Squeak/Groan from steering system
Discussion in 'Suspension' started by DanS, Aug 18, 2010.
  1. Aug 18, 2010 at 6:16 PM
    DanS
    DanS [OP] Member
    Central Coast, California
    Lifted 2000 Tacoma 4x4 5spd 2.7L 4cyl
    All-Pro upper A arms uniball long travel, tru trac rear locker, downy adjustable lift up front, all-pro rear springs 3 inch, greasable rear shackles from northwest offroad, k&n air filter, 33" BFgoodrich MudTerrain T/A, alpine stereo w/ipod hookup
    2000 taco 4x4 downy adjustable lift with all pro upper a arms uniball long travel and 33" tires.
    I recently went to the dunes and mashed it up pretty hard. I didn't notice anything break at any point, though.
    The problem: When the steering gets about halfway through one direction, it begins to squeak/groan. It only happens when the steering wheel is turning, but will happen if the car is moving or not. Car still operates normally and handles fine.
    I took a look underneath and noticed that the steering rack torques/rotates a little around its long axis when the steering wheel moves. I tried re-torquing all the associated bolts, but this did not help.
    I have also noticed a little gash in the metal that houses the upper end of the coil spring/shock assembly. (not sure what to call this cause some of these parts are not stock). It appears that this gash could be in the path of travel of some of the suspension components under extreme conditions. I am not sure, however, when this gash appeared. Also, its not a huge gash, it would not have taken a lot of force to cause.
    Any ideas?
  2. Aug 18, 2010 at 6:17 PM
    DanS
    DanS [OP] Member
    whoops, sorry for posting this twice
  3. Aug 18, 2010 at 6:19 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    First of all, you need new steering rack bushings. Look at Wheelers offroad for those.
    As for the gash, are you talking about the coil bucket, the part that houses the upper part of the coil and is welded to the frame? If so you were definitely mashing on it hard!
  4. Aug 18, 2010 at 6:23 PM
    08pretaco
    08pretaco Well-Known Member
    az
    2014 Tundra 4x4 CM 5.7L SR5
    got any pics of the gash? id like to see
  5. Aug 18, 2010 at 6:38 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    x2
  6. Aug 18, 2010 at 8:27 PM
    DanS
    DanS [OP] Member
    Here is a photo, taken at night =D
    "Gash" might be an overstatement, but it IS in metal.
    Do you think this could be related to the steering issue I mention?
  7. Aug 18, 2010 at 9:21 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    Well it looks like you bent up the coil bucket pretty good. You might want to look into some coil bucket gussets. I don't know much about them but I know some of the long travel guys on here could help you out in that department. As for the groan, I really have no clue. It wouldn't surprise me if you bent some other stuff as well. Did you jump the truck at all?
    edit: actually, it looks like its just been ground off in that spot in the pic. Is the metal ripped?
  8. Aug 18, 2010 at 9:25 PM
    malander
    malander Well-Known Member
    max
    01 limited trd 4x4
    deck plate mod,jba cat back,bilstein 5100's,ome 883 springs, Allpro expos, allpro U-bolt flip kit, 10" Bilstien 5150 shocks, custom lower shock mounts
    my truck had an annoying whine to it dont know if thats your problem exactly but the rack and pinion was gashed open and had to be replace... 900 bones later it was fixed
  9. Aug 18, 2010 at 9:49 PM
    08pretaco
    az
  10. Aug 19, 2010 at 6:21 PM
    DanS
    DanS [OP] Member
    I don't think the coil buckets are bent or even ground down, they look straight and they have a machined metal lip/bead... Maybe they were installed as part of the Downy adjustable lift? The previous owner of the truck installed the lift...
  11. Aug 19, 2010 at 7:27 PM
    nelson18matt
    nelson18matt Well-Known Member
    Goodyear, Arizona
    2004 Long Travel Tacoma
    *SOLD*
    when i had my mid travel susp the top of the uni ball made contact with the coil bucket and left a similar cut into the metal like you have there... that could be the case for you too.
    maybe not to top of the uni ball (it doesn't look like it from the pic) but some part of the UCA made contact w/ the coil bucekt
  12. Aug 19, 2010 at 8:54 PM
    DanS
    DanS [OP] Member
    After this contact, did you notice any problems?
