Squeak from Left Rear Tire - Any ideas ?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by NBtacoma84, May 15, 2011.
  1. May 15, 2011 at 12:49 PM
    NBtacoma84
    NBtacoma84 [OP] New Member
    NB, Canada
    05 4x4 TRD Sport
    EBC Sport Rotors OME 884 Coils Toytec AAL Extang Trifecta toneau
    I've got a 2005 Tacoma DC 4x4 with 210,000kms (2" Lift Coils & 2" AAL). About a month ago I started hearing a squeaking noise coming from the left rear wheel when my truck was rolling forward at slow speeds or accelerating, but only when the truck is moving forward. When it rolls backwards, no squeak. The squeak occurs from stop to 25km/hr then subsides. I've jacked it up, put it on stands and let the tires spin forward - No squeak. I've pulled the tires off and let it spin - No squeak. There doesn't seem to be any contact with the rear brake shoes and the sound doesn't seem to be coming from the drive shaft either.
    So what I've gathered is that the squeak only occurs when there is weight on the tires and the truck is rolling/accelerating forward. I'm leaning towards rear bearing, but wouldn't the squeak occur in reverse as well if it was a bearing going bad?
    I'm a little stumped on this one. Any suggestions would be greatly appreciated
  2. May 15, 2011 at 12:52 PM
    StandingCow
    StandingCow Well-Known Member
    NJ
    09 SR5 4x4 V6 access cab
    Sounds to me like a bearing, not sure what else that could be.
  3. May 15, 2011 at 12:59 PM
    ColtsTRD
    ColtsTRD Well-Known Member
    Scott
    AZ
    is the sound definitely coming from there? If not it could be your carrier bearing or u-joints
  4. May 16, 2011 at 12:54 PM
    NBtacoma84
    NB, Canada
    05 4x4 TRD Sport
    the sound is definetly is coming from the left tire area.
  5. May 16, 2011 at 12:56 PM
    YFZ_TRD
    YFZ_TRD 4Runner Pilot
    Lee
    Beaverton, OR
    2014 4Runner SR5
    I would say bearings as well. The wheel rolling when you're driving and there is weight on the bearing is not the same as you putting the truck up on a jack and spinning the tire.
  6. Aug 3, 2011 at 3:11 AM
    gbtoy4x4
    gbtoy4x4 Well-Known Member
    Greg
    Las Vegas
    2010 Silver TRD AC OR 4x4 6sp
    Factory Silver Sport Grill, Gray TRD Shift Knob, BFG 285/75/16 AT's, Debadged, AFE Cai, TRD Short Shifter, Redline Hood Struts, Leer Topper, Budbilt Front, Mid+Xcase Skids, ELocker Skid, Icon C/O, Built Right UCA's, Rear 2in AAL w/Bilstiens, AP U-Bolt flip, 1" 4Crawler Body Lift, Relentless Front Bumper w/Lights + Sliders, Rear Breather Mod, 5 ProComp 7089 Rims, AP SS Brake Lines, Famous Fab HC Rear Bumper W/Swing Out Tire Carrier, Synthetic Brake Fluid, Synthetic Power Steering Fluid, Front Superbumps, Hood Blackout,
    Check the aal, might have moved
    seems like mine moves off friction and squeaks
