Squeak from A/C controls - 04 Tacoma 4 door
Discussion in '1st Gen. Tacomas (1995-2004)' started by wesleykey, Jun 1, 2019.
  1. Jun 1, 2019 at 1:30 PM
    wesleykey
    wesleykey [OP] New Member
    I have a squeak coming from a plastic part under the dash on the passenger side. This part is the part that moves when you adjust the temperature from hot to cold. When the dial is adjusted as cold as it will go, I hear a squeak. When I crank it a bit over toward hot, the squeak stops. I will try to attach pictures. The A/C blower is over on the far right under the passenger dash, but this part is over to the far left.
  2. Jun 1, 2019 at 7:07 PM
    wesleykey
    Can anyone see the attachments? Trying to learn to use this forum.
  3. Jun 3, 2019 at 6:10 AM
    wesleykey
    Wow. No one?
    I believe my issue may be the A/C actuator. Can this be lubricated or will it need to be replaced?
  4. Jun 4, 2019 at 2:12 PM
    ThunderOne
    ThunderOne Well-Known Member
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
  5. Jun 4, 2019 at 6:05 PM
    wesleykey
    Yes. The blend door. Or the actuator. Or the servo. Half my issue was the part has 10 names. It was $260 from the dealer or $150 on eBay. I removed it, greased it, and my problem is solved.
    ThunderOne likes this.
  6. Jun 6, 2019 at 3:14 PM
    bentenna
    bentenna Well-Known Member
    Ben
    2004 Black Tacoma SR5 TRD
    2 inch leveling kit
    I had the same symptoms. My problem was the blend door servo motor. 40 bucks from rock auto. Only 3 screws to replace.
