Squeak from front left wheel base.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by airsoft_warrior, Sep 28, 2009.
  1. Sep 28, 2009 at 6:53 PM
    airsoft_warrior
    airsoft_warrior [OP] Batman
    Zack
    Edgewater, Maryland
    2015 Tacoma DCLB Limited
    TRD Performance Exhaust
    I put on my bilstein 5100's a couple of months ago and I noticed that there was a slight squeak coming from the front left wheel base. I couldnt tell what part it is coming from. Any suggestions?
  2. Mar 15, 2010 at 2:02 PM
    05offroad
    05offroad Well-Known Member
    Michael
    El Cajon, California
    '05 Long Travel Prerunner
    I've lost track
    BUMP....Old thread but I'm in the exact same situation and it drives me nuts. started off little and now it squeaks the whole time I drive. Anyone have a solution??
  3. Mar 15, 2010 at 3:40 PM
    nvdeserted
    nvdeserted Well-Known Member
    Reno, NV
    2009 Tacoma TRD OR Access Cab
    Electric Dynolock tailgate, TrailGear Slides, , 285/75-16 Yoko Geolanders on Wheelers Type B, SAW 2.0 front and back, Camburg b/j UCA, 1.5" AAL, Ubolt flip, ARB bump.
    All trucks will eventually squeak -Chinese proverb
    JK, but where I start usually is wet the area down with a hose real well and drive around the block real quick. If it stops squeaking when wet its probably some dirt or something causing extra friction in suspension components. If you're handy with a wrench, pop out bolts on strut, Control arms etc and just apply a good thick grease to moving parts and make sure everything is torqued properly; also check that all your lugnuts on the wheel are tight.
    If you're not too handy with a wrench, get some WD-40 and spray the rubber bushing at the bottom of the strut, other components etc... it'll work for a while.
    Determine whether it sqeeaks from bumps or just being driven.
  4. Mar 15, 2010 at 7:00 PM
    airsoft_warrior
    Zack
    Edgewater, Maryland
    mine seems to be from even slight bumps. I havent noticed it in a while though but I havent driven with my windows down either.
  5. Mar 20, 2010 at 7:01 PM
    Anthony
    Anthony San Antonio Detailer :)
    Houston - Spring/Tomball area
    06 prerunner access cab 2.7L M5
    Nfabs Afe Pro Dry UWS linex'd toolbox
    bump
    same here, happened after installing 5100s
  6. Mar 21, 2010 at 6:50 AM
    airsoft_warrior
    Zack
    Edgewater, Maryland
    That squeak is coming from both front 5100's. It is very annoying with my windows down. it is every time the front shakes. any ideas how to solve it?
  7. Mar 21, 2010 at 11:17 AM
    Anthony
    reading up that its the swaybar touching the coil springs.
  8. Mar 21, 2010 at 11:20 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Sway bar shouldnt touch the coils with the 5100's.
  9. Mar 21, 2010 at 12:08 PM
    Anthony
    i just took at look at mine and the swaybar is really close to the coil spring on both sides, to where i could imagine theyd touch eachother over a bump or something when the suspension travels.
  10. Mar 21, 2010 at 12:31 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Check the coil spring for marks from it touching. If its touching, it will eat away at the paint on the coil.
  11. Mar 21, 2010 at 1:59 PM
    airsoft_warrior
    Zack
    Edgewater, Maryland
    If thats it then how do I fix it?
  12. Mar 21, 2010 at 2:15 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Sway bar relocation bracket/spacer.
  13. Mar 21, 2010 at 2:17 PM
    airsoft_warrior
    Zack
    Edgewater, Maryland
    Great more money. I am going to see if they are touching. Which is the sway bar... (I feel like such a NOOB)
  14. Mar 21, 2010 at 2:19 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
  15. Mar 21, 2010 at 2:24 PM
    airsoft_warrior
    Zack
    Edgewater, Maryland
    Thanks I will go check right now.
  16. Mar 21, 2010 at 2:33 PM
    airsoft_warrior
    Zack
    Edgewater, Maryland
  17. Mar 21, 2010 at 2:42 PM
    airsoft_warrior
    Zack
    Edgewater, Maryland
    It is actually coming from the passenger side. mainly.
  18. Mar 21, 2010 at 3:01 PM
    Sparky4.0
    Sparky4.0 Well-Known Member
    Aaron
    WestTexas
    01 trd beat to hell
    the a arm
  19. Mar 21, 2010 at 3:03 PM
    airsoft_warrior
    Zack
    Edgewater, Maryland
    Yeah whatever its called. I just took the pic so everyone would know what I was talking about.
  20. Mar 21, 2010 at 3:54 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Is it comming from where it mounts to the frame, or the spindle?
