstops ICON U-Bolt Flip Kit Body Mount Relocation ECGS 8” Clamshell Bushing (Eliminates Needle Bearing) **For Refrence: Suspension set up is equivalent to Stage 4a Acutune** Performance/Off-Road Stuff/Recovery Nitro 4.88 Regear installed by ECGS Dobson 4x4 Snorkel Differential Breather 10k lb winch (Smittybuilt) Extended rear brake lines Hi-Lift Jack w/ weatherproof cover included (mounted to roof rack, can also be mounted to swing out) Air Compressor and Air Hoses included 4 ton jack stand included Tree saver winch strap included D-Ring Shackle x 2 included Spare Parts Include: 1 Wheel Bearing, 1 Tie Rod End Interior Accessories Custom Rear Seat Delete Platform Dashtop Multi-Mount (DMM), Will include 3 RAM mounts, one radio mount and two phone mounts iPad Mount, attached to passenger seat bracket, used for navigation Headrest Velcro Pouch Kit (Blue Ridge Overland) Overhead Storage Attic (Blue Ridge Overland) Trash Can (Lusso Gear Spill-Proof Car Trash Can, 2.5 Gallon Hanging behind Passenger seat) Fire Extinguisher Mount Exterior Accessories/Storage Prinsu Cab Rack Rugged Case (47” weatherproof rifle case mounted on Prinsu roof rack) Custom Roof Rack on Camper (designed to fit traction boards perfectly with space on either side for bikes or storage cases) Tailgate Storage, custom design using deck hatch that utilizes the interior space of the tailgate where I store recovery gear. Overland/Camping: Camper Custom (see details below) Bed light Bed lighting Domestic Fan Swing Up Rear/Side Panels with Locks Roof Rack 200 watt solar panel LED Third Brake Light Rear View Camera (connects to video rear view mirror in cab) Hurricane Hinges (not in the first few pictured as it was recently installed, you can see them in the later pictures but they are now painted black not silver to match the camper, totally waterproof no leaks!) Bed Buildout/Living System Baseboard/Mounting Plate (1/2” Birch, Bed Liner Coating) Trunk Cabinet Shelf Cabinet (fits 2 Sidio crates plus top storage box w/ organizing dividers) Elevate Fridge Cabinet w/ under storage for stove/cooking gear Custom 8020 build - strong enough to sit/stand on Water: 10 Gallon Water tank with pump, two spouts, one in back seat one in the bed 5 lb Propane Tank w/ mount attached to Swing Out (likely included, final tbd) Drop down table (attached to swing out) Rear Seat Delete (custom) Lighting: Rigid Adapt 30” Light Bar Rigid Ditch Lights Quad LED Headlights Meso Dual Red/White Interior Lights (Map + Dome) Camper interior lighting Electric Dual Battery System RedArc BCDC 25a Controller 90 Ah AGM Secondary/House Battery 200 watt solar panel 2 Blue Sea Fuse Boxes to manage accessories (one under hood, one in bed) Extra fuses included Comms: Midland Micromobile GMRS WeBoost w/ extended antenna on a RAM pivoting mount Other Fumoto Oil Change Valve Bike Rack (Tire Mounted)
    @Nimble9 does the side bike mount work with hard topper (ARE Overland is what I have)?
  12. Oct 19, 2020 at 8:36 PM
    #312
    Nimble9
    Lebanon, PA
    2006 4x4 DCSB
    enough to have fun
    most caps could work if the cap was cut, but other than that it would most likely not work as the mounts and the cap take up the same space
  13. Oct 22, 2020 at 6:08 AM
    #313
    Nimble9
    Lebanon, PA
    2006 4x4 DCSB
    enough to have fun
    **Updates**
    Latest Products to drop!
    2005 Tacoma Frame Caps are live! - https://squareonecreations.com/collections/accessories/products/bumper-end-plates
    My new SWAG is all ready!
    Premium "Mood Shirt" (Will literally be your most comfortable shirt) - https://squareonecreations.com/collections/swag/products/squareone-creations-mood-shirt
    Squareone Creations Logo Shirt - https://squareonecreations.com/collections/swag/products/squareone-creations-t-shirt
    Squareone Creations Patch - https://squareonecreations.com/collections/swag/products/squareone-creations-patch
  14. Nov 1, 2020 at 11:30 AM
    #314
    Kane50
    Kane50 Well-Known Member
    2016 TRD Sport
    Why no shipping to Hawaii :confused:
  15. Nov 1, 2020 at 1:41 PM
    #315
    Nimble9
    Lebanon, PA
    2006 4x4 DCSB
    enough to have fun
    PM me for a quote!
  16. Nov 1, 2020 at 3:09 PM
    #316
    uploadadventure
    uploadadventure It’s all @ColoradoTJ’s fault
    Dixon, Mo
    2019 Cavalry Blue Tacoma TRD OR (sold) 05 Duramax
  17. Nov 1, 2020 at 3:26 PM
    #317
    Nimble9
    Lebanon, PA
    2006 4x4 DCSB
    enough to have fun
    looking good!!!
  18. Mar 5, 2021 at 4:44 AM
    #318
    Nimble9
    Lebanon, PA
    2006 4x4 DCSB
    enough to have fun
  19. Mar 10, 2021 at 7:52 PM
    #319
    fatfurious2
    David
    Ashburn, VA
    2010 TRD OR Access Cab
    :fingerscrossed: for some tool mounts for the bed rails. Would like them to mount with a single bolt in the rail.
    Similar to these:
  20. Mar 24, 2021 at 11:16 PM
    #320
    BalutTaco
    BalutTaco Moja_Przygoda
    2019 Cement Limo Trail Edition -> 2022 Magnetic Grey OR
    Bird nest engine bay.
    upload_2021-3-24_23-16-23.jpg I would like a freee sticker please :(
