Squareone Creations - SideRide Bike Mounts
Discussion in '3rd Gen Tacoma Parts Marketplace (2016-2023)' started by Nimble9, Nov 13, 2020.
  1. Dec 25, 2020 at 9:29 PM
    #61
    tacomarin
    tacomarin ig: @travelswithchubbs
    Bay Area
    2018 DCLB TRD OR
    Prinsu Cab and Top Rack VO Drifter LED Interior, License Plate, and Reverse Lights Huskyliner Weather Beater floor mats Salex Center Console Organizers 35% Front/15% Rear Tint Debadged and De-stickered Anytime Front and Rear Cameras Brute force front bumper BAMF HC Dual swing out 285/75r17 BFG KO2 Front: ADS 2.5, EXT, RR, Clickers Rear: OME Dakar HD, ADS 2.5, EXT, RR, Clickers Stainless steel brake lines (+4 in rear) Wheeler's Offroad Superbumps Front and Rear Wheeler's Offroad U-bolt flip ECGS CV Axle Bushing SCS Stealth 6 17x8.5 wheels, matte dark bronze
    I told you it was a stupid idea! :D
    RushT[QUOTED] likes this.
  2. Dec 26, 2020 at 6:18 AM
    #62
    RushT
    RushT Amateur Everythingist
    North Texas
    '18 DCSB TRDOR Inferno
    Nah.... just needs some different engineering. Like the addition of a riser to clamp the the forks higher up... or something similar. Overall, it’s a more challenging setup.
    Nimble9[OP] likes this.
  3. Dec 26, 2020 at 9:59 AM
    #63
    tacomarin
    Bay Area
    2018 DCLB TRD OR
    A buddy used to carry his bikes on the side like that and would just loosen the stem and rotate the bars 90 degrees, which isn’t too bad but would get old. My mt bikes have 800mm wide bars so I’m always thinking about catching them on things
  4. Dec 27, 2020 at 3:14 PM
    #64
    BroID
    BroID Well-Known Member
    The Gem State
    2017 Tacoma TRD off road
    BFG KM2 255/85r16 Bilstein 5100s OME 888, HD Dakar’s, JBA control arms, BAMF Shackle hangers and shackle.
    Squareone, what do you think about running your side ride with a Max modular/Kbvoodoo bed rack?
    the rack can sit on top of the side ride possibly? Double up the mounting hardware for the rack and the side ride? I would also lift the other legs of the rack the same height that the side ride lifted it.
  5. Dec 27, 2020 at 3:17 PM
    #65
    Nimble9
    Nimble9 [OP] visit squareonecreations.com Vendor
    Lebanon, PA
    2006 4x4 DCSB
    enough to have fun
    The bedrack is exactly where the mounts need to be. But i think KB has bike mount accessories that work with that rack!
  6. Dec 27, 2020 at 3:22 PM
    #66
    BroID
    The Gem State
    I own them but like yours. It would be nice to have the bike just a little lower when going through tight spots. I also have the cargomax on one side that prevents me from running their bike mount. Yours would fit underneath possibly. Looking through your posts to find pictures of how it mounts to each rail
  7. Dec 27, 2020 at 3:38 PM
    #67
    BroID
    The Gem State
    It won’t work. You do have a very slick side ride bike mount.
  8. Dec 27, 2020 at 3:43 PM
    #68
    Nimble9
    Lebanon, PA
    2006 4x4 DCSB
    enough to have fun
    thank you! I’m working on compatible accessories, so maybe in the future the setup you want will be possible!
  9. Dec 27, 2020 at 3:54 PM
    #69
    Ainapo
    Ainapo Well-Known Member
    SW WI
    MT+LB=sport
    I want to drill holes in my fiberglass snugtop and bolt these on externally. Will you make a set for this application?
  10. Dec 27, 2020 at 4:06 PM
    #70
    Nimble9
    Lebanon, PA
    2006 4x4 DCSB
    enough to have fun
    I don’t have any plans for something like that, but if you don’t mind trimming your cap the standard mounts should work
  11. Dec 27, 2020 at 4:12 PM
    #71
    Ainapo
    SW WI
    MT+LB=sport
    Thanks for quick reply. The snugtop has such a long overhang... I'd feel better about drilling holes than cutting out chunks (in terms of keeping it dry inside). Thanks.
  12. Dec 27, 2020 at 4:16 PM
    #72
    Nimble9
    Lebanon, PA
    2006 4x4 DCSB
    enough to have fun
    totally understandable! Unfortunately I don’t know the strength of a fiberglass type rack, and the weight of mounts plus a bike might be too much. I could potentially make one like that one day though!
  13. Dec 27, 2020 at 4:35 PM
    #73
    Ainapo
    SW WI
    MT+LB=sport
    I'd be your guinea pig. The first thing I did to my new cap was to drill 26 holes in it. Only the first one was hard. No leaks yet!
    Nimble9[QUOTED][OP] likes this.
  14. Dec 27, 2020 at 4:48 PM
    #74
    Nimble9
    Lebanon, PA
    2006 4x4 DCSB
    enough to have fun
    Well PM me I can see about making something!
    Ainapo[QUOTED] likes this.
  15. Dec 28, 2020 at 2:05 PM
    #75
    [SEAR]taco
    [SEAR]taco Well-Known Member
    2019 White Tacoma TRD sport dbcb
    I am from Western PA I can be your Guinea pig!
  16. Dec 28, 2020 at 4:24 PM
    #76
    Nimble9
    Lebanon, PA
    2006 4x4 DCSB
    enough to have fun
    pM me if you’re serious! :D
  17. Dec 29, 2020 at 5:22 AM
    #77
    Nimble9
    Lebanon, PA
    2006 4x4 DCSB
    enough to have fun
    Went to bump this thread, then realized it's Tuesday, soooooo
    Taco Tuesday Bump! :taco:
  18. Jan 3, 2021 at 9:17 PM
    #78
    ez_tacos
    ez_tacos Member
    Erich
    '18 SR5
    Hoping to gather some information from this group, might have to post in other sideride and/or softopper threads as well, but we will start here.
    I am looking to get a bed rack that will go over my current softopper and still be able to use the sideride mounts. I believe @Unchained5150 had a older SOS concepts that worked, but they appear to have altered their design and it doesn't look like it would work any more. I've found quite a few images on the old google machine, but most appear custom and I am wondering if that is the route I will need to go. Since I have a long bed, I have considered using a short bed rack with the hopes of having the extra space near the cab for the sideride, but I don't really feel like dropping a thousand bucks only to find out it doesn't work.
    Any and all info is great, thanks in advance.
  19. Jan 3, 2021 at 10:09 PM
    #79
    velomutt
    velomutt Well-Known Member
    2018 Taco DCLB OR INFERNO
    A bunch of Meso Custom stuff.
    Pmd you ez_tacos
  20. Jan 4, 2021 at 4:23 AM
    #80
    Nimble9
    Lebanon, PA
    2006 4x4 DCSB
    enough to have fun
    so as long as there is 5" or so from the bedrack upright / forward most mounting support the SideRide should fit. I have my own Softopper Bedrack that I made out of 5052 aluminum designed to work with the SideRide and other mounts, but It's not ready for production yet unfortunately.
