Squeak coming from driveshaft. I think!?!?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 09rojotacoma, Apr 7, 2016.
  1. Apr 7, 2016 at 6:09 PM
    09rojotacoma
    09rojotacoma [OP] New Member
    Nat
    Currently stock 2009 Tayota Tacoma Pre-Runner
    None so far.
    I got a squeak coming from my driveshaft I think. I have a 09 Tacoma Pre-runner 2wd and I don't know if I have to replace and U-joints or just grease them, and if I do have to replace any how many are there thanks!
  2. Apr 7, 2016 at 6:12 PM
    Yetimetchkangmi
    Yetimetchkangmi Well-Known Member
    Benjamin
    Newcastle, WA
    03 Tacoma 4x4 The Yeti
    ARB front locker, Custom high clearance rear bumper, Custom plate front bumper, mile marker winch PE8, safari snorkel, Deck Plate Mod Fox 2.5 rr DSC, Camburg UCA, squeaky Dakar leafs, 5125 10" and custom 7.5" shackles, thee finest PNW pinstripes, MT-R, Nissan crew cab roof rack??? wtf is that about??? Allpro skids, Rigid duallys President McKinley CB with PA Recaro SRD with Wedge Engineering Morimoto retrofits Champion Rad - Failed Tundra brakes
    Just going to leave this right HERE
  3. Apr 8, 2016 at 12:41 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    IF you have grease fittings you should be greasing them every oil change ( my opinion ). Note you may or may not have grease fittings. My Prerunner does, many have reported that they don't. Crawl under and look.
    There are three on a Prerunner one at the transmission, one after the center carrier bearing and one at the differential.
    If you have them pump grease in until you see Clean Fresh Grease come out of all four end caps of each universal joint. Then take a ride and see if the noise is gone. You may still need new joints, but the grease will help.
